Results 1 to 21 of 21
    Junior Member Two Rings fowl's Avatar
    Aug 24 2020
    2010 Audi S5
    Cayman
    Gutted Catalytic Converter VS Test Pipes?
    As the title of my thread says Gutted Cats vs Test pipes. Here is a bit of back ground. I purchased the car in Sep 2020. It came with a bad PCV and water pump. Both were changed along with the thermostat by the Audi dealers. I have the JHM 207mm pulley, IE TCU and ECU tunes, Merc Racing HX and IE intake. Plugs are NGK BRKR9EIX gapped at .26.
    Car ran great for a few months and then last week puff of white dust came through left tail pipe, change of exhaust note and loss of power. Chunks of Cat material started coming through the exhaust and right side cat seem to be going as well. I immediately knew what the issue was from reading threads here, but was concerned about loss of power. I suspect its down 30hp or more. Took it to mechanic and he said change both cats and confirmed that nothing is wrong with engine.
    Now back to my thread title, I definitely do not want to put back the cats as I think they will fail again. So I am asking what's the pros and cons of Gutted Catalytic Converter vs Test Pipes and which one is preferable? Which one would you choose and why?. The answers would really help me to make up my mind. Oh, just a FYI, I have order the magnaflow 11385 as I was going to do the exhaust mod before the cats failed.
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Quote Originally Posted by fowl View Post
    Now back to my thread title, I definitely do not want to put back the cats as I think they will fail again. So I am asking what's the pros and cons of Gutted Catalytic Converter or Test Pipes and which one is preferable? Which one would you choose and why?. The answers would really help me to make up my mind. Oh, just a FYI, I have order the magnaflow 11385 as I was going to do the exhaust mod before the cats failed.
    Most people will say that gutted cats sound better than test pipes. I think there is more then enough evidence of people's experiences to believe that is in fact the case. The gutted cats should have both the flanges welded to strengthen them and keep in mind that a gutted cat will be harder to re-install then a test pipe.
    With Test pipes you can sell your cats or hang on to them for going back to stock. This isn't a option for you at this point. I have seen some people claim that a test pipe flows better then a gutted cat but I haven't seen any real evidence of that either way.
    Sent from my SHT-W09 using Audizine mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    I am at a similar crossroads. The cost of test pipes are flippin expensive for being some pipe welded to a flange but, se la vie. If you can finagle the cats out without damage you get ~$300 back. Id say test pipes if you can afford the cost of buying, install, and getting exhaust to sound better. Gutted cats are cheap and risky but def more evidence of cleaning up the sound. With your mods, IMO, go test pipes.
    Aug 24 2020
    2010 Audi S5
    Cayman
    Come on guys please help me out here, any further comments.
    Apr 29 2018
    This subject has been well discussed on this forum. I went through a ton of posts on here deciding what I would do when the time came and there was more then enough information to come to the conclusion that gutted cats sound better then test pipe. Because there isn't a Turbo wheel in our exhaust taking some of the bite out of the V6 exhaust note things can get ugly and loud in a hurry once the cats come out.
    Because of the sound and smell I decided to order a set of RedStar HFC but if I were in your shoes having already blown one of my cats out, I would have went the gutted/reinforced cat route.
    Sent from my SM-N986U using Audizine Forum mobile app
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Search is your friend. All of us have read the threads. You should, too. RoofRails summarized it well. If you want more details read and draw your own conclusion. There is no agreed-upon consensus on the total solution despite the issue being with us for years. There does seem to be agreement that gutted cats are less offensive than test pipes from a drone/rasp perspective, but are still unpleasant and loud.
    FWIW: I'm stage 2 dual pulley and still on stock cats. I'm sure they will fail. When they do, I plan to remove, gut, reinforce and reinstall, maybe put in downstream high flow bottle cats for smell and maybe some drone/rasp mitigation. We have no emission testing here. I expect some unpleasant drone and rasp. I am still studying the best approach there.
    Reasonable minds differ as we continue to explore various x-pipe, resonator and muffler combinations. Part of that problem is that ears being human and sounds being subjective, there will always be honest debate and disagreement on what "sounds good".
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    I agree with all the comments above. The sound is going to be somewhat subjective. I have test pipes and I've had quite a few different exhaust configurations since I bought the car. I like how my current setup sounds (see signature for the details) but it took awhile to get here:
    https://www.youtube.com/watch?v=18d1...ature=youtu.be
    The other variable you might or might not struggle with is your downstream O2 sensors. Do you plan to try spacers or will you be getting a specific tune?
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Quote Originally Posted by RoofRails View Post
    This guy said everything that should be said ^
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Aug 24 2020
    2010 Audi S5
    Cayman
    I was thinking of using spacers as I don’t think IE turns off the O2 sensors in their tunes.
    Junior Member Two Rings prabkaler's Avatar
    Apr 27 2020
    I’d go with test pipes. Sound aside, getting the cats in and out is a huge pain in the a**. And not to mention test pipes are cheaper than how much you can sell your cats for. Bought my redstar test pipes for around 700 and sold my factory cats for 450 CAD a piece, and the passenger side was melting.
    Aug 24 2020
    2010 Audi S5
    Cayman
    Thanks to all for your comments.
    Established Member Two Rings Hamsteak's Avatar
    Oct 08 2020
    Georgia
    I know I'm a bit late to this thread but I got my Cats Gutted earlier this month with a healthy 1200$ expense, I wouldn't think the price would've been too much cheaper on the install if I had test pipes. But the cost overall would've put me at or almost at 2000$ total. Which, if you don't have that much to spend, simply gutting the cats would be the best alternative option IMO.
    In terms of sounds the car is a decent bit louder and sounds good without being too obnoxious or raspy, just think about it like Stock Plus almost. However, while drone itself did not get louder, I do get a funky note coming from the cats on low-mid throttle at low-mid rpm. It's your preference whether you mind such a sound or not but that's all up to you. Personally I can live with it.
    While the cats are a pain to get to, test pipes only really make the re-installation process easier. I haven't heard many people use this method but an easier way to get access to the cats ESPECIALLY the top bolts is to take off/un bolt the drive shaft and while you have to subframe loosened, use a ratchet strap to pull the transmission from one side to another to get some extra room.
    IMPORTANT NOTE : Once the gutting was done I had no issues regarding the O2 sensors, I tuned to car with IE for Fuel-Cut launch prior to getting the work done.
    2015 Audi S4 Prestige | Sepang Blue | Black Interior | 10.796 @ 125.69
    | IE Intake | IE TB 100 Tune | AEM Methanol Kit (1000cc Nozzle) | IE TCU Tune | IE 80mm Throttle Body | APR 57.75mm Supercharger Pulley |
    | IE 188mm Crankshaft Pulley | Apr Heat Extractor | Ported Supercharger From Shane Horning | CSF Radiator | Gutted Cats |
    Aug 24 2020
    2010 Audi S5
    Cayman
    Quote Originally Posted by Hamsteak View Post
    Thank you very much for this detailed explanation. It helped a lot.
    Aug 24 2020
    2010 Audi S5
    Cayman
    What do you guys think about these? Let me know your thoughts.
    https://www.ebay.com/itm/193933119655?ul_noapp=true
    Apr 27 2020
    Never heard of them to be honest, but looks like they’re decent. Just make sure they’re 304L stainless steel and at least 2-2.5mm thick and you should be good!
    Feb 14 2017
    Gulfport, MS
    Never heard if them. I see Red Star Exhaust test pipes on the same eBay page for the same price. They are respected here.
    Aug 24 2020
    2010 Audi S5
    Cayman
    Quote Originally Posted by MSq5 View Post
    I saw the RSE ones as well but they will take 4-6 weeks to get to me and my car is down waiting on this test pipe. However these TP can get to me in 4-5 days. I found the Becker TP on eBay and its about $150 cheaper but there are several complaints about their quality on here so I am hesitant buy them.
    Aug 24 2020
    2010 Audi S5
    Cayman
    [QUOTE=prabkaler;14479651]Never heard of them to be honest, but looks like they’re decent. Just make sure they’re 304L stainless steel and at least 2-2.5mm thick and you should be good!
    The test pipes are Stainless steel 1.6mm thick mark 316, flanches out of 304 stainless steel.
    Aug 24 2020
    2010 Audi S5
    Cayman
    Quote Originally Posted by prabkaler View Post
    May I ask why you said it should be 2-2.5mm thick when the Red Star is only 1.6mm?
    this is a quote from their add on eBay. "Highest quality 1.6mm wall 304 stainless steel".
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    If you saw my thread at all I've recently went through all of this. My passenger side cat snapped at the flange connecting to the header. A friend wanted to weld it up, but all shops that I talked to said it was just going to break again. I finally went to a fabricator that offered really low price for custom made test pipes and catted down pipes installed for $1100. He explained to me as the pipe for the stock cats heat cycle the pipe absorb more carbon. which in turn make them brittle. He could weld them up but did not recommend so I went with him creating test pipes and catted down pipes. I know that cats are just going to be a problem with this platform, that said, now that they are in my down pipes I can easily replace them within a hour if they fail again. As for sound, yes they make your system loud and raspy (less raspy when the exhaust is warm). The sound evolved to be a little better over time but it still was too loud for my liking... I like sporty but not a "look at me" make babies cry volume.... so I installed Vibrant Ultra quiets where the stock mid muffler used to be just last week. Sound is much better, maybe a little too quiet, but zero drone on the highway and almost no rasp. I guess I'm getting old, but I'm happy and my car is really finally ready to go from single pulley to dual pulley later this summer.
    https://www.audizine.com/forum/showt...ipe-Setup-B8-5
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
