Hello.
My wife always complain about not to be able to open car door when im putting stuff in the trunk so i google the matter and found this:
Key-fob Range LimitaƟon
DescripƟon: Extend the range of the key fob
● 46-Central Module Comfort System
● Long Coding
● Change range_limitation_lock, range_limitation_rear, range_limitation_opening,
range_limitation_panic, and central_locking_system_requst_for_range_function to Not
Active
● Press and hold green check mark to accept
Ist a cutout from a obdeleven coding document for audi b9.
But when i try this on my A7 2016 with obdeleven the list in 46 central comfort is just byte and bit, does anyone know what byte and bit to change to disable range limitation of the keyless system?
Best regards
Emil
