I've seen good and bad reviews for H&R springs. Visually they look great and I believe lower the car the most out of all springs if you go for the Super Sport. As far as the bad I've read people with them say the ride can be too firm/bouncey and the springs can cause issues/wear quicker than other springs. I have 034 Motorsport Dynamic Lowering Springs on my 2016 mag-ride S3. They are linear springs so the ride is a bit firm. Drop is 0.75in. I've never read a bad review for these everyone seems to like them. I've hear good things about APR roll control springs as well. If I ever switch springs I'll probably go for the Neuspeed Sport springs which lower by 1in all around on mag-ride. Adjustable springs seemed like something I would like but after reading a lot of reviews I changed my mind. The actual process of adjusting the height is not that simple. I would just set the height once and never change it again so for me it wouldn't make sense to spend two to three times as much on height adjustable springs. If your going to track the car then that's different. Coilovers require a mag-ride delete or it will throw codes and lights at you. Regarding spacers, when I was using my OEM wheels I was running 10mm all around for a flush look.
You can see mag-ride S3's with different springs here:
https://www.audizine.com/forum/showthread.php?t=877031
Here are a few pics of my S3 with OEM 19in wheels, 10mm spacers, and 034 Motorsport Dynamic Lowering Springs. The black wheels are 19in Neuspeed RSE102's (20lbs):
I also have APR Stage 2 High Torque and DSG tune on 93 octane and love it. Unfortunately APR discontinued their Stage 2 tune so you will have to look at Integrated Engineering, REVO, and other tunes instead if you plan on tuning. I highly recommend it. The difference between stock and Stage 1/2 is huge and fun.
Sent from my SM-G981U1 using
Audizine Forum mobile app
