Aftermarket support is limited for the CREC. The SIMOS 16 ecu is hard to crack, so at the moment we only have tunes from APR, EPL, and 034. There is a small shop called Boost Dynamic Tuning that offers remote tuning for the CREC as well. And IE and VAST are working on remote solutions for the CREC. So right now things are limited, but hopefully we'll have more options later this year. The thing that sucks is all the tunes that are currently offered do not offer Ethanol maps which is a huge let down because the main benefit of the CREC engine is that it has Dual Injection meaning it should take to Ethanol much better than the Simos 8 cars. As far as TCU tune goes I highly recommend Berk aka BG.SQG.
I've been trying to push the platform and am aiming to be the first in the 10s and have found out a couple things along the way that are different between the Simos 16 and Simos 8 car, like for instance our fuel pumps are different, so are our alternators. So if you start needing to replace certain engine components make sure to check for parts based on VIN. If you plan to push big power I'd take a look at getting your supercharger clutch welded as they are known to fail at higher power levels. I haven't done it yet but I need to shortly, I'm already pushing over 500hp.
