Got into the shop for the alignment alot quicker than i thought. Was out quite a bit - which i expected.
Update: Holy smokes
FIXED the issue! and i don't really think?! i even needed the obd11
Got the car back from alignment shop.
Tried clearing the code following the procedure i listed above. Security code 43702 seems the only code that worked. Again same results - no beeps/no learning happening after OBD11 reset learned values for Steering Assistance.
Got home and came across this video:
https://youtu.be/zXyTuW4Eog4?t=229
On a whim i tried it again using the procedure outlined in the video.
Turned the car on, foot on brakes, put the car in gear.
Turned the wheel left all the way...BEEP! (less than 5 sec)
Turn the car all the way right BEEP!
Centred the wheel. Code vanished.
Cleared codes with OBD11, re scanned No Fault Found.
Code:
OBDeleven data log
Date: 2021-02-17 19:21
VIN: WA1UFCFL1FA012268
Car: Audi A4 Allroad
Year: 2015
Body type: Avant
Engine: CPMB
Mileage: 106940 KM
01 Engine
System description: 2.0l R4/4V TF
Software number: 8K5907115N
Software version: 0005
Hardware number: 8K2907115L
Hardware version: H09
ODX name: EV_ECM20TFS0118K5907115N
ODX version: 001006
Long coding: 722A0013242600062000
Trouble codes:
No trouble codes found
02 Transmission
System description: 0BK 20TFSIUSA
Software number: 8K0927158AE
Software version: 1003
Hardware number: 0BK927156AL
Hardware version: H18
ODX name: EV_TCMAL551211
ODX version: 002022
Long coding: 000001
Trouble codes:
03 Brakes
System description: ESP8 quattro
Software number: 8K9907379N
Software version: 0020
Hardware number: 8K9907379N
Serial number: --------------
Long coding: 0E150001
Trouble codes:
04 Steering Angle Sensor
Trouble codes:
05 Keyless System
System description: BCM2 2.0
Software number: 8K0907064JP
Software version: 0650
Hardware number: 8K0907064JP
Hardware version: H14
Long coding: 0D824040000000000000
Subsystems:
System description: J764 ELV MLB
Software number: 8K0905852E
Software version: 0046
Hardware version: H40
Serial number: 0214000105166005
Trouble codes:
03286 - Right front exterior door handle touch sensor Open circuit
static
Priority: 2
Frequency counter: 1
Driving cycle: 167
Mileage: 106942 km
Date: 2021-02-17 17:08:36
08 Air Conditioning
System description: KLIMA 3 ZONEN
Software number: 8K1820043AQ
Software version: 0123
Hardware number: 8K1820043AQ
Hardware version: H04
Serial number: 01100620140048
Long coding: 6480208000
Trouble codes:
09 Central Electrics
System description: BCM1 1.0
Software number: 8K0907063DH
Software version: 0103
Hardware number: 8K0907063DH
Hardware version: H16
Serial number: 00000831822401
Long coding: 26000096863CAFE00100488300003D0D0F9CC70822090201000008004400030100000020000000
Subsystems:
System description: MITSUBA250414
Software number: 8K1955119B
Software version: 0461
Serial number: 1404180703404
Long coding: 004577
System description: G397_RLFS
Software number: 8U0955559B
Software version: 0002
Hardware version: H06
Serial number: 22739033
Long coding: 02005D
System description: E1 - LDS
Software number: 8K0941531AS
Software version: 0031
Hardware version: H03
Serial number: 00000000002705141092
System description: AQ_Hum_Sensor
Software number: 4H0907658
Software version: 0003
Serial number: DDC88037000000000001
Trouble codes:
15 Airbag
System description: AirbagVW-AU10
Software number: 8K0959655R
Software version: 0812
Hardware number: 8K0959655R
Hardware version: H51
Serial number: 003NED12432M
ODX name: EV_AirbaECUVWAUDI010
ODX version: 003114
Long coding: 304544354A3238313130554A304C384B3053
Trouble codes:
16 Steering Column
System description: Lenks.Modul
Software number: 8K0953568Q
Hardware number: 8K0953568Q
Serial number: 90862NFC0012C
Long coding: 000017
Subsystems:
System description: E221 - MFL
Software version: 0004
Trouble codes:
17 Dashboard
System description: KOMBIINSTR.
Software number: 8K0920931T
Software version: 0564
Hardware number: 8K0920931T
Hardware version: H35
Serial number: ZA866K46F
Long coding: 8BA6290202010008020000
Trouble codes:
19 Gateway
System description: GW-BEM 4CAN-M
Software number: 8R0907468N
Software version: 0060
Hardware number: 8R0907468C
Hardware version: H11
Serial number: 3041Y145290A0B
Long coding: 80C303FF00
Subsystems:
System description: J367-BDMHella
Software number: 8T0915181
Software version: 8041
Serial number: 5105353503
Trouble codes:
03041 - Energy management active
static
Priority: 7
Frequency counter: 11
Driving cycle: 168
Mileage: 106942 km
Date: 2021-02-17 16:58:07
36 Driver Seat
System description: MEM-FS
Software number: 8K0959760D
Software version: 0077
Hardware number: 8K0959760D
Serial number: 00000104865366
Long coding: 00581B00000000000000
Trouble codes:
42 Driver Door
System description: TSG FA
Software number: 8K0959793R
Software version: 0510
Hardware number: 8K0959793P
Hardware version: H02
Serial number: 0000105536988
Long coding: 011C13205E00410001
Trouble codes:
44 Steering Assistance
System description: RCEPS
Software number: 8K0909144G
Software version: 0508
Hardware number: 8K0909144B
Serial number: 0015309797
ODX name: EV_RCEPSAU48X
ODX version: 008015
Long coding: 100000000001
Trouble codes:
C10ACF0 - Steering End stops not learned
static
Date: 2021-02-17 17:13:47
Mileage: 106942 km
Priority: 6
Malfunction frequency counter: 31
Unlearning counter: 168
VIN_EEPROM: 32323638
VIN_bus_system: 32323638
Steering wheel angle: 0.1 °
BUS_SCU_Motor_Angle: 0.0 °
BUS_SCU_Nominal_Angle: 0.0 °
End_stops_unlearn_reason: unlearned by Diagnostic Service 31
End_stops_unlearn_reason_hex: 05
46 Comfort System
Serial number: 0337364921
Long coding: 0126023A20BA309580B0023200000000
Subsystems:
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1501
Hardware version: H05
System description: J245 PS151
Software number: 8K0959591C
Software version: 0043
Hardware version: H08
System description: J394 PS240
Trouble codes:
52 Passenger Door
System description: TSG BF
Software number: 8K0959792R
Hardware number: 8K0959792P
Serial number: 0000105347817
Trouble codes:
53 Parking Brake
System description: EPB-4
Software number: 8K0907801N
Hardware number: 8K0907801J
Serial number: 10000000386083
ODX name: EV_ParkiBrake
ODX version: 001028
Trouble codes:
56 Radio
System description: Radio U SIRIU
Software number: 4G0035082G
Software version: 0133
Hardware number: 4G0035082
Hardware version: H60
Serial number: 156FP0E8020205
Long coding: 020007020100000001
Trouble codes:
5F Multimedia
System description: H-BN-NA
Software number: 8R1035664F
Hardware number: 8R1035664D
Hardware version: H41
Serial number: 203FV0EB005428
Long coding: 10020005000681ED45008B4E00000403F40000020000000000
Subsystems:
System description: NAR 2014
Software number: 8R0060884CA
Software version: 1002
System description: DU7 High
Software number: 8R0919604A
Software version: 0104
Hardware version: H42
Serial number: A130FO0E3050457
System description: E0380 Bedient
Software number: 8T0919611L
Software version: 0030
Serial number: 00000001883526
System description: CD-Database
Software number: 8R0060961G
Software version: 5950
Trouble codes:
62 Rear Left Door
System description: TSG HL
Software number: 8K0959795G
Hardware number: 8K0959795D
Hardware version: H01
Serial number: 0000105495631
Long coding: 010C13204000210001
Trouble codes:
6D Deck Lid Control
System description: J605 Master
Software number: 8K9827851C
Software version: 0330
Hardware number: 8K9827851C
Hardware version: H53
Serial number: 8K9827851C
Subsystems:
System description: J756 Slave
Software number: 8K9827852C
Serial number: 8K9827852C
Trouble codes:
72 Rear Right Door
System description: TSG HR
Serial number: 0000104998685
Trouble codes:
