    Junior Member One Ring
    Feb 05 2021
    San Diego
    2015 Quattro Audi A3 Tire Pressure Chart and Recommendations for 235/35 R19
    Hello all,
    I know this topic has been discussed thoroughly but I would like to ask specifically for the 2015 A3 Quattro tire pressure and also contribute the tire pressure chart coming from the 2015 A3 car manual I found online, which I didn’t find on the forums before.
    The sticker on the door does not include 235 35 19 tires and only includes the 225/40 R18 with tire pressure or 41psi... the guy who changed my wheels told me even if I change the rims to 19 I still need to stick with the door label... I was very skeptical given the tire pressure chart that I found noting 36 36 at maximum load and 35 32 at normal load....
    So my question is if my sticker is only noting 41 but the manual chart is noting 35/32 or 36/36, which one should I go by?
    Dec 25 2004
    Earth
    Mine says 44..
    I run 41
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Apr 29 2017
    wow 44 and 41 is high!
    I run 34
    2017 Audi A3 2.0T Progressiv Quattro S-line w/ 19'' Wheels
    Junior Member Two Rings JepoyA3's Avatar
    Jul 18 2019
    Quote Originally Posted by 17A3 View Post
    I run 34
    I run 41 and I feel it's just right. Handles decent enough, road noise is low, it rides supple, but just enough to feel the road. 34 is lowest I would go. 3 more psi lower and my tire pressure light would go on. All on personal preference and the type of tires you have. 44 though, yikes! I'd feel the tiniest spec of pebble on the road with that amount of psi haha.
    Veteran Member Three Rings 993140's Avatar
    Oct 14 2012
    GT3 Touring
    Way Out West
    Quote Originally Posted by Spike619 View Post
    You should run 35/32 unless you are carrying a full load as described by the table:
    Viken
    2024 RS3
    2023 S3 Premium Plus
