Results 1 to 8 of 8
    Junior Member One Ring
    May 27 2019
    nothing more...
    spain
    coding/pairing new mechatronic with odis
    Hi guys
    After spending 7k on my gearbox rebuild a year ago (my previous thread about the dl501 story...)
    The gbox is failing again having neutral to drive shudder and from second to first...on hard brake sometimes even stalling... The garage won't fix it as over a year has passed
    I have original vagcom but functions are limited.
    How can I recalibrate the gearbox with odis and also if needed.....pair a new mechatronic to it...
    Thanks
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Pairing a new one with odis requires a online connection.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    I'm not familiar with using ODIS since it's a dealers equipment but with VAGCOM you can do the adaption on the transmission. If you completely replace the TCU I'm not sure if you need it VIN coded to your new VIN. I put a newer transmission (2015) into my 2013 RS5 and with VAGCOM I see the newer transmission shows it's old VIN number and only Audi can program the VIN with ODIS. I'll know within the next week as I pull if off the lift whether the different VIN number makes a difference or if the Immobilizer will stop it from working properly.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Apr 27 2012
    Guelph
    Its component protection you will need to worry about.
    Sep 07 2019
    New london CT
    Does odis with a paid subscription allow independents to code new mechatronics
    Jan 10 2008
    Roy, WA
    Not sure but I would think if it was a paid subscription then they should be able to connect with the Audi servers in Germany and get all of the updates too.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jul 16 2018
    Atlanta
    Should be able to. And as far as new mechatronics, you have both component protection and immobilizer adaptation tasks to accomplish requiring online server access.
    https://erwin.audiusa.com/erwin/show...equirements.do
    5 steps towards vehicle diagnostics
    All steps must be completed in order. Perform only those steps not already completed.
    Step 1
    Independent Shop Registration
    Required to obtain Site ID. Allow one to two weeks processing. (If you are already registered and know your site ID, proceed to step 2.)
    Step 2 *
    Request Security Certificate
    Required to obtain your Org ID, Global user ID and ODIS certificate.
    Step 3 *
    Obtain Diagnostic License
    required to activate your ODIS installation
    Step 4 *
    Software Installation Instructions & Files
    Only one Download is required. One download contains all the Brand information needed.
    Step 5
    Purchase Diagnostic Subscription
    A subscription provides one year of unlimited access to all ODIS System diagnostic and reprogramming functions. Note: A separate subscription is required for each brand and is available on their individual web sites.
    * This step must be performed from the laptop that ODIS will be installed on.
    Certainly quite a process for individuals, but should be no big deal for shops.
    Jan 10 2008
    Roy, WA
    In addition to the above Audi also recommends to do the Adaption process on the DL501. Not sure the ODIS process but in Vagcom you go to Transmission, Basic Settings, and there are five adaptions in a row you need to do starting with "Adaption of Transmission range switch". Once you finish with Vagcom you need to drive the car but it won't necessarily be completed in one drive, sometimes it can take up to a couple of hours of driving and some say you need to drive it in Auto and do some manual shifting so you can spend time in both gear sets in the DSG, Odd gears on one shaft and even on the other. It does Pressure calibration, Distance sensors, clutch valve, clutch engagement point adaption. On my S5 it too about 1.5 hours on some good country back roads. I'm going to do it in the next week or so on my RS5 as it's a 2013 and I recently installed the DSG out of a 2015 RS5, NSD to PXL transmissoin code, which did require ODIS at the dealer and about 20 min of coding.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
