Onixiii,
You will get a lot of opinions on this, but I think you will be very pleased with something like the Bilstein B14 PSS kit, or the B16 PSS10 kit if you have money burning a hole in your pocket.
The additional shock settings are nice to have, but I think they can be a bit of a distraction for newer drivers. Most people just set them once and never touch the knobs again anyways.
Another great package is Koni Sports coupled with something like H&R Sports or Eibach springs. This combo won't break the bank and performs well, plus you get knobs to play with :)
I ran this package on my MK6 Jetta and could run circles around most Golf R's, although they had a nasty habit of getting back around me on the straights!
For Camber, you will need to talk to some other people here... but there aren't a ton of options. The 034 Sport Dynamic+ mounts look okay, as do the SuperPro mounts but I have heard that they both can be a bit clunky. There are also more traditional spherical bearing setups from Ground Control and Integrated Engineering.
I think ECS Tuning carries just about all the options here:
https://www.ecstuning.com/Volkswagen...n/Camber_Kits/
Whatever you do, I would highly recommend either RS3 control arm bushings or the new ones from Black Forest Industries:
https://blackforestindustries.com/pr...rubber-mk7-mqb
The front control arm bushing design does NOT hold the toe settings very well. These bushings will increase steering feel and give the car a bit more confidence.
Good luck and have fun!!!
