Hi! I have an Audi A4 B8 -11. My horn, steering wheel buttons and airbag (according to fault code) stopped working.
I was driving around with this for a while when my buttons started working again for a while but not the horn and airbag. After a little longer the buttons stopped working again so I punched the center of the steering wheel and saw the lights on the button flickering. So when I pressed the horn (still not working horn) the buttons would work. And after pressing the horn for a while my buttons worked for like 1 month (still not horn and airbag).
After some research I found that it should be the clock spring, delivering electrical power through the steering wheel. So yesterday I changed the clock spring and the horn and airbag now works but still not the buttons. So now I’m guessing the buttons were a coincidence that they stopped working at the same time at the beginning and because they have worked separately from the airbag and horn while they were broken it should be a second fault right? So now I’m looking at maybe buying the buttons from a broken car or maybe the whole steering wheel, anyone who knows why only the buttons stopped working? No visible cable loose while stripping down my steering wheel, no fuse got fired up and airbag is working so I guess it has to be the cables around the buttons? Cuz there is a connector behind the airbag I could have pushed with the horn while I got them to temporary work.
Secondly my steering wheel angle sensor got a fault code after stripping down the steering wheel and airbag, I tried the method to start on and off and drive in circles and turn the wheel and all of that. My eyes bleed while watching fault codes (and my stability program doesn’t work).
Thanks.
