Results 1 to 23 of 23
    Feb 02 2014
    Focus RS, Audi S4 & S5
    Knoxville, TN
    How to put a B8.5 on jack stands?
    I have a 2015 S4 that Id like to put on jack stands in my garage for a few weeks while i do some maintenance work. I have several jacks, 4 jack stands and a pair of ramps, but its not clear to me how to get the car onto 4 jack stands given what appears to be a limited number of jacking points.
    Senior Member Two Rings 6SpeedS4's Avatar
    Dec 19 2018
    2016 Audi S4 w/ APR Stage 1 /IE Intake / IE non-res downpipes / AWE Touring / ECS SS Clutch line / M
    Pittsburgh, PA
    Quote Originally Posted by whts4 View Post
    Because of that I use safe jack which allows you to lift from each pinch weld.
    Sent from my SM-N975U using Tapatalk
    2016 Audi S4 PP / Sport Diff / 6 speed / APR Stage 1 93 Octane / IE Downpipes / IE Intake / AWE Touring / Canyon strut bar / 034 Rear Subframe Mount / ECS Tran Mount / ECS SS Clutch Line / Merc heat exchanger
    2014 Audi SQ5 Prestige / IE Stage 1 91 Octane
    Oct 19 2008
    Ontario%20Canada
    Plenty of options for safe lift/stand points. A quick Google image search will show you where they are.
    2011 S4 - Ibis White - 3 pedals - daily driver
    2.95 PR, EPL software, Merc Racing HX, Eurocode inserts, Koni Yellows, H&R OE Sports, beefy RSB, homebrew CR15, stainless brake & clutch lines, custom FBSW by FlyDesigns, P3 Multi Gauge
    Established Member Two Rings DriveBikeRun's Avatar
    Dec 15 2018
    2014 Honda Odyssey, LOL
    Louisville, KY
    Yeah, there are jack points on the front and rear of the pinch weld on both sides. I’ve had mine on 4 stands several times.
    Veteran Member Four Rings KMPRSSD's Avatar
    Dec 19 2010
    E10 2002tii, 2010 VW Touareg Lux Limited
    Connecticut
    I think what OP is asking is how you you jack up from say the driver side front pinch weld and then get a jack stand under that same pinch weld. To the OP...I have jacked under the steering knuckles with a floor jack and then put a jack stand under the pinch weld. Also I have backed up onto ramps on the rear wheels, then used jack stands on the fronts. Ramps are obviously only good if you don't need to remove the wheels.
    ll B8.5 S4 l 6MT l IE STG ll SP l Daytona Grey w/ Magma l Sport Diff l Black Optics l B&O l AWE Touring w/ non res DP l 19" AG M590 l Luft-Technik Intake l P3 Gauges l EuroCode SS l RS4 Grille l Carbon Valance l DeAuto Fogs l RSnav ll
    Senior Member Three Rings BEight SFour's Avatar
    Oct 13 2019
    Alpine White E36 M3.. RIP rear ended
    Bay Area CA
    I had to buy a U-jack and some skinny Jack stands to get it jacked without too much trouble. Had to buy some rubber pinch weld pads too. If you have a regular jack you have to put a pinch weld puck all the way at the end of the jack point and as far to the jacking pad as you can to maneuver a stand under it, if you're using the actual pinch weld jacking point
    Sent from my SM-G975U using Audizine Forum mobile app
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    Pinch weld pads are great, I have both of these:
    https://www.amazon.com/gp/aw/d/B07Z6...?ie=UTF8&psc=1
    https://www.amazon.com/gp/aw/d/B06WR...b_b_asin_image
    You’ve gotta lift from just off the lifting point on pinch weld and then place the jack stand support under the actual lifting point. It’s a process and takes some trial and error. Sometimes I’ll lift the rear high enough to get a stand under the front. Experiment a little and you’ll find the sweet spot. Lifting pads will protect your pinch weld seem and underbody coating.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I've taken the side carry handle off of my floor jack, so I can get a jack stand right up next to it on the pinch welds. I also have a couple of these I bought for our Macan, but I find they don't fit on my jack saddle very well. https://safejacks.com/products/the-r...ck-single-unit
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Lower control arms will connect directly to the frame or a solid crossmember that bears the full weight. That frame spot or crossmember spot is where I place the floor jack.
    I lift temporarily until I get high enough to get the tire off the shop floor and place a jack stand under the associated pinch weld. Then, lower the jack and move to the next as needed. This way, I'm never under the car unless supported by jack stand(s) holding the car up at the pinch weld(s).
    I think this is the answer OP was seeking.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jul 31 2020
    Austin
    Quote Originally Posted by ShelbyM3 View Post
    This except I start in the front and it lifts the rear enough to slide jack stand under. Pinch weld goes beyond jack point so you can jack right next to it and place jack stand where the arrow/jack point is.
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    Quick Jack FTW!!!
    But if that’s not in the budget...
    I always had 2 race jacks on hand, and I removed a side handle from each one (opposite sides) I would place the jack at the extreme end of a pinch weld to allow my jack stand to slide in right next to the jack and still
    be safely on the pinch weld when the jack was removed. I would do front first then rear, but I always had a buddy on staff to help me when I was doing a full elevation... safety first!!!!
    I just noticed the jacks are in the photo and the handles are removed from the same
    side on these, I had a third that was opposite but it died recently and I tossed it and replaced it with a sweet giant Schwaben floor jack!
    Apr 02 2018
    Reviving a dead thread, but this lifting this car safely is a big PITA to me. What I did while doing brakes tonight allowed me to lift from the front pinch welds and still have room to put a jack stand beside the jack. I went old school and dug out a heavy duty scissor jack, put my pinch weld metal pad on it, then lifted at the far rear edge of the exposed pinch weld. Then I could fit a 3 ton jack stand beside it. Wouldn't pick my bigger jack stands still.
    Scissor jack is probably 40 years old, so I probably need to get a new one. Don't want to get the little one out of the trunk every time.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Quote Originally Posted by Andy-S View Post
    Jack stand is probably 40 years old, so I probably need to get a new one. Don't want to get the little one out of the trunk every time.
    if you have a garage, quickjack makes a lot of sense. I'm personally jacking the front of the car first by jacking under the front subframe and then putting the jackstands under the front pinch welds, kind of in the same way as many Mercedes and BMW cars want you to do it, but these of course have an official front central jackpoint. This is not an official Audi way, but I'm all about unofficial and don't have any front underbody shields, so that's how I do it. And then I'm jacking the rear of the car under the rear diff - this is an official Audi way if you don't have a sport diff. If you do you're SOL)
    Apr 02 2018
    Quote Originally Posted by fastboatster View Post
    I do have the shields on the front, and I do have the sport diff.
    I've looked at the quick jacks several times. I have a garage. They still take up space I'd prefer not to give up. And if I did want something like that, the MaxJax are cool, too.
    Apr 23 2019
    CA
    Yes, portable 2 post lift is the ultimate way to go if your floor is thick enough, that's true. or you can cut a hole in your underbody shield) jk.
    Jul 31 2016
    PA
    The pinch weld also runs the entire length of the car, just use something soft to not crack the plastic and you can lift it anywhere you want on that seam.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Apr 02 2018
    Quote Originally Posted by djn876 View Post
    I've actually thought about cutting the plastic back 3 or 4 inches all the way around. That may be the best option and allow me to use my jacks and still fir the stand beside it.
    Mar 26 2016
    Quick jacks store pretty easy…
    Aug 01 2019
    2013 S4 APR Stage 2, 2009 Subaru 3.0R
    Statesboro, GA
    I just leave my quick jacks under the car, so they don't take up any valuable. I also purchased mine as an open box so I saved a lot of money, but it did come with some problems and Quick Jack fixed them.
    Senior Member Two Rings reardoma's Avatar
    Oct 18 2020
    2017 Maserati Ghibli
    NC/DC USA
    Quote Originally Posted by B7TitaniumA4 View Post
    May I ask what wheels those are?
    I’ve got a similar set they are Alzor 601s which are the cheap version, around $200/wheel for 19x8.5et42
    https://www.ecstuning.com/b-alzor-pa...our/601-15kt1/
    2015 Moonlight Blue 6MT PP+ -034 stage2+ & constantly modded
    Mar 26 2016
    Genuine Audi, I think they are from an A5, these are my winter/extra set.
    Oct 18 2020
    NC/DC USA
    Thanks those are indeed the OEMs, very similar to the RS4 wheel.. VMR 708 replicas, etc. a couple similar ones on b8 avants s-line as well. Either way, looks good, esp with the red center against your silver
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
