Results 1 to 12 of 12
    Established Member Two Rings mpepin07's Avatar
    Nov 14 2020
    Denver
    DSG Fluid Options
    I'm about to order one of the DSG maintenance kits from ECS tuning and see that they have several options. One of them provides you with the genuine VW fluid (P/N G052529A2) and costs about $410 and one uses Liqui Moly 8100 Dual Clutch Gear Oil (P/N 20044) and costs about $210. Each of them also come with drain/fill plugs, cooling filter, trans filter, pan gasket and bolts.
    What is the consensus on the preferred DSG fluid to use?
    I tried searching online for info and couldn't find much. I am willing to pay the almost twice as much for the kit with genuine VW fluid if it is recommended, but if they are pretty much the same then obviously I'd like to save a few bucks here.
    Also, will I be okay doing this on ramps rather than jack stands? I see most of the DIY instructions mention having the car level. Will the few degrees from the ramps cause any issues for me?
    2013 Audi S4 | Phantom Black | Sport Diff | B&O Sound
    EPL Stage II ECU & DSG Tune (E20) | JHM 187 Crank Pulley | CTS Turbo Intake | 034 Trans Mount Insert
    Senior Member Three Rings Iwantyourcar's Avatar
    Jul 14 2018
    2010 Audi S4, 2019 Jeep Grand Cherokee, 1994 Oldsmobile Bravada
    Indiana
    I can’t comment on doing the job on jack stands, as I’ve only had my shop change mine. My car has around 134k on it. I believe the service is called
    For every 30k on audis maintenance schedule. I used liquimoly kit and I made it around 20kish before I definitely needed it changed. Now I have OEM in there. But it’s fresh so I’m not really sure if it will make it to the 30k mark yet.
    Most here will probably say go OEM. If you go liqui you may have to change it early? At least that was my experience.
    '10 S4 / Koni / JHM / 034 Motorsports / ST Suspension / ECS / CTS Turbo / Maxton Design / Polo / EPL / Rotiform / Podi / Brembo / Stoptech
    Established Member Two Rings Keymainey's Avatar
    Aug 04 2019
    '14 5.0 Mustang
    TX
    Fcp euro has an OEM full service kit for $225 and a great return policy.
    Ramps may show the incorrect fill level and you want to fill properly.
    As stated above, most that I've read use non OEM fluid had issues with it after a while.
    Mar 05 2016
    I had the exact same reflection, VW fluid or LiquiMoly DSG for half of the price. With our finicky dsg, all those potential circuit board and mechatronic issues, I decided to bite the bullet and go with the original fluid. Maybe it won’t change anything but I’m not taking any chance.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Nov 29 2019
    Cincinnati
    Use OE fluid. It’s not worth the risk to use anything aftermarket.
    Junior Member One Ring
    Oct 09 2018
    Atlanta
    When I changed mine at 35 k miles, I changed both filters and put in Redline DCTF. Trans shifts beautifully, behaves perfectly. When I renew it at 70K I'll use exactly the same thing. Redline FTW.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Quote Originally Posted by Keymainey View Post
    Quote Originally Posted by TC_S4 View Post
    ^ This. Who knows, but I would kick myself, if I put aftermarket fluid in and began to have issues over a few hundred $.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Nov 14 2020
    Denver
    Thanks for the replies guys. The kit through FCP Euro looks like it uses Febi branded fluid, not genuine VW/Audi. Is this correct? Link: https://www.fcpeuro.com/products/aud...audi-vw-516089
    Mar 05 2016
    Quote Originally Posted by mpepin07 View Post
    FCP don’t sell genuine VW DSG oil, they only have Pentosin which the the OE oil used on BMW, Febi and LiquiMoly DTC oil. I am a fan of LiquiMoly and Motul engine oil, but when comes to our infamous DSG only VW/Audi dsg oil that goes in. Specially all the circuit board and wires are bathing in the oil.
    I guess Febi is ok, but beware of the consequences if there are any😒
    Nov 14 2020
    Denver
    Okay good to know. I’ll bite the bullet and pay extra for the genuine VW/Audi.
    Thanks everyone!
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    Never had any issues with the Liqui Moly 8100 DSG fluid. I'm on my second dsg change with it and never noticed anything wrong. 3rd dsg service will be using the same.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Original works better. I had both Original and Motul. Original car runs a bit smoother in my car even the way solenoids works and clutch feels better on OEM in my opinion.
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
