So I have built my own k04 turbos. Using BW turbine housings, Turbo Rebuilders UK Enhanced CHRA's, and Knock off compressor housings. I have standard 4+4 comp wheel it's just billet over the standard cast wheel. But I have seen other comp wheels with a different amount of blades. And the standard turbine wheel is a 12 blade. But they make an 11 blade and 9 blade turbine wheel. Supposedly the 9 blade causes less back pressure over the standard 12 blade by allowing more exhaust to pass through relatively faster. And spools more in the upper RPM range. And the 12, blade spools up faster but doesn't provide as much boost in the top end. I know the smaller A/R doesn't help with the k04 running out of breath in the upper RPM range. They are good for the bottom end quick spool. Has anyone have any definitive information on the difference between the 9 blade and 12 blade turbine wheel. And or the difference in the 4+4 comp wheel and the 11 blade billet wheel. I'm thinking about possibly changing over to a 9 blade turbine wheel and the 11 blade comp wheel over the 12 blade ET and 4+4 comp wheel.
2003 A6 2.7T 6spd Stage 1+ (motor pulled for stage 3+ upgrades)
2001 Allroad TIP Stage 1
2006 A3 2.0T 6spd Stage 1
