I was pulling out of my driveway one day when a dash message said "Alternator fault, battery not charging". I stop the car and try to turn it on again, and the engine would crank once and stop. I checked the voltage the battery was at and it was reading 11.5.
I ended up getting the vehicle to the shop for them to look it over, and they called back the same day saying that the issue is not happening and that there is nothing wrong with the vehicle. I told them I would pick it up the next day, the following morning they called again saying with the tech tried to move the car to the lot the warning came on again, and that now it needs a new alternator.
They ended up replacing the alternator and I got my car back yesterday. Everything seemed fine, I did notice the car was idling slightly higher than usual (900 RPM), but nothing else seemed to change. Yesterday afternoon the error came back up on the dash and I was just able to get the car home before electronic systems started shutting down.
I'm getting the battery tested today, and really hoping that it is that.
Has anybody else experienced this? It's like the alternator charges sometimes, other times it doesn't. Possibly a loose connection somewhere? Any ideas would be helpful!
