I bought a full set of Moog front and rear solid sway bar end links, noting some C7 cars were fitted with nylon end links from the factory, but ended up not using these. The Moog K750359 is a direct substitute for the front sway bar end link, far heavier and stiffer than the factory units. Fits C7/C7.5 A6/S6, A7/S7, RS7.
Ships for $40 via UPS Ground
https://www.summitracing.com/parts/MOG-K750359 retails for $41.99/ea from Summit
