Results 1 to 6 of 6
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    Vacuum Coolant Fill Advice
    So I recently had my supercharger off and when I put everything back together, I went to use my vacuum filler to purge air and add coolant. Now its been almost 2 years since I last did it so my memory isn't great, but I thought previously I was able to pull and maintain a vacuum reading of close to 25" Hg. For some reason, I was only able to get about 15" Hg on the gauge this time and even letting the compressed air run through the venturi for over a minute, this was the reading the gauge stabilized at so I shut the valves and watched. It did not bleed down even after 2+ minutes so it doesn't seem that there is a leak but I'm not sure why I couldn't pull more vacuum.
    Any thoughts on this? I should mention my overflow reservoir did have a fair amount of coolant in it when I did this.
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    If it didn't bleed off, I wouldn't stress. Goes to show everything was sealed up, nice N tight.
    Jul 31 2020
    Austin
    Literally just happened to me yesterday. Same exact scenario and I figured out what it was. How many gallons is your compressor? I had to close valves at 15psi, then wait for my cheap 3 gallon compressor to refill, then open valves for it to finish climbing to 25 or 26 psi which is where it actually stops. In other words compressor ran out of pressure which is why it stopped at 15 psi. Don’t worry about coolant in the overflow tank just re-do it, make sure heater is turned up full blast when you do, and you may suck out some additional air this time by going to full 25 or 26 psi. Not a big deal though system self bleeds pretty well.
    Senior Member Three Rings Jk79's Avatar
    Sep 20 2018
    Chicago
    It should read around the 23-25 mark. A vacuum filler should really only be used on an empty system. In order for the fill to work the negative vacuum needs to be created throughout and then replaced with the fluid. Did the volume of fluid you added match the approx capacity? I would at least bleed to make sure there aren’t air pockets.
    2018 RS5
    2014 S4 - EPL Stage 2+ (SOLD)
    Jul 31 2016
    PA
    Did the system pull the coolant level up to the fill area, it may have just become water sealed if it did.
    You have to bleed it anyway so I wouldn't worry too much about it. Just finish up the normal bleed procedure and keep an eye on level as you drive for a little.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Mar 28 2017
    Thanks everyone. Just to close the loop here, the issue was that I didn't evacuate my expansion tank fully. I went back today and pulled as much fluid out as possible, then gave it another shot. Pulled to just past 25" and held solid.
