Originally Posted by
Striker27
See I get the whole idea of the upgrades. But what do you get in actual numbers. How much faster is it?? The aftermarket always seem to talk up the product. But no one ever seems to quantify the whole thing.
You are asking for a single answer to a question with multiple permutations of inputs. There just isn't a single answer. That is why even the big turbo vendors don't quote any numbers because "it depends". Makers/vendors of individual components quote numbers for those components if they have dyno'd them and can isolate the change to just that component. For example, if you take a stock A4 and add Stage 1, you get X hp,
everything else being equal! Now, is everything else always equal?
What if I add intake (what type/make), exhaust (what type/make), cat (what type/make), intercooler (what type/make), injectors, spark plugs etc. etc.?
Then there's the question of going fast.
- In a straight line? Quarter mile? On what tires? What outside temperature? What elevation? What's the vehicle weight?
- Around turns? What suspension? What brakes?
Depending on the above, the answer can be 30-200 hp as some of the others are indicating.
Do you see my point?
