Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 161
Thread: Lowering Links
  1. #121
    Mar 30 2022
    16 S6 / 18 SQ5 / 22 SQ5
    Virginia Beach, Va
    Seems like a few on here have asked about the adjustment lengths, equaling (fill in blank) drop, per turn. I have the TGK links that Eligh referenced in the video above. TGK recommends no more than 8 total turns per link or possible errors and headlight adjustments might pop up. Each turn roughly equates to a .25” drop. I adjusted my links to mirror the OEM ones, then adjusted them according to the drop I was after. Reinstalled, all good to go. Mind you, adjusted mine off the vehicle, measured with a micrometer and then installed them. Set and forget. Zero issues to report 👍🏼
  2. #122
    Jun 24 2019
    US
    Quote Originally Posted by 4TBBUCS View Post
    Great feedback. BTW, did you have your vehicle aligned afterward? I'm not convinced that an alignment is necessary, but then again, I will at least have it checked just in case.
    Sent from my SM-S908U1 using Audizine Forum mobile app
  3. #123
    Mar 30 2022
    Virginia Beach, Va
    Quote Originally Posted by scavokRS3 View Post
    Could just be me / subjective, but I re align anytime I change anything suspension (geometry) related. Again, subjective. The cost of an alignment is nothing compared to a set of 275 tires 😂
  4. #124
    Nov 22 2018
    Palm Beach Gardens, FL
    I got an alignment and it took them a while to get it dialed in. Car felt better afterwards.
  5. #125
    Veteran Member Four Rings Chard's Avatar
    Thanks for all the info guys! I'm looking into getting a set of links as well. For the function, it seems any brand will suffice.
    I've noticed a lot of discussion about number of turns. Since all manufacturers are probably different, perhaps the better thing to share is the length people are using from the center to center of cup (of front and rear links) and what ride height that achieves.
    This way, it wouldn't matter what brand you have.
  6. #126
    Jun 24 2019
    US
    FINALLY got mine installed! Along with a little extra cool air .
    Stage 1 IE as well, and removed resonator. Good for now!20230206_160105.jpg20230206_160117.jpg
  7. #127
    Mar 30 2022
    Virginia Beach, Va
    Nice! How much drop to did you gain? What’s your tire / wheel setup?
  8. #128
    Jun 24 2019
    US
    I lowered a total of 1", front and raised the back 1". Split the adjustments evenly.
    I'm on TSW Watkins ET 32 18".
  9. #129
    Sep 23 2023
    Delaware
    Can I ask what your measurement was/is? Curious how low you have them set to. I also have an Azores Green SQ5 and ordered lowering links. Your ride height looks great. Thanks!
  10. #130
    Established Member Two Rings cmil527's Avatar
    Oct 16 2023
    Old Bridge NJ
    Just picked up my ride Saturday any preference on brand with the links guys? Thanks in advance! 😊
  11. #131
    Senior Member Three Rings ADG05's Avatar
    Oct 17 2008
    Santa Monica CA
    Quote Originally Posted by cmil527 View Post
    I just posted a set in the B9 classifieds.
    2021 SQ5 Daytona Gray | Instagram: @raudi_sq5
  12. #132
    Oct 16 2023
    Old Bridge NJ
    So if u put in tire change mode and are on a lift do you still need to allow the car to go to sleep?
    2024-SQ5-Glacier White/Magna Red-Prem+-Options:S Sport,Nav,Sport Exhaust,BO Pkg & 21'' BO Wheels,Nappa Leather,Audi "S" Beam,Cargo Cover,Black Rings,Audi Guard-Mods:HRE FF10-21X9.5''-Tarmac-255/40 Pirelli P-Zero,20% Side & 35% Windshield Tint,JB4 Map 6 w/Bluetooth,Roar Pedal,034 Turbo Inlet & Trans Mount,AWE IC,Roc Euro Intake,ECS X-Pipe/Res Delete,Badgeskins DRL Kit,TGK Lowering Links,DSG Red CF Paddles+PSB,Maxton Kit w/V2 Lip & Roof Spoiler
  13. #133
    Jul 21 2023
    2018 SQ5
    Portland, OR
    I finally got around to purchasing some Airmatic links last month and getting ready to install them. I appreciate all the help in this thread, but I’m curious (and may have missed it somewhere) if anyone measured the length of the links front & rear before install? I’m aiming to close the wheel gap on a 21” wheel, but don’t need to tuck the wheels. I’m curious if any of you have measurement information for the length of the links prior to installing them? Any help/guidance/measurements (and fender height after) would be greatly appreciated!
  14. #134
    Veteran Member Three Rings Thudux's Avatar
    Jun 22 2016
    2012 Jeep Wrangler
    Houston, TX
    Quote Originally Posted by cgantz View Post
    I was at 32 1/2" in Offroad before before install
    --->2017 Audi SQ5 Build<---
    Instagram @ Thudux
  15. #135
    Jun 22 2016
    2012 Jeep Wrangler
    Houston, TX
    So I just did mine tonight and want to go mess with it tomorrow morning again some more in some daylight. Im sitting around 29 1/4" all the way around and looks pretty sick. I am curious tho....why do you need to make them the OEM length and then adjust how you want it? Why not just make them shorter or lonf=ger from the get go seeing the control arm module you snap it on is loose anyways?
    Here's pics
    Instagram @ Thudux
  16. #136
    Junior Member Two Rings
    Apr 08 2018
    2013 A7 Prestige Ibis White
    AZ
    Hey everyone I just got my 034 lowering links today but I can't seem to find any information on the max amount of turns. I have seen every where the TGK ones are max 8 turns but nothing on the 034. Does anyone have any suggestions or information?
  17. #137
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Quote Originally Posted by chikmagnet View Post
    Yes its the same, max 4turns each end. Make sure you put your car in lift mode or you wont get any results. Ask me how I know.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
  18. #138
    Apr 08 2018
    AZ
    Installed last night
    So I got mine installed last night I had a few little hiccups that I had to deal with, but was able to get them on in about hour and a half. will say I am not super happy with the outcome though.
    I was hoping for a bit more drop. I installed 034 links, did 4 turns on each end.
    Sitting at 30“ all the way around. would like another half inch (TWSS).
    edit - for terrible grammar from text to speech
  19. #139
    May 03 2010
    2012 TT Sold
    Maine
    Hey folks,
    So I went to put 2021 SQ5 Premium Plus in Wheel change mode. Vehicle > Settings & Service > Air Suspension: Wheel change.
    Well it doesn't exist! Trying to upload video but its slow moving.
    any ideas?
    Thank you
    2002 A4 1.8T - sold
  20. #140
    Apr 08 2018
    AZ
    can you snap a pic of what you are seeing in the menu?
  21. #141
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Quote Originally Posted by A4Maine-iac View Post
    Hey folks,
    any ideas?
    Thank you
    What does this have to do with lowering links? There is a sticky thread specifically to ask random questions.
    iain
  22. #142
    May 03 2010
    2012 TT Sold
    Maine
    I am in the process of putting them on.
    Thanks
    2002 A4 1.8T - sold
  23. #143
    Junior Member One Ring
    Apr 12 2024
    East Lansing
    I think you're supposed to put the car in "wheel change mode" prior to uninstalling stock/installing lowering links?
  24. #144
    May 03 2010
    2012 TT Sold
    Maine
    Quote Originally Posted by hooligan74 View Post
    Exactly!
    2002 A4 1.8T - sold
  25. #145
    Apr 08 2011
    NoVA
    You do have air suspension, right?
    iain
  26. #146
    May 03 2010
    2012 TT Sold
    Maine
    I do, trying to upload video but not cooperating.
    Off-Road - Comfort - Dynamic ......
    2002 A4 1.8T - sold
  27. #147
    Apr 08 2018
    AZ
    it is in the service menu not drive select
  28. #148
    May 03 2010
    2012 TT Sold
    Maine
    Thank you..I was miss informed. All set.
    2002 A4 1.8T - sold
  29. #149
    Jan 30 2024
    Tampa, FL
    Lowering Links
    Has anyone used the ECS Tuning static lowering links that are red and yellow in color… says it will lower it 1.5” front and rear. I find no info on here… I just don’t wanna mess with adjusting a link.
  30. #150
    Established Member Two Rings FFM's Avatar
    Aug 29 2019
    Bellingham, WA
    I like the concept, but they should have opted for lower options I feel. I think most of us on links end up near the max low setting. Sell a preset 8 turn rod and I’m in 😜
    Current: R8 V8 6MT | B9 SQ5
  31. #151
    Jan 30 2024
    Tampa, FL
    Quote Originally Posted by FFM View Post
    So how many inches is Max versus the 1.5 inch that they preset? Only half an inch?
  32. #152
    Aug 24 2023
    San Antonio, TX
    Quote Originally Posted by Mythos_SQ590 View Post
    If the highlighted aren’t selected then it will cause errors.
    Preciate this info. Crawled underneath the car today to install my lowering links.
    The most tedious part is getting the oem link off of the plastic ball joints. Other than that, easy install.
  33. #153
    Mar 30 2022
    Virginia Beach, Va
    Soooo, anyone have any experience with the new IE LL?? Like the etching and quick adjustment option. Might swap my TGK LL for a set 🤷🏻*♂️
  34. #154
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Guys they're just lowering links, stop overthinking it and make your own for $30
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  35. #155
    Aug 21 2018
    WPB, FL
    I wish I would have seen this before installing the links. My car is now throwing the suspension and light codes among others. The rear is jacked way up. I may just go back to stock.
  36. #156
    Senior Member Two Rings Rare Ara S3's Avatar
    Jun 30 2020
    Michigan
    Quote Originally Posted by DC321 View Post
    Are you sure you didnt adjust them the wrong direction?
    Ara Blue 2019 RS3, Ultra Blue 2022 SQ5
  37. #157
    Aug 21 2018
    WPB, FL
    Quote Originally Posted by Rare Ara S3 View Post
    Yes. It was laying very low after install. Then I thought it was too low. I went from Dynamic to Comfort and thought it was perfect. THEN it threw the suspension and Light codes. Then it jacked up the rear of the car.
  38. #158
    Nov 27 2024
    Hawaii
    Also very curious about ECS’s options.
    Any brave souls try em yet?
  39. #159
    Jun 30 2020
    Michigan
    Did one or both pop off or a sensor break?
  40. #160
    Aug 19 2005
    07 A4 Avant S-line 6MT
    CNY
    Did you start with them at OE length and then adjust? How many turns?
    When I installed my CTS links I did 10 half turns shorter in the front and 12 half turns longer in the rear over stock lengths to get to 29.25" all around (dynamic).
    '21 SQ5 Ultra Blue
    past: B7 Avant 2.0t S-line Manual [CTS K04, 034 K04 Tune, Golf R intake cam, CTS HFC, Stasis Exhaust, BFI Snub, 034 Street Mounts, Apikol Race Diff Mount, Hotchkis 29mm RSB]
