Oh, I'm saying you can get them on eBay and Amazon and Aliwhatever if you search by the connector p/n. A lot of them will be preloaded with pigtail leads, and you'll see they are all China quickies. Audi doesn't source them that way, and TE doesn't produce them that way. But they'll work fine in most cases I would expect. My concern would be this is an "exterior" connector, and making sure the "single wire seals" are on the wires is something to confirm.
There's also the different pin systems, MQS 0.63, MCON 1.2, MCP 1.5, and they never say which pins they installed on these preloaded connectors. Not that Audi says what pins are used with a given connector in a given usage either. Most likely, they have the correct terminal type as I'm not sure how much variance the connector allows for pin type.
The parts catalog says half the harness connectors are 07P973702, with the yellow center. Google search that, and an interesting Amazon listing comes up.
https://www.amazon.com/Connector-07P...0D1KJZ6TY?th=1
Notice it has four variants, with and without wires, and clearly presents 702 vs 702A (the key slot is not in the same position). So be sure to get the non-A or it won't fit.
The other half have the black center connector, 4H0973702A. Same key slot under pin 1. But you'll notice the pins are turned 180° relative to the release tab. This is why half are one way, and half are the other way, so the right angle turns don't run into each other.
https://www.amazon.com/Connector-Rep.../dp/B0BW8PT4YM
So yeah, all over the place, just have to know the connector p/n to search by.
And the right angle cover is 8K0971921. I assume there's something about the cover that it can go on the connector only one way? Otherwise, why not just use the same connector for all eight.
Notice how the release tab is on different sides depending on if the right angle needs to turn left or right. All the solenoids are the same re pin 1 and 2. So to turn the release tab around, the connector pins have to be inverted so they still match the solenoid.
