For those that don't know this is an 2015 3.0TFSI Q5 APR STG2 93 with a 194mm crank pulley and stock upper with Berks (BG SQ5) TCU tune.
So without changing any of my mods I flashed over the APR STG2 93 with 034 Motorsports dynamic STg2 + 93 (thier dual pulley file). I haven't had a ton of seat time yet and I have no Dragy data yet so this is my initial review. 034 is every bit as refined as APR as far as all of the little nuances of the engine acting and feeling OEM level smooth. Now the biggest difference I noticed right out of the gate is the gas pedal sensitivity or lack there of with 034. On the APR tune the gas pedal was extremely responsive I have never used a pedal box before but I would have to imagine this is what a pedal box feels like. I could turn things up in a hurry without ever getting past the first 1/3rd of the pedal travel. Watching my Torque app with both APR and 034 the APR software was quick to close the bypass valve on any quick inputs to the pedal regardless of how deep the input was, causing vacuum to flip to boost and pushing you back in your seat. Even with no change of pedal position when transitioning to a incline my APR software would start closing the BP valve and move from vacuum to boost. With 034 there is definitely a reduction in vacuum so they are using some of the Supercharger to equalize the increased engine load but not as aggressively as the APR file.
To sum this up I was use to that very sensitive and very aggressive approach to the throttle input that the APR file provides. To me it was fun and made the Q easier to drive in part throttle situations. It also felt faster (APR) even though I haven't proven or disproven that yet with Dragy times or a 1/4 Mile pass so for now it's just the seat of the pants part throttle feeling I'm referring to. I'm 99% sure Audi does this same trick with the throttle calibration when switching between comfort mode and dynamic mode. If you guys have felt that then you know what I'm talking about.
If you have never driven a APR tuned 3.0TFSI then you will have no point of reference and this really won't effect you at all. Or maybe some people prefer the less sensitive pedal. I prefer the APR pedal feel over the 034.
I'm in this for the long haul now so I will be getting back to you guys with more impressions, observations and at some point some tangible data.
On the observations front It looks like my EGTs are down a bit with regular driving , this is probably because the 034 is keeping me out of the boost more so then APR but I really need more time behind the wheel and a nice highway run to confirm this one.
Sent from my SHT-W09 using Audizine mobile app
