Results 1 to 12 of 12
    Oct 15 2020
    Chicago, Illinois
    3.0 IE tune vs APR
    What do you guys think about IE vs APR for a tune on a a6 , I know APR have now lowered their prices making their tunes very tempting but I’ve also noticed they advertise higher horsepower numbers than IE but far lower torque figures . Now I can imagine in a car as big and heavy as the A6 torque is a big deal but is it worth the extra few hundred dollars plus $130 for the power link . Also I should mention IE has lower horsepower figures .
    Oct 02 2005
    The Moon
    HP claims are worthless as there are too many variables from dyno to dyno.
    034 and IE are the two best tunes period. The test against time is the only true way to measure absolute performance and those two are the fastest.
    With all that said APR is fine and unless pushing past stage 1 on 93 octane the difference is negligible. If you are going to go full stage 2 especially with E40 APR shouldn't be considered over the aforementioned companies.
    Veteran Member Three Rings silver3.8's Avatar
    Nov 13 2019
    DMV
    I don't have a 3.0 but I do have APR. I wish APR gave us the option to tune at home like IE does. I do like my APR tune and never had any other brand so I can't give you a comparison of the two. From what I gathered from these posts are, they both are good tunes but IE has the up bc of the at home tuning option.
    Probably not what your looking for but hope it helps a little.
    C7.5 A6 2.0T P+ S - Line:
    Performance :RRR Stg 3 (93 & E30), Mamba GTX 3071R, APR Intercooler, 034 HPFP, APR Coils, HVF TCU, GFB VTA, BMS Pedal Tuner, Injen CAI, Visican gauge, JHM HFC & DP and Cende's Valvetronic Exhaust, Improved Racing's Catch can and 034 dog bone insert.
    Appearance: RS6 front bumper, RS6 Honeycomb grille, Maxton design trunk lip, 19" Niche Rainer
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    I was waiting out IE’s crec (2016+) tunes last year but they never came, and to my knowledge are still not released. I went with APR instead and can say that I have zero regrets. 3.56 second 0-60 on single pulley 93 octane tune, not looking to break any records as this is my daily driver. Additionally apr seems the have the reputation as a “safe” tune across many vag platforms, to the extent that a safe tune is possible of course.
    For what it’s worth apr’s crec tunes show 404lb-ft and 477 HP for single pulley 93 octane whereas IE lists 423lb-ft and 435 HP for their tune. APR’s stock torque reading also shows 14ft-lbs less than IE’s (325 vs 339) so if you believe the advertised numbers that should be taken into account as a correction.
    At the end of the day there are so many variables with dyno results that the numbers are just marketing anyways. The numbers are more than likely within a margin of error that may or may not be measurable in the real world.
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by p3u View Post
    p3u makes a good point (no surprise) about ethanol. Apr has 100 and 104 octane tunes but nothing for ethanol. If you’re looking to run an ethanol blend there are better options for sure, especially if you have a 2015 or older.
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    running stage one from APR and couldn't be happier. I do have to say this though i did get a Melen TCU tune as APR shows it's numbers up the 7,400rpm redline and even though APR raises your redline there is no way you can get there without a TCU tune so you'll be leaving about 20hp on the table from what they are saying your gains will be and going to say same with any other tunes that raise redline and show you there HP numbers at an elevated redline
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Sep 16 2020
    West Michigan
    I am on APR, single pulley stage 2.
    I have been considering going dual pulley. Ethanol mixes seem like a hassle, so I plan to stay on 93.
    Otherwise it has been flawless. The car is a rocket.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Senior Member Two Rings E-SWIFT's Avatar
    May 07 2009
    TDI-Passat, M109
    philadelphia
    I'm I.E. Dual Pulley, and I LOVE IT !
    It's a blast to drive and I can tune from home.
    2014 A7 Garnet Red Pearl.
    Stop-tech slotted/drilled rotors F/R w/EBC ceramic Pads.
    I.E. Stage 2, Dual Pulley, JHM 187 mm Crank Pulley, Euro-code inserts
    RKX intake w/K&N filter. Eurocode Sway Bar Kit -F/R.,
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    IE STG2 DP+TB E40 and the cars is flat out stupid fast lol , even on 93 pulls like a train, walked a RS7 on 93 last week ;)
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Oct 02 2005
    The Moon
    Quote Originally Posted by ANMS4 View Post
    I thought you blew up your motor? Already back in action?
    Dec 18 2012
    Framingham MA
    Yes sir!
    It was replace under warranty (new audi block), I’ve had lit back three weeks now. 😎
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    I'm dual pulley (AWE upper/JHM 187 lower) and have been running GIAC dual pulley for about a year. This past week, I flashed JHMs Stg2 file and TCU file... WAY better than GIAC! Hands down. The top end just keeps pulling, where GIAC was "meh" on the top end. I actually broke all 4 tires loose today.
    I'm looking forward to their Stg3 file, when it's ready.
