Results 1 to 20 of 20
    Jan 13 2021
    Virginia
    DSG service price?
    Hi All,
    I just got home from my local Audi dealer. I called and made an appointment last week to get the dsg fluid changed. I was quoted 350. I get there today and they wanted 650. all of the local shops i called were somewhere around 350 - 400. Were they just quoting labor? Im genuinely confused here.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by 04lss View Post
    Hi All,
    $ 350 for DSG service at dealer seems extremely cheap, $ 650 definitely sounds more like it from them.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jan 13 2021
    Virginia
    I have access to a lift. Im going to take care of it myself. The question is, is there any reason i shouldnt use this kit from FCP https://www.fcpeuro.com/products/aud...ce-kit-39070kt the dealer was only going to change the cartridge filter. The only question i have is around the brand of the fluid. Any issues there? I also want to do my rear and center dif fluids at the same time. Im thinking motul 75w90 or the redline 75w90 or liquimolly fluids.
    Jul 02 2013
    I buy a lot from FCP, but the DSG service is one of the few things I have not ever attempted to DIY on my car. Here is a great AZ tutorial in case you haven't seen it: https://www.audizine.com/forum/showt...al-Service-DIY
    The Motul Diff 75w90 fluid appears to be popular choice, but I would think the other two are also acceptable.
    Jan 13 2021
    Virginia
    Thanks for the link! Ive watched a few videos on youtube from DAP and FCP on the service. It seems to be it just consists of opening a drain plug, emptying the fluid, using a pump to add new fluid, and changing the cartridge filter. It all seems fairly simple.
    - - - Updated - - -
    My big question is around the FEBI fluid, any worries there vs VW fluid?
    Jul 02 2013
    - - - Updated - - -
    No idea, but maybe someone with experience can chime in. For me, rule of thumb is: when in doubt, use OEM of anything.
    Deactivated Four Rings
    Jun 23 2011
    Don't let the dealer do it. They just drain the fluid and they do not touch the internal filter. Find a good shop and have them drop the pan and clean it all out and replace both the internal and external filters.
    Jan 13 2021
    Virginia
    Quote Originally Posted by Chris@EPL View Post
    Is there a big benefit to the internal filter? Im willing to tackle that myself. I'm pretty capable when working on cars. The only reason i was going to let audi do it was for the convenience, at 350, it was worth the cash to not have to touch it.
    Jun 23 2011
    To do the internal you need to remove the pan and drain the fluid so not worth doing it a second time.
    Jan 13 2021
    Virginia
    any concern with the FEBI fluids? This is the Kit id probably buy https://www.fcpeuro.com/products/aud...audi-vw-516089
    Senior Member Three Rings Iwantyourcar's Avatar
    Jul 14 2018
    2010 Audi S4, 2019 Jeep Grand Cherokee, 1994 Oldsmobile Bravada
    Indiana
    Full kit with install is around 500 at my shop.
    '10 S4 / Koni / JHM / 034 Motorsports / ST Suspension / ECS / CTS Turbo / Maxton Design / Polo / EPL / Rotiform / Podi / Brembo / Stoptech
    Jan 13 2021
    Virginia
    Quote Originally Posted by Iwantyourcar View Post
    Is that with the internal filter? The quotes I got were for just the canister filter.
    Jul 14 2018
    Indiana
    I’m a 2010. I only have internal filter. My external is a “lifetime” part.
    Jan 13 2021
    Virginia
    Im pretty set on doing it myself, my dad is letting me use the lift at the shop he works at. Hes also a master tech. A friend of mine mentioned something about VCDS to do the flush, i havent seen anything about that in the DIY guides. Any ideas?
    Im going to take the money i save by not paying the 350 to the dealer, and use it to replace the rear diff fluid, do an engine flush, refill with Liquimolly and a bottle of ceratec. if pricing works out, ill do the center diff too.
    Nov 01 2013
    Pennsylvania
    Vagcom is suggested so you can monitor the temperature of the fluid - once in range you shut the car off and top off the transmission.
    Word is you can get similar results using an infrared thermometer aimed at the pan but since I have vagcom I used it.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    I would not recommend changing the DSG fluid without VAGCOM. Bringing the tranny fluid to the proper temperature is key to ensuring you have the proper volume of fluid in the DSG.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Jan 13 2021
    Virginia
    I have access to a eurodyne cable and the logging software. Think that might get me what i need? Otherwise im sure i can get an infrared thermometer.
    I also have torque pro, and a friend has an OBD11, which is what DAP used in their DIY video.
    Jul 10 2019
    California
    I was in a similar situation as you 2 months ago. I had ordered the ECS liquimoly kit but just didn’t have the time to do it so I shopped around for quotes on labor only, got anywhere from $300-600.. so I decided to do it myself. It’s pretty easy, also helps if you have a pump (I used a manual pump) for filling and a power tool for all the torx screws on the tranny pan— these definitely made the job way faster. I used OBD11 with no problems as well
    Jan 13 2021
    Virginia
    Can someone explain the benefits of the internal filter change? Audi doesnt consider it neccesary so im curious what the advantage is.
    Nov 01 2013
    Pennsylvania
    I can’t speak to the benefits other than a clean filter but the extra work to do it seems trivial to me.
    You also get to drop the pan so you get a look at anything that might be there and you get a new gasket on it. The pan should already be empty and it’s 12 screws I think. There is an order to put them back in, tho, iirc. If you’re on a lift it probably costs you fifteen minutes to do including cleaning it.
