Originally Posted by
MugurMarius
Hello,
I would like the following:
1) put matrix headlights from B9.5
2) put tailights from B9.5
3) Engine change
For point 1 & 2, what pieces I need (besides the headlights/tailights) and if it can be achieved easily.
For point 3, I need to change my engine, I just replace without updating the cluster mileage (it's recommended to update the mileage to the new engine or just leave it like it was?). Do I need to update the ECU if I swap engine? It's the same engine (cwgd)
Thank you and sorry if I opened in the wrong thread.
So far I do not believe anyone has attempted the B9.5 headlights in a B9 model. I believe the issue you may find is body work will need to be changed as well, bumper, grille, etc. Then you have the challenge of getting the current Central Elec module to understand how to run them properly. With that said you can fit the B9 matrix lights:
Headlights | A5, S5, RS5 Matrix LED Retrofit Package <-Click for More Information
As for the taillights, the B9.5 taillights do fit the B9 body and there are full packages here:
Taillight Package | A5, S5, RS5 Post-Facelift LED (Highline) <-Click for More Information
There is a bit of wiring work that is needed and is recommended for installers to have experience in this type of work. Once installed, parameters set with VCP and proper coding done you get the full functionality, dual rear fog light and the animations like this:
As for changing out a motor, I don't believe anything change in a massive way between the B9 and B9.5. Same engine code and the pre-facelift long block supersedes to the post-facelift part number. I see no changes in the turbo, intercooler, etc. Probably mild revisions along the way but should be a direct swap.
Cheers,
