Results 1 to 21 of 21
    Junior Member One Ring
    Jun 16 2020
    Cowlitz County, WA
    2.0T Low Oil Pressure after limp mode
    I’ve been struggling to get my Audi out of limp mode (epc) and after replacing my fuel filter, high pressure fuel pump and cam follower it ran a little better but still wouldn’t get above 3k rpm. I had open circuits codes for the N75, fuel pressure regulator and evap system. I replaced the N75 and it didn’t change anything so then I realized it was truly an electric issue and turns out it was the 15 amp fuse inside the ecu that was blown.
    Upon replacing said fuse car started up instantly and sounded normal so I took it on a test drive and every time it would start to build boost I would hear a thunk or a bad noise coming from the turbo side and was persistent until it warmed up and went away. After about 30 mins into my test drive the “red oil can of death” popped up and I put a quart of oil while it was running and had a hard time taking off the oil cap??? That didn’t fix the pressure and ended up turning the car off 3 times within a mile to make it home, would turn it off immediately after the oil can turned back on.
    So I thought my previous issue was mechanical due to the cam follower being completely busted through and needed a new hpfp and intake cam(I have one sitting on the shelf waiting to install if needed) and I was aware of the fact that after all this my oil pump will go bad from all the metal but I’m not sure if that was even the problem so it still a possibility that’s what is causing my low pressure?
    If I do end up taking off the oil pan and dropping the subframe is it possible to clean it out and get it back to normal? I’ve been reading something about diesel but I have no idea what that does in terms of cleaning.
    I’m sorry for my format I’m trying to work on it lol.
    Feb 15 2016
    Cambridge,Ontario
    no offense but lets stay away from what you think right now and just stick with what you know ... " just the facts Ma'am , just the facts" <-- I may have just dated myself.
    okay from what i have read.
    1. you heard a noise coming from the turbo side of the motor
    2. red oil can light came on
    3. oil cap difficult to remove .
    so , not sure why you dumped a quart of oil in the car , what was the oil level like when you checked it ? did you just dump a quart in without checking oil level before or after ?
    oil cap difficult to remove ... yes there is significant vacuum at idle on the 2.0T . a lot more than on the 1.8, however the oil cap should NOT be difficult to remove. If you are pulling way to much vacuum in the cranckase it can in fact effect your oil pressure throwing low oil pressure warnings. If you have access to a vacuum gauge i would check to see what that vacuum is at idle through the dipstick. If you dont have the means to do that before doing anything i would consider the PCV assembly ( along with the breather tube ) Maybe someone can check theirs to give you a baseline ( my b7 is off site right now ).
    If the vacuum is fine or you replce the PCV ( with the correct version ) . Next step is to get an oil pressure gauge on your engine and lets see what the oil pressure is running... baby steps..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 16 2020
    Cowlitz County, WA
    Thank you I’ll try to not use I think. Is a PCV system something I can get from the junkyard or should I get a new one from ecs?
    Jun 16 2020
    Cowlitz County, WA
    And I was a tad low on oil before I poured in the quart and it brought me close to max hot. I’m not sure if the reading is supposed to be old or hot.
    Aug 18 2020
    Sonoma, CA
    Quote Originally Posted by Knavishmammal View Post
    Get a new one. OEM. Pelican Parts has them as does FCP and many other online retailers. Get a new gasket too. PCV is very easy to replace on these cars. What year is the car? There are two variations of pcv and they have to do with the check valve or lack there of in the breather tube. Make sure you get the proper one.
    Jun 16 2020
    Cowlitz County, WA
    Quote Originally Posted by tractoman View Post
    I have a 2007, is this the later or earlier model when looking for parts?
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Late model. Should have "P" revision PCV. But can check rear breather pipe, it should have a black check valve where it connects to the rubber hose(that connects to VC). If for some reason it don't, then get an "R" revision PCV. Always go genuine with the PCV. FCP has lifetime replacement, so only pay once.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Feb 15 2016
    Cambridge,Ontario
    If you get the later one get a new breather pipe too as it's the check valve that may be the issue.
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
    Jun 16 2020
    Cowlitz County, WA
    Thank you guys for all the advice :)
    After replacing my pcv should I still inspect the oil pick up with having a busted follower? I got a magnetic plug from ecs and am curious on how much metal is on it. I am towing the car on Monday to my parents and won’t be able to inspect much since I live in an apartment. It’s only 6 miles away but I don’t want to put more stress on it.
    Feb 15 2016
    Cambridge,Ontario
    That's a nightmare job. I would check oil pressure next after replacing pcv
    1976 Yamaha XS 360
    Jun 16 2020
    Cowlitz County, WA
    Is the best way to check the pressure with a mechanical gauge through the pressure switch?
    Aug 18 2020
    Sonoma, CA
    Yes, mechanical gauge connected where the switch goes, behind the oil cooler.
    Apr 20 2020
    '04 allroad 2.7T, '07 A4 2.0T qt, '10 A4 2.0T, '10 TT 2.0T qt, '02 Ford Ranger 3.0L.
    Chino, CA
    My bet is on the oil pressure switch being correct. Three of us investigated low oil pressure issues in recent months, none due to bad (cheap) pressure switch. We all had to at least remove the oil pan, clean/replace oil pickup or the entire oil pump. Get ready for that.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    Quote Originally Posted by mc_hotmail View Post
    We had an employee who purchased a B7 A4 that was having some oil pressure issues as well. Upon breakdown the pickup tube was partially clogged (with pieces of a follower from a previous failure the owner had fixed incorrectly), the oil pump assembly had seized, and the balance shaft sized up as well. Was quite the headache but he got the car for a steal.
    Hopefully OPs problem isn't as serious, but to wrap up the thought: I would also bet the oil pressure sensor is functioning and there is an underlying issue. Still worth confirming pressure with a mechanical gauge, but pulling the pan and doing a little digging wouldn't be a bad next step after that.
    Best of luck! Feel free to send me a PM if you need some parts pricing.
    There's another low oil pressure thread on the B7 forums here: https://www.audizine.com/forum/showt...pressure-issue
    Jun 16 2020
    Cowlitz County, WA
    Quote Originally Posted by XLR8 Craig View Post
    Sounds like I’m heading down the same road but I’m not sure if it’s seized up yet cause I can get it a couple blocks before it would throw the light and that’s my reasoning for wanting to inspect the pick up.
    Jan 21 2018
    frackville, pa US
    Thats only cuz pressure drops as oil heats up..
    Apr 20 2020
    Chino, CA
    ... cause I can get it a couple blocks before it would throw the light
    There is no coincidence here. That light comes on one time is one time too many. The 2nd and 3rd time just starving the engine of oil and grind down a bearing or journal somewhere or everywhere.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Another possibility is that the pressure relief valve in the pump is hanging up on a chunk of cam follower. For good oil pressure when hot it needs to be fully closed. It may have opened when the oil was cold and got hung up on some debris. When you pull the pan to inspect the pickup check to make sure the relief valve.
    Jun 16 2020
    Cowlitz County, WA
    So I finally got the car to my parents house and am kinda confused on where the sensor is. I have a feeling I’ve been looking at 1.8T diagrams... the only thing I can think that it is right behind the oil cooler, thing is size of my hand and right above the filter. Is that the sensor?
    Feb 15 2016
    Cambridge,Ontario
    you must have tiny hands...
    it bolts to the back of the oil filter housing towards the firewall and has a black connector.
    1976 Yamaha XS 360
    Account Terminated Four Rings
    Oct 15 2013
    Some sketchy advice here. Wow.
