Results 1 to 25 of 25
    Junior Member Two Rings
    Oct 19 2015
    GA
    Spark Plug Replacement
    It's time to replace my spark plugs and I haven't been able to find a lot of info for the B9's. I'm currently running APR stage 1. Is the general consensus to run OEM plugs (I haven't found anything else yet).
    Nov 23 2009
    NYC, US
    You have a 2018 model? I thought first plug change should be done at 60K miles.?
    Oct 19 2015
    GA
    Yes. I’ve made it a little past that already.
    Nov 23 2009
    NYC, US
    I see ECS Tuning is selling the APR coils for our car. But nothing for plugs. That’s odd. There should be other brands available other than factory version.
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    I haven’t even bothered to look but was wondering how hard is it to get to our plugs.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    Oct 19 2015
    GA
    Popping the engine cover off, all the coil packs are right there. Doesn’t look difficult at all.
    Apr 08 2019
    It’s a royal pain in the ass. The last gen was simple. There’s so much in the way. This is a job I prefer to just pay someone to do on this car
    Oct 31 2005
    Ashburn
    I found spark plugs on ECS tuning under B9 S4.
    - Instagram: @Sinister_rs5-
    Apr 05 2006
    992 c4s
    Blue Springs
    Quote Originally Posted by chawski View Post
    This information sucks. Lol
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    Oct 19 2015
    GA
    Did my plugs today. I’m not sure how the last gen was set. The B9 isn’t terrible. I used a write up from the other forums. The biggest thing was having the proper spark plug socket. Apparently a normal thin walled socket doesn’t fit.
    Apr 05 2006
    992 c4s
    Blue Springs
    Quote Originally Posted by Mynavi View Post
    What mileage did you change at?
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    Oct 19 2015
    GA
    I’m at 80k which is a bit beyond the interval.
    Junior Member One Ring
    Jan 18 2006
    central nj
    @Mynavi - can you elaborate? What type to spark plug socket do we need to change out B9 SQ5 spark plug? do you know where can we get the socket?
    Jun 26 2021
    2021 A5 Sportback, 2005 Sequoia
    Waukee, Iowa
    Apr 05 2006
    992 c4s
    Blue Springs
    Best tool for an Audi.
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    May 30 2020
    Orlando
    I recently swapped to Brisk Silver Racing ER12YS Spark Plugs and I’m happy with them. I’m also on APR Stage 1. Not a tremendous difference, but did actually notice better mpg off of them at highway speed.
    Jan 18 2006
    central nj
    anyone know what should be the spark plug gap?
    May 30 2020
    Orlando
    Quote Originally Posted by samnt650 View Post
    APR states .0024 +\- .0002
    May 30 2020
    Orlando
    Quote Originally Posted by Deven_A4 View Post
    Sorry, .024 +/- .002
    Apr 05 2006
    992 c4s
    Blue Springs
    I was told the ome’s are pre gapped.
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    Sep 29 2022
    Edmonton, Alberta
    Not too bad of a job, I went with upgraded 034Motorsport coils but stayed with OEM spark plugs (from RockAuto). 034 has a nice instruction write-up on this job on their website. I wound up taking the PCV valve hose off to access the driver’s side spark plug bank really made accessing the coil/plugs easier.
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    After removing and installing the spark plugs dozens of time to try and track down my misfires, I learned to do it without removing the PCV (which is a pain). You only really need to remove the intake on the passenger side, and unplug the ECU on the driver side to give you more room. From that point, you can access what you need to. It's so much easier and quicker this way.
    Established Member Two Rings kharma's Avatar
    Nov 10 2006
    Billerica MA
    Timely bump, I'm gonna need to start doing this myself after going TTE810.
    Sent from my Pixel 7a using Tapatalk
    Oct 14 2022
    US
    I'm coming up on my 40k service and will be replacing spark plugs per the recommended maintenance schedule. A few questions from a novice:
    1. Are there any benefits to "upgrading" to Brisk Racing 2MOR10S Silver Spark Plugs on a Stage 1 Tune, or is this only advisable on Stage 2+? 034 mentions "these plugs are one step colder versus oem - one step colder is typically recommended for Stage 2 tunes or higher" but also list that they are applicable for Stage 1 in the proceeding sentence. Is there any actual benefit, or do they just want to sell me some aftermarket plugs?
    2. What Plug Gap is advised? I've found three different answers.
      Quote Originally Posted by TheMysticWizard View Post
      034 advised me that the stock plugs should be gapped at .024-.030 with their Stage 2 file (I was also running E85 at the time) for my SQ5
      APR states .024 +\- .002
      034 mentions .024 +\- .001 for the Brisk application
    3. Should I be replacing plugs sooner than the recommended 40k intervals since the car is tuned?
    Thanks,
    Established Member Two Rings deviantspeed's Avatar
    Jun 24 2021
    '19 B9 A4 Krautgeist + Portche
    Quote Originally Posted by esssssss View Post
    Thanks,
    Do what they recommend. I have a different tune and usually do plugs about every 20k, but that's just me. Plugs are cheap and easy to access (2.0T).
    2019 A4 B9 on B8's - H&R - JB4 - Cat sticker - Shaved and chamfered hubs for 10mm hubcentric spacers - Bunch of other stuff (sold)
    2018 Q5 B9 PP, no cat sticker.
