Results 1 to 14 of 14
    Oct 30 2018
    Compatible G13 Coolant
    Im wearing my flame suit....
    In preparation for upgrading my heat exchanger, is there a good comparable coolant to OEM I can purchase from Amazon?
    Thanks
    Sent from my SM-A716U using Audizine Forum mobile app
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    Pentosin E
    Senior Member Three Rings no thx's Avatar
    Feb 26 2017
    DTW
    Quote Originally Posted by 430hps4 View Post
    Pentosin E
    +1 for Pentosin E (got mine from fcpeuro). And it's not premix so it's cheaper and you can mix as you want according To your climate
    Sent from my SM-G970U1 using Tapatalk
    Jul 31 2016
    PA
    Any reason not to just pick up some G13? I find at least around me the European stuff can be hard to come by.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Feb 26 2017
    DTW
    Pentosin is g13
    Feb 26 2017
    DTW
    It's on fcpeuro for the low
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    This is G13. Widely available.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Pentosin E
    100% I bought a bottle at my local AutoZone for next to nothing (like $5 on sale). Like other people have said because it's not pre-mix you can extend the bottle for a long time.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Senior Member Two Rings 6SpeedS4's Avatar
    Dec 19 2018
    2016 Audi S4 w/ APR Stage 1 /IE Intake / IE non-res downpipes / AWE Touring / ECS SS Clutch line / M
    Pittsburgh, PA
    Quote Originally Posted by MSq5 View Post
    What's the difference between the pink and the purple ? The purple showing Audi as well.
    Sent from my SM-N975U using Tapatalk
    2016 Audi S4 PP / Sport Diff / 6 speed / APR Stage 1 93 Octane / IE Downpipes / IE Intake / AWE Touring / Canyon strut bar / 034 Rear Subframe Mount / ECS Tran Mount / ECS SS Clutch Line / Merc heat exchanger
    2014 Audi SQ5 Prestige / IE Stage 1 91 Octane
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by 6SpeedS4 View Post
    Pink is silicate free. Actually G12+. Purple is silicate enhanced. g13. Both work in our cars. Purple is supposed to last longer - up to 150,000 miles. It is a little more environmental friendly, but perhaps not quite as efficient in cooling. Or, that is my understanding.
    Mar 07 2020
    Minnesota
    That's interesting ... I thought all coolants were now silicate free to prevent/reduce impeller wear.
    Apr 24 2017
    Hilton, NY
    Just a heads up with coolant, you can always go up higher grades of "G" coolant but cannot go down when topping off/adding a partial amount. So if your car came with G13, you should not/cannot put G12 in it. Also I would not mix different grades if you are going up, stick to what is in there unless your flushing the whole system.
    Jul 31 2016
    PA
    Quote Originally Posted by choppstixxx View Post
    Edit: I read this wrong at first but figured it out. Either way this should help clear up compatibility hopefully.
    Jan 01 2018
    2021 Q5; 2003 F250
    Southeast PA
    A new coolant was introduced in MY 2019. It's G12evo, Audi RTU PN: G-12E-050-1G-DSP.
    Except for the e-tron, it can be mixed with G11, G12, G12+, G12++, and G13, but it will cause a reduction in corrosion protection.
    e-tron requires G12evo and can't be mixed with others.
    Sent from my SM-G981V using Audizine Forum mobile app
