Results 1 to 9 of 9
    Jan 24 2021
    Denmarj
    Speedometer not working and odometer not working and no ABS lights on. RPM works
    Hello i bought a audi a4 2002 some months ago and I can't figure out why my speedometer and odometer dont work what could be wrong?
    Pls help me
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Could be bad wiring, a bad sensor, or bad module. In 2002, you may have a speed sensor in in the transmission, or it could be using the wheel speed sensor. If it's using the wheel speed sensor, it could be the ABS module itself.
    Sent from my Pixel 5
    Jan 24 2021
    Denmarj
    I'm confused between engine speed sensor and transmission speed sensor. What's the difference?
    Where is the transmission speed sensor?
    Jan 24 2021
    Denmarj
    How do I know if I use wheel speed sensor or transmission speed sensor?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    If you have this plug above your drivers side drive axle you are using the ABS sensor. If there is a sensor here you are using the VSS (vehicle speed sensor).
    Veteran Member Three Rings SoundEfx's Avatar
    Aug 29 2017
    2000 S4 - 2001 S4 - 2003 RS6
    PNW
    Hope I can thread jack a little. I have the sensor above the axle but can't for the life of me find the wire that suppose to go to it.
    I have two manual harnesses and none of them have that connector.
    Dec 28 2006
    Western Maryland
    You probably have harnesses from a 2003+ A4 that utilizes the front left ABS sensor.
    This thread may help: Clicky clickŪ
    Aug 29 2017
    PNW
    Thanks.
    IF the car starts this weekend, I'll know what works and what doesn't.
    Jan 24 2010
    Paramus,NJ USA
    IIRC correctly only 2002 had a VSS. Did not use ABS for speed reading. It can be changed to read speed from ABS module without any hardware change or wiring. However does require to some specialized tools and being able to read and write flash files to instrument cluster.
    You would need to backup your cluster, encrypted and decrypted flash files and then look at the physical flash address at 0x33A changing from 21 to 31. Most of the time Once Changed the speedo should come to life. It is not my fault if you brick your cluster for not following directions. If you are not capable then leave it to the professionals.
    Ziddy Autowerks
