While I've been fooling around with my suspension and power steering refresh, I tried installing an air dam on the passenger side between the auxiliary radiator and the stock airbox.
I have a cold air intake waiting to get installed, but I've often heard that the waste heat from the passenger side aux rad effectively negates the cold air intake attempts to snort "cold" (let's be honest - it's
ambient air) air and could actually make it worse as it gets the hot air coming from the back of the aux rad.
While I had the suspension components out, it gave me an opportunity to have a look at what's happening in that area of the engine bay. It appears that the fender liner causes a diverting effect that routes the hot air coming from the aux rad up to the airbox. Well obviously that's a bad idea. I am betting that if I can re-route that hot air, I can keep the aux rad in place and hopefully manage those intake air temps a bit more and maybe a CAI will work as intended.
Here's an image of the concept I'm trying out:
The yellow is the airbox, the green is the aux rad, and the blue is the air dam. The red arrow is that hotttt Arizona desert air.
Heat soak I'm attempting to deal with by utilizing reflective foil and insulation combined with Typhoon-class fans (Vasili, one ping only, please). But hot air, while moving, I can hopefully divert away from the air box.
First thing I did was remove the SAI pump. I already have it tuned out (Jackal), so it's just dead weight and in the way, tucked right behind the aux rad. Side note: I didn't want to figure out how to remove the SAI tube and put in the JHM block-off plates, so I left the metal tube in place and just fabricated a little plug for it with a short length of hose and a cap. I'll let you know if I get any codes or shart out a plug from the exhaust.
Next I cut out an air dam from some
DEI Form-A-Barrier and squeezed it in there. I made a test piece out of cardboard to figure out where to make the openings for the coolant lines, refrigerant lines, and wire harnesses going through that area. I still have it if anyone wants a copy for a template.
Looking down at it, before I put aluminum tape on it to seal it up:
Looking up from underneath and behind the aux rad:
The air dam blocks off the space between the top of the aux rad and the bottom of the airbox. It also wraps down the side a bit, but not 100% (I may do that if needed). I still needed to provide access to those 10mm nuts that hold the bumper on. Mashing it in there is a little fussy, but it fits nicely.
Last, I cut out a section of the fender liner to provide and outlet for the hot air from the aux rad. This will allow the hot air to exit the engine bay and not blow up to the airbox anymore. I got some perforated metal I had and riveted it to the liner. It's on pretty firmly. It oughta work.
Here's the fender liner opening from the interior, looking toward the back of the car:
The car isn't off the jackstands yet, so I'll report in with whatever IAT results I get reported from my VFIZ.
