Results 1 to 24 of 24
    Senior Member Two Rings 1SICRS4's Avatar
    Sep 10 2013
    Lincoln, Ne
    The dreaded B8.5 electronic steering issue *solution?*
    I am now experiencing this issue on my 2013. Disabled DSR with minimal effect. What's odd to me is how little info there is based on how common this issue seems. I'm still unclear about the revisions made to the racks. Were the revisions made to the rack construction or the module? Can the module be replaced without replacing the entire rack? WTF is the actual solution for this issue? I dread the thought of having to pay $2,500 for a new rack if the issue can be solved with a simple software update.
    2013 Prestige DSG S4 | APR Dual pulley+TCU | Forge Motorsports Charge Cooler | RocEuro Intake | JHM Baffled DPs | AWE Touring | Vogtlandsprings Coilovers | 034 Control arms | 034 Engine + Drivetrain mounts | 034 Rear Sway Bar
    Dec 10 2012
    1983 Honda CB1000 Custom
    granville ohio
    I have this problem intermittently and have not seen a clear explanation of the root cause. I have living with it for years, but have a technique that solves it for me. When I back out of my garage, I make sure to take the steering to full stop before I pull away forward. My theory is that this re-calibrates dead center, but who knows? You can also take it to full stop while moving forward.
    2013 S4 Premium Plus, 6MT, Brilliant Black, Sport Diff, Red & Black Leather, B&O, APR Stage 1, AWE S-flo
    Sep 10 2013
    Lincoln, Ne
    Per OBD11
    Hardware number: 8K0909144B
    Hardware version: H36
    Software number: 8K0909144F
    Does anyone know if this is the most up to date revision?
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Quote Originally Posted by 1SICRS4 View Post
    Per OBD11
    That software number denotes that it already has the 48K8 software update installed. So you won't have luck there. What issue are you having exactly? On mine the wheel would feel like it was being pushed back and forth by magnets when trying to hold it in the 12 o'clock position. The steering lock trick would help sometimes. I ended up watching this (or here if you don't have dynamic steering) website for a remanufactured rack to come in stock and jumped on it when one came in. I haven't had a problem since swapping the rack. You can always find coupon codes for BuyAutoParts. They also add the option at checkout to upgrade to a lifetime warranty. I ended up getting my rack for $860 shipped. They also sell new OEM racks for $1600. You can see my original thread here.
    As far as the module/rack debate goes. I think most just spring for the entire rack because the modules are more difficult to track down and it's not a surefire way to rectify the issue.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Sep 10 2013
    Lincoln, Ne
    Quote Originally Posted by agentsmith988 View Post
    How are you able to tell that the software number has the update? Is there a listing of software versions and their corresponding update? If so I'd like to know where I can find that for future reference. I'm experiencing two issues. The 12 o'clock position issue. The car seems like it constantly requires small corrections to stay tracked, but once the corrections are made it seems like an overcorrection; hence, needing to be corrected again and again. Then there's the feeling of being pulled into every rut or uneven surface on the road. Its as if the car automatically tracks itself into the shitty road condition.
    Fry Sauce, UT
    Local dealer looked up the software version correlation for me when I was diagnosing my own rack. Surprising that they didn't disable DSR at the same time the software was updated in your situation though (for me the update was applied and DSR was disabled at the same time). May be worth checking to see if the update was applied properly.
    - Steve
    NKAWTG
    Established Member Two Rings DriveBikeRun's Avatar
    Dec 15 2018
    2014 Honda Odyssey, LOL
    Louisville, KY
    Just adding my experience FWIW. I have a 2013 and had the issue where it needed nearly constant steering correction when going straight at highway speeds. As far as tracking into ruts or uneven pavement, I never noticed that being worse than other cars. I disabled DSR first which helped some, then replaced the subframe brace with the X-brace from 034. I’ve been happy ever since. As for allocation of the benefit, I would say it was close to a 50/50 split between disabling DSR and the X-brace. I never had the feeling of magnets pulling the steering wheel like agentsmith988 describes, though. It was more subtle than that.
    Sep 10 2013
    Lincoln, Ne
    By VIN?
    Fry Sauce, UT
    By VIN?
    Yes they had it on record with my VIN and also said that the software number 8K0909144F linked up with having 48K8 flashed (not really sure how true this is so take it with a grain of salt).
    - Steve
    NKAWTG
    Sep 10 2013
    Lincoln, Ne
    Quote Originally Posted by DriveBikeRun View Post
    You don't seem to be the only one. I've read of x braces and strut tower brace "fixes". These only seem like bandaids for a more serious underlying issue. Truth since it's known that Audi has released at least one TSB for this issue, and others have reported the issue vanishes once they upgrade to a new rack (which I'd assume also has more current software. I refuse to add additional aftermarket hardware as a bandaid in an attempt to get the car to perform as it should have from the factory.
    Fry Sauce, UT
    I agree with your "band-aid fix" mentality. I didn't want to just mask a fault.. I wanted it fixed.
    Here's a video I found back when I was troubleshooting my own issue that goes over the many issues that can crop up on this rack style. The rack I received from BuyAutoParts had a few tags on it written in German and featured the MSG logo.
    - Steve
    NKAWTG
    Sep 10 2013
    Lincoln, Ne
    Yeah, I came across this yesterday while I was trying to get more info. I called Audi service and parts this morning and asked them what the most current part number is for the rack and control module. Per that conversation the most current rack part number is: 8K1423055AN and the most current control module part number is:8K0909144Q
    Sep 10 2013
    Lincoln, Ne
    Except they weren't able to tell me if that was for vehicles with or without dynamic steering, so basically useless. Also for what I can see when I Google that part number, it isn't a dynamic rack.
    Sep 10 2013
    Lincoln, Ne
    The shop checked the software which is up to date. They believe what I'm experiencing has to do with the intermediate shaft, though they don't see any physical damage to it. They also do not see any damage to the rack itself. They recommend replacing the intermediate shaft. Per Audi they say that the most recent part number for the rack is 8K1423055AN searched by my VIN, except that part number doesn't appear to be compatible with cars having dynamic steering. What I'm seeing is that the part number for vehicles with dynamic steering is 8K1423055AQ.
    Fry Sauce, UT
    You are correct. You need 8K1423055AQ if you have dynamic steering.
    I started out trying to clean and lubricate my intermediate shaft when I was diagnosing my rack. You can easily remove it and inspect it by moving it around to see if it's binding at all.
    You're most likely not going to see external defects on the rack itself. Most of the issues are caused by water ingress. You'd have to remove the control module/tear down the rack to actually inspect it.
    - Steve
    NKAWTG
    Sep 10 2013
    Lincoln, Ne
    Picked my car up from the shop yesterday after they replaced the intermediate shaft, retorqued suspension components, and completed an alignment. The car does feel stiffer overall, however, it did not entirely eliminate the issues I've been having. Movement off of the 12 o'clock position and tracking off course are still noticeable. My shop does not believe that the replacement of the rack will eliminate those issues. It seems like everyone else who's experienced this and has replaced their rack no longer has these issues. My conundrum now is, do I spend roughly $3k to replace a part that my shop doesn't believe will resolve anything?
    Fry Sauce, UT
    If it doesn't bother you that much right now you could always have BuyAutoParts notify you when a remanufactured rack comes in stock. With a coupon code (they always seem to have one available) you can keep the rack price under $900.
    - Steve
    NKAWTG
    Veteran Member Four Rings hunter_killer's Avatar
    Mar 25 2020
    Mandan, North Dakota
    At what mileage have you guys seen this issue arise? I’ve noticed a lot more sloppy steering when going down the road ever since I got new tires installed. I’m at 101k miles but just had tires done 1k miles ago. Seems like an odd coincidence, but I never had this prior. It wants to wonder sometimes, some times it takes barely any movement in the wheel to make the car go left or right, and sometimes it feels like it’s sitting on a high point directly straight on the steering wheel and I’m driving with magnets on either side pushing me (as stated previously).
    2013 Quartz Gray S6: APR Stage 1 and CTS intakes.
    Gone: 2013 S4 Stage 2. RIP.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by hunter_killer View Post
    My rack the bed right under 100k miles. Started making noise and then I got a dynamic steering fault warning.
    2007 Porsche Cayman | 5MT
    Mar 25 2020
    Quote Originally Posted by Ashtonts View Post
    I don’t have any noise nor a fault light but I won’t hold my breath on either of those not popping up.
    Sep 10 2013
    Lincoln, Ne
    The issue is that no one is able to tell me the appropriate part # for the car. When Audi runs the VIN # they're showing that my car should use the rack without dynamic steering. I called Audi North America and asked for a build sheet for the car. They told me that they don't offer build sheets for cars 2014 or older.
    Sep 10 2013
    Lincoln, Ne
    When they complete an update with ODIS I believe it sends a notification to their central server where information pertaining to that VIN # s is stored. This is what I've heard.
    Fry Sauce, UT
    This is correct. But I've seen info come back from the mothership through ODIS that was just about as reliable as VAG's VIN/part number database.
    As someone that has physically swapped out their own rack and has dynamic steering... 8K1423055AQ is the correct part number. Sounds like you just need to find out if you have a dynamic rack or not.
    When you change the steering option in ADS between Comfort, Auto, and Dynamic can you feel the ratio change? I can definitely feel a difference between Comfort and Dynamic with my rack. Especially at parking lot speeds.
    I also believe that the ADS screen will differentiate between Dynamic Steering and Steering as seen here:
    - Steve
    NKAWTG
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    To add info to this ...
    I have a 2014 S4 - and the proper replacement DYNAMIC rack for my VIN split is 8k1423055an
    It does continue a different component module named RCevo instead of RCEPS. So it requires ODIS to do a SVM entry of XCHG44A001
    Programs up and functioning as it should!
    Lurker
