Results 1 to 28 of 28
    Established Member Two Rings csaba.meszaros's Avatar
    Apr 11 2017
    '16 Audi RS7
    Debrecen Hungary
    Lightbulb Air suspension failure / replacement parts
    Dear Members,
    Looks like my '16 Audi RS7 has some problems with the air suspension. There is some construction going on in the yard and the car sat in the garage for like 5 days, I've observed that the rear left got deflated, the tires are now behind the fender for that corner. The other corners seem to be fine. Checked with VCDS, there are no codes for the suspension, just the one that is being triggered when you activate tire change mode from the MMI, I've changed to winter tires in December. When I open the doors, the compressor brings that corner as well to level.
    I suspect one of the struts has a leak, most likely the rear left. I have a few questions for those who already did this repair:
    1.) Is it safe to change just the rear-left or is it recommended to change them in pair?
    2.) Is the air suspension of the RS7 different than the A7/S7? Stiffer or something.
    3.) Looks like Dunlop is producing an aftermarket replacement at a fair price, some say it's better than OEM, is it safe to use that on an RS7? I would change both at the rear if I go aftermarket.
    Thanks a lot!
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    If you cannot check yourself, I'd have someone look at it.
    It might not be the air spring at all, could be a leak in the air lines or at the valve block in the trunk.
    I also say air spring because in the rear the air spring and shock are separate unlike the front where it is one complete strut.
    As a side note the S7 and RS7 rear air springs do appear to be the same.
    Left 4G0616001AA
    I think the RS7 suspension tuning difference is done in software with the electronics for the shock and they are different parts.
    S7 4G0616031AE
    RS7 4G0616031AF
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 30 2018
    long island
    mileage on the car?
    Its typically recommended to replace them in pairs. If you happen to have a very low mileage car, im sure you can replace just one.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Apr 11 2017
    '16 Audi RS7
    Debrecen Hungary
    I have 63k KM ~ 40k miles. I've contacted a company specialized in air suspensions and they've recommended a new enforced product from LuftMaster-Dunlop. Will change them in pair and will send them the factory components for a rebuild.
    They look a bit different than the original ones which bother me, but they've ensured it's just the dust protection that's missing which is anyway not needed due to the location of the air suspension ( inside an aluminum housing). They offer 2 years of warranty.
    Apr 11 2017
    '16 Audi RS7
    Debrecen Hungary
    After changing both air suspensions in the back, the rear-left is still losing air somewhere about a centimeter every two days. Which are the common leaking points we should check?
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by csaba.meszaros View Post
    I don't know if there are any "common leaking points"...anywhere there is an air line or connection maybe???
    "It might not be the air spring at all, could be a leak in the air lines or at the valve block in the trunk."
    Did your mechanic diagnose the rear air springs were faulty before replacing them or just took a shot in the dark and is now finding out they were not the issue?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Established Member Two Rings T00fast's Avatar
    Apr 19 2020
    Omaha, Ne
    My issue was a leaking left front air spring which was triggering VCDS codes for the ride height sensor, ACC being disable because of uneven right height. What was confusing me was the code said 'Mechanical failure of the sensor' My first purchase was an ebay ride height sensor in which the code eventually came back. I ended up just getting one air spring and it fixed my issue after recalibrating the air suspension, I look at it if the older air spring holds air and there's no codes, might as well let the other one go as long as possible. Ended up going with the remanufactured Arnott springs from AutoHausAZ.
    I can't speak for the rears, but have you sprayed soapy water at the fittings where the air line goes into the rear bag? Did you replace the brass air fitting? Also spray the air distribution block with soapy water in the trunk too. You could just gamble and replace the valve block. Theres ebay ones out there for cheap, the OEM one is is around 350 bucks.
    Good luck.
    Dec 09 2020
    San Francisco, CA
    Quote Originally Posted by T00fast View Post
    Good luck.
    I have a 2013 Audi S6 and after 2 days or more the front drops way over the front tires. I have quite a few miles on my car. Do you guys think it's the front air struts? Also the passenger side sits about 1/4 to 1/2 lower. Thinking on replacing both struts since they have high mileage already anyways.
    Apr 11 2017
    '16 Audi RS7
    Debrecen Hungary
    Quote Originally Posted by gk1 View Post
    From my research, air spring fault was obvious in my case so I've decided to source the parts from somewhere else and just ask the mechanic to replace them. I must admit I've failed. I will check the valve block in the trunk.
    Apr 11 2017
    '16 Audi RS7
    Debrecen Hungary
    Damn, it was a loose-fitting in the valve block. Sprayed some pre-wash liquid on it and it was bubbling at the base between the housing and the fitting. Tightened it up until I felt confident I am not going to screw the plastic thread, sprayed again, bubbling is gone.
    Mar 30 2018
    long island
    expensive assumption on your part to replace the struts.
    If you still have your old ones, at least you have working spares.
    Dec 09 2020
    San Francisco, CA
    Will some soap and water in a spray bottle work to check for air leaks around the connections? Also is it possible to get rebuilt air struts over getting new ones?
    Apr 11 2017
    '16 Audi RS7
    Debrecen Hungary
    Quote Originally Posted by AudiTurbo4me777 View Post
    Yes, soapy water also works fine. I just had the pre-wash liquid dissolved in the garage and prepared for a wash. Front struts can be rebuilt but this takes time and very few shops will keep your car on the jack while the rebuilt is ready. Try to trade in your OEM struts and get some rebuilt OEMs, we have shops specialized in this in the EU. As for the back, I've just replaced them for 400$ with labor included. After one night, I've measured the ride height is still the same, so the leak is gone. Problem solved. GK1 let me know where I can send the beers. Thanks!
    Dec 09 2020
    San Francisco, CA
    Alright, will keep everyone posted as to what I find soon as I get the chance to do it. I'm thinking mine would also be leak in the block in the trunk but mine takes about 2 days or more for the whole front to bottom out.
    Apr 19 2020
    Omaha, Ne
    Yes, Look at Arnott Industries. I replaced one of my fronts... Took me an hour with my quick jacks. Each front was like 450 + 250 dollar core from AutohausAZ
    Dec 09 2020
    San Francisco, CA
    Alright, I will check about those air struts, thanks.
    Dec 09 2020
    San Francisco, CA
    Does anyone know the location of the air compressor for a 2013 Audi S6? Can you actually hear it working when it's on?
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    It's in the trunk, under the carpet, around the spare tire
    Senior Member Three Rings GlacierS5's Avatar
    Jul 27 2017
    San Jose, CA.
    This one is from a RS7 in the spare tire area circled in red. 20210104_121406.jpg
    Sent from my SM-G975U using Audizine mobile app
    2018 Glacier White S5 | Prestige | Sports Pkg | Dynamic Steering | Carbon Fiber Pkg | 034 Motorsports Parts
    2016 Sepang Blue RS7 | Prestige | SRM Intake |EuroCode Sways
    2014 Glacier White S6 - SOLD
    Aug 06 2014
    NJ->CO
    That is the solenoid valve block.
    The compressor is under the car by the rear sway bar.
    In this pic it is under the black cover in the middle by the spare tire well.
    Here is what it looks like.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    thanks for starting this thread. I was looking to fix my front sagging suspension. It started after an unusually cold freeze spell in Houston. The front driver's bag was hissing, and instead of jumping in and replacing the air strut, i did the soapy water and found the air line connection was hissing, and it was a cheap O ring that was worn. Fingers crossed, but now the car is at a good height for > 5 hours. (2015 s6, 58k miles)
    Dec 09 2020
    San Francisco, CA
    Quote Originally Posted by GlacierS5 View Post
    I checked the block with soapy water spray bottle and no leaks there.
    Aug 09 2011
    Brooklyn, NY
    did u lode adaptive dampening? n get air suspension error codes?
    '16 Audi S6 4.0TT Eurocharged ECU - Current
    '12 Audi A6 3.0T Prestige - 187/57 DP Eurocharged ECU /TCU - Trade
    '06 Audi A6 3.2 Prestige - Sold
    '00 VW Jetta VR6 - Donated
    '98 Audi A4 Stage 3 - Gone
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Tevien View Post
    Where are these valves located in the car? Having the same issue. Thanks
    Not sure what you're asking. Post #19 in this thread has a picture of the compressor in the trunk, under the spare tire.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Junior Member One Ring Tevien's Avatar
    Nov 06 2018
    Houston
    Quote Originally Posted by Alabama View Post
    Yeah, noticed that as soon as I posted. Thanks.
    Jun 05 2021
    2018 Audi Q5
    Springfield, Massachusetts
    Hey thanks for posting this issue it helped me find out mine is bubbling on one of the lines that's going into the metal part of the trunk. I assume that's where the compressor is. It's at the brass fitting where the blue hose comes out of it. Can that line be replaced or easily taken off to see if it's an o-ring or something bad. Thanks
    Jun 05 2021
    2018 Audi Q5
    [QUOTE=Reece6776;14872535]Hey thanks for posting this issue it helped me find out mine is bubbling on one of the lines that's going into the metal part of the trunk. I assume that's where the compressor is. It's at the brass fitting where the blue hose comes out of it. Can that line be replaced or easily taken off to see if it's an o-ring or something bad. Thanks
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by Reece6776 View Post
    That aluminum part in the trunk is the air tank/reservoir.
    18 S6
