Results 1 to 16 of 16
    Established Member Two Rings Betq's Avatar
    May 08 2018
    So Cal
    How to Disable Range Control?
    I recently purchased b8.5 ecode headlights and when plugging everything in, I'm receiving faults saying auto-level circuit is open.
    The dash says the auto level is defective.
    I manually adjusted the lights and I don't care much about range control...
    Does anyone know how I can disable it by long code or any other method? These lights look amazing but the constant reminder that it's defective is getting on my nerves.
    Veteran Member Three Rings 3.0ss's Avatar
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    Quote Originally Posted by Betq View Post
    Did you try clearing codes first? I just had a "Headlight range control defective" code stick when I ran the car with the lights unplugged, that fixed it for me.
    2010 S4 Prestige 6MT - Brilliant Red | 034 Stage 2 | 034 190mm | Merc HX | Milltek Resonated Exhaust | Gutted/Reinforced Cats | S34 Intake | JXB Short Shifter Kit | AG M580's | Bilstein B8s | H&R Sport Springs
    2018 Q7 Prestige - Orca Black/Cedar Brown Valcona | Luxury Pack | Driver Assistance Pack | Cold Weather Pack | Towing Pack
    2014 Q5 P+ - Lava Gray Pearl | 3.0T | B&O | MMI+
    May 08 2018
    So Cal
    Yea... unfortunately it popped right back up after :/
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    Strange.. I had to clear codes twice for mine to go away maybe try clearing them again? Or try unplugging them and plug them back in?
    Jul 16 2018
    Atlanta
    Are they Audi headlamps or third party generics? Because the wiring at the headlamp plug to the V48 motor is the same for US vs. EU and for B8.0 vs B8.5 in that regard. Pins 1, 2, 3, and 4 on the 14-pin plug. Assuming you got the correct ones for PR 8Q3 (HID) vs PR 8Q5 (HID w/ AFS).
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Have you tried running the Basic Setting for headlight adjustment to see if it can re-learn the home position and upper/lower limits? VCDS instructions are here.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    Quote Originally Posted by agentsmith988 View Post
    Didn't know about this one. My projectors used to point down then up to their normal position every time I started the car but ever since I swapped in some upgraded projectors(non AFS) they no longer do the down/up movement. I've got a VCDS rental for the next 7 days, could this potentially fix that?
    Jul 16 2018
    Atlanta
    Well, the problem is your fault code is about open circuit, not about no or incorrect basic setting (at least based on your opening post).
    Performing the basic setting for the headlamps is "prepare car (on level surface, fuel tank full or almost full, driver or equivalent weight in the driver's seat), start process, manually aim headlamps to correct orientation (1% down angle from level), then complete process". This tells the range control module "this is level", reading the level sensors on the suspension during the process. The movement of the lamps at car start is just the diagnostic performed at each startup.
    Perform a full vehicle autoscan and post the log here so the actual DTC(s) can be seen.
    May 08 2018
    So Cal
    Headlights should be OE, came in a Magneti Marelli box and has the Automotive Lighting sticker on both headlights, here's the listing that I purchased them from https://www.ebay.com/itm/Headlight-R...72.m2749.l2649.
    I try the basic setting adjustment and scan/post the logs once the car gets back from the shop unless they fix the issue while it's there
    Also didn't notice this 2nd bulb exposed in the headlight until they were installed, does anyone happen to know what their function is?
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    Looks like a cornering light to me... maybe works with AFS?
    Jul 31 2016
    PA
    Did you get AFS lights for a non AFS car?
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by 3.0ss View Post
    This is correct. That bulb is for your cornering light and will come on when you turn the wheels based on a module that reads speed and turn input angle.
    Does OP have AFS?
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    May 08 2018
    So Cal
    It's a B8.5 premium plus no AFS, headlight listing says it was for vehicles with automatic headlight leveling and no mention of AFS. It did mention it has "with bend light", so it could be for non AFS optioned with cornering lights?
    Oct 23 2014
    Buffalo, NY
    No.
    °2011 A4 | 6MT
    Jul 16 2018
    Atlanta
    Cornering light, bending light, these are terms synonymous with AFS. So you have a PR 8Q5 headlamp on a PR 8Q3 car, which means the leveling and swivel motor pins are not matching.
    PR 8Q3 uses pins 1-4 for the V48/V49 tilt motors. These wires come from the J431 control module in B8.0 or from the J519 in the B8.5.
    PR 8Q5 uses pins 1-2 for control, pin 4 for power from a fuse (panel C, column 1, fuse 7 and fuse 6), and pin 14 for ground for the J667/J668 modules on the headlamps that control the V48/V49 tilt motors and the V318/V319 swivel motors. And the 1-2 control lines come from either a J745 control module in a B8.0 or the J519 in a B8.5. In a B8.5, maybe a little wiring and some recoding and you could enable AFS to make use of the headlamps without error. But you need a different headlamp range control module and additional wiring to do AFS in a B8.0.
    As for range control, the point is for the benefit of the people you're blinding, not for your benefit.
    Jul 31 2016
    PA
    As stated above, you bought the wrong lights for your car, see if you can trade those back to them. Otherwise you will likely need to code out the auto-levelling stuff at all and make sure you aim them properly.
