So I noticed a slight exhaust leak on the passenger side recently and read up on how to get the cat out to replace what I thought was just a gasket leak. Had it apart over the summer when I did my timing chains so I thought that maybe it came loose at the flange with heat cycles. Well that slight leak turned into a huge leak last night. Tore it down today to find that the flange broke off the converter at the exhaust manifold.
Build date was August 2012 for the car and it now has 206,000 miles on it.
That will certainly make tear down easier but now instead of a gasket it’s a cat replacement. Debating on replacement or repair at this point although leaning towards replacement. Looks like I can source an aftermarket stock style for just under $400. Still debating on repair or replace.
Thoughts?
