The swap/build is taking place at Sittin Pretty Autowerks in Centennial, CO by mastermind Christian Figuli (AZ username: ItsChich).
After discussion and planning with Christian, we came up with the build plan and I was able to source a complete s4 in Arkansas.
The avant: 2011 A4 S-Line avant Monza silver (wrapped gloss dark gray), 131k miles. Current setup: k04, CTS FMIC, CTS test pipe, AWE touring exhaust, k&n intake, DV+, vogtland coilovers, 034 rear sway
The donor: 2011 S4, 89k miles, 6spd manual, bone stock
The build: swap 3.0 supercharged engine, 6spd manual transmission, subframe, necessary wiring harness(es), interior (seats/door cards), instrument cluster, brakes. Retain: ecodes, push button start, suspension (vogtland coilovers, 034 control arms), b9 FBSW, s5 rotors. Aftermarket mods: carbon bits (front lip, side mirrors, rs4 roof spoiler, quad rear valence), drilled/slotted rotors, b8.5 LED taillights, ECS heat exchanger, CTS dual pulley, ECS black chrome quad tip exhaust (valved), IE intake, IE tune, can auto performance test pipes, can auto short shifter, 034 motor mounts, ECS drivetrain mounts, RSNAV, Avery satin metallic dark basalt wrap (Whoozys wraps), kilmat sound deadener (floors, doors, trunk)
Tuesday 1/19/2021: the avant is dropped off at Sittin Pretty Autowerks to begin teardown, interior is completely guttered
Wednesday 1/20/2021: drivetrain is removed from the avant, engine bay is cleaned
Thursday 1/21/2021: s4 arrives at the shop to begin teardown
Friday 1/22/2021: interior teardown continues, wrap is removed from avant, performance parts start arriving
