Results 1 to 13 of 13
    Senior Member Three Rings Dodaman's Avatar
    Mar 27 2018
    Coil pack advice.
    Hello all. Was getting a p0303 code for the #3 cylinder. Went to swap it with another one to see if the code followed it, and this happened. I guess I found the problem. Haha. They are original with only 40k miles on them. All plugs look fine, as they should. They were changed under 10k miles ago. So I’m going to replace all 6 JIC
    My ? Is I have a choice of Bosch or Bremi. The originals are Bremi. But I thought I’d ask the experts if one was better than the other ?
    Thanks for the replies. Have a great week.
    2005 A4 Cabriolet Quattro, 3.0L
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    I don't know about Bosch vs. Bremi, but thanks for sharing the pics. Never saw the guts of these coils before.
    Also, in the background I see the black flex tube has crumbled away from the coil pack harness at the rear of the valvecover. Probably wise to get something around those wires to protect them from cat heat. Good luck and thanks again.
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Quote Originally Posted by Dodaman View Post
    ...They are original with only 40k miles on them.
    Seriously? Your 3.0 has only 40K miles? Dang, mine is only 203,000 more than that.
    Mar 27 2018
    Coil pack advice.
    Yes Sir. It had 18,500 when I got it 3 years ago. But never had a coil pack just break in half when I went to pull it out. Haha.
    I hope mine goes as long a yours.
    Oct 09 2008
    Bremi is fine. I've seen many break. Keep an extra in the trunk for when one inevitably fails.
    The Awesome™
    Mar 27 2018
    Quote Originally Posted by JoshDub View Post
    Ok bummer but thanks for the advice. I’ll get an extra.
    Mar 27 2018
    Quote Originally Posted by john_gonzo View Post
    Good eyes. It was completely broken apart, so I took all that part off. Already have some more and plan on wrapping it back up. Thx.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Have you considered going Genuine? Not sure what brand that would be, but a little extra assurance goes a long way.
    2001 Corvette (C5) Z06
    Mar 27 2018
    Quote Originally Posted by MetalMan View Post
    Bremi is the original coil packs. I just ordered them with matching part #’s from FCP Euro along with new plugs. Was just curious about Bosch. Only bummer is they won’t be here for 3 days with the weekend. So the car waits. But picked up a compression tester. Figured I’d check the cylinders for that as long as I’m switching them all out. Should run like a champ then 🤞
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    FWIW, it's usually recommended to run the compression test with the engine hot. (only mentioning because it sounds like you're planning to not drive the car, but perform a compression test anyways)
    Mar 27 2018
    Thanks Metalman. I do plan on getting it up to temp before doing the test. Guess i wrote it wrong. Haha. Gonna recheck the connections and grounds with meter while I’m there.
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    There was a recall on the 3.0 cops...maybe 2013...not that it helps you now.
    The oreilly import direct cop is a good part.
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Eldor is the original manufacturer, I'd stick with those.
    Bosch and Bremi seem to have a pretty less-than-satisfactory reputation around here as far as aftermarket coils go.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
