For the question of what battery Audi put in the car, the PR code is more reliable than the battery in the car. Unless you bought it new and know it's never been changed. For the NAR market B8 vehicles, except maybe the Q5 hybrid which I don't really care about, there are six PR codes:
group 94R, the smaller battery: J1N for 75Ah/420A AGM and J0R for 80Ah/380A flooded
group 49, the "middler" battery: J0B for 92Ah/520A AGM and J1U for 95Ah/450A flooded
group 95R, the larger battery: J0P for 105Ah/580A AGM and J0Z for 110Ah/520A flooded
those A ratings are DIN spec, so might seem small. The 520A DIN batteries are also marked 850A EN, which seems to be about the same as SAE.
You'll notice all the battery groups are the same terminal orientation and same cross-section, the sizes just differ in length, and therefore volume.
On the subject of stop/start, no NAR market B8 had stop/start (again, Q5 hybrid, no idea, don't really care). Stop/start will be a fast death to a standard flooded battery. So when Audi started shipping RoW stop/start equipped vehicles in '09, no doubt they all had AGM batteries. Notice on the Bosch battery page, the S6 AGM has the stop/start icon, the S5 flooded do not:
https://www.boschautoparts.com/en/au...nger-batteries
This is an area where Bosch US and Bosch EU very much differ on their tier branding. Here, S6 is AGM and S5 is flooded. But on a European page, S5A is AGM and S4E is enhanced flooded (EFB):
https://www.boschaftermarket.com/gb/...8#ce_30004468_
EFB. So they enhanced the standard wet flooded battery to better survive stop/start. Notice it has the stop/start icon on it. But per the details, they are good for basic stop/start, not stop/start that utilizes and regeneration mechanics. Audi's stop/start regeneration is not "real" brake regeneration. It's just a manner of loading the alternator onto the engine only during braking and overrun and boosting the alternator output to power charge the battery. This way the alternator can be less of a load when the engine is working to move the car and still get the battery recharged. This means the battery is under a lot more voltage and charge swing. So such a system dictates AGM in that case. See SSP 426.
None of the Audi B8 batteries that are flooded (these will all be 000 915 105 Dx part numbers) are EFB. At least not meant to be. Could Audi be sourcing EFB as stock for the non-AGM part numbers? It's Audi; anything is possible. The AGM batteries will all be 000 915 105 Cx part numbers. Don't forget, these 000 ... part numbers are not what would be in early cars. No idea when they changed to them, no idea if they were ever used in factory build. But we're stuck with information for replacement parts, not factory parts.
As to what or why NAR market vehicles might have which of the six PR codes, again, I suspect that would require an information compilation that would still be guesswork when it's all done. I do wonder if my car had AGM because with the turbo, it would run the fan during the afterrun period every car shutoff. I notice after I had the stage 1 where my ECU was reflashed with the 2012 standard, the fan has never run on engine shutoff since. Not once. I just hear the hum of the V51 pump, assuming that hum even means it's working. Did they want AGM originally and then get cheap? Who knows, it's Audi, or really, VAG with lipstick the past decade. Cost cutting above all else.
I guess we ask AoA, but AoA seems to have the technical curiosity of a corpse.
