Results 1 to 40 of 48
    Junior Member Two Rings
    Jun 22 2018
    Cincinnati, Ohio USA
    3.0t teardown and rebuild, 210k miles, pic heavy
    Im in the process of rebuilding my 3.0t because of a burnt exhaust valve. The engine has 210k miles and ran good up until the valve burnt up. It burned about 1 qt of oil per 1k miles and has the timing chain rattle for a second or two upon startup. This isnt going to be a step by step. I just want to show the internals of a high mileage engine. The engine is already pulled and had the heads off before i started.
    Left head cam journals. no noticeable wear
    Left head valves. tons of carbon
    Left head valves. carbon cleaned about 30k miles ago
    Left head. Wear mark from chain rattle
    Left head. Valve seats no chips or pits. exhaust is dirty
    Left cylinders. tons of carbon
    Left Cylinders. close up of walls
    Right head cam journals. no noticeable wear
    Right head valves. tons of carbon. hole in #3 exhaust valve
    Right valves. close up
    Right head valves. carbon cleaned about 30k miles ago
    Right head. Valve seats no chips or pits. exhaust is dirty
    Right Pistons. tons of carbon
    Planning on tearing down the lower half tomorrow. I'm curious what the main and connecting rod bearings look like.
    Senior Member Two Rings 11A6's Avatar
    Jan 04 2018
    Maine
    Thanks for sharing this with us. what's the model of your engine. I have a first gen 3.0 with 130k miles and hope to do carbon clean summer but after seeing how much carbon was on in only 30k miles wondering if it's worth it. Seems to build up fast.
    You note that other than oil consumption it ran well - any sense of what caused burnt exhaust valve? Thanks in advance.
    2011 A6 Avant Prestige w/CWP 1/20
    Jun 22 2018
    Its out of a 2012 A7. The carbon that's on the valves now is nothing compared to what was on them before the cleaning. its well worth it. Exhaust valves burn when a piece of carbon or debris get caught between the valve and its seat. During the combustion process the hot gas/air is traveling past the valve and slowly melting it until it creates a large hole big enough to not be able to build compression anymore. I do not know the chances of it happening but it must be very low as i did not find much information of it happening to other 3.0t owners.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Thanks for the pic, so which valve got burned? Cn you post a pic of the damage to it?
    Jun 22 2018
    Finished tearing down the engine today, and I'm totally surprised on the condition of the bearings. Also took a close up if the burnt valve. It is one of the exhaust valves on cylinder 3. Also If anyone wants a photo of something just let me know ill try to get it posted. Im going to be dropping off the block and heads to get hot tanked tomorrow. Hopefully i can pick the block back up Saturday and start the reassembly process.
    Cylinder 3 burnt exhaust valve
    Pistons and connecting rods
    Close up of the rings. Its real crusty but all rings move and not broke
    Connecting rod bearings. The marks in the center are from me removing the pistons. Had to tap them out
    Crank journals. looks good
    Crank bearings
    Cylinders still have a little of the cross hatch left
    Nov 27 2018
    Valparaiso, IN
    Other than the carbon and burnt valve that motor looks great.
    Nov 27 2015
    UK, West Berks
    Thanks - I enjoyed looking at those photos. Is the price of some parts (e.g. valves) such that you can choose to replace rather than clean?
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    What all do you expect to replace in the rebuild? Just rings and seals or pistons, valves, etc. Thanks for sharing!
    Scott
    2013 S7 | Prestige | Estoril Blue | Lunar Silver | SRM RS7 +4mm Turbos | SRM Short Intakes with RS7 Airbox | DS1 Stage 4 ECU | APR TCU | AMS Catted DPs | AMS Cooling Package | OCarbon Large Weave Carbon Package | Alu Kruez | Eurocode Sways | HRE FF01 20 X 10.5"
    2021 SQ7 | Prestige | Black Orca Metallic | Black Optic | Luxury Package | Laser Lights | Tow Pkg |
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Thanks for the pics. Sucks that this happened to you.
    What oil was used and what OCI?
    Was any type of Fuel injector cleaner used, top tier fuel?
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II 12.868@107.8 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I 14.746@95.29 3944lbs
    Established Member Two Rings Tineo's Avatar
    Jul 08 2013
    Dairy Land, Asturias - Spain
    nice photos. Thanks for sharing!
    2008 A4 B8 3.0tdi Quattro Sedan 6MT EuroSpecs
    Ibisweiss | TLR remap to 301hp | S-Line interior | Rotor 19" rims | S4 front & rear brakes | Depo taillight LEDs w/ fulldynamic LED turn signals | 80mm exhaust tips | S4 blackgloss grill with blackgloss valence | S4 pedals | RSNAV 8.8" ...and more
    Jan 04 2018
    Maine
    Coincidentally someone just posted in the C6 forum (my neck of the woods) that they picked up an 09 A6 with earlier 3.0 tfsi and it also had "burnt exhaust valve" that they associated with an injector issue thought I'm not sure why an injector would burn exhaust valve. he's replaced cly head and injectors and claims it's fine. Thought you might find that interesting.
    https://www.audizine.com/forum/showt...ightings/page6
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    your rod and main bearings look a lot better than mine, lol:
    Jun 22 2018
    Dang email notifications aren't working. ill try to answer everyones questions
    Dippy - I ordered a kit from ebay for about 1200 shipped. https://www.ebay.com/itm/3-0T-Engine...72.m2749.l2649 it is a pretty decent kit. Most of everything has VW part numbers and appears to be decent quality. I could of cleaned and reused the valves but i didnt really want to chance it. i dont plan on pulling the engine for a few more years
    scott99c2 - Replacing everything in the kit. New valve springs and connecting rod bolts. pcv valve. I was going to replace the oil pump but i disassembled mine and it looked pretty good. I thought about replacing the water pump and thermostat but they looked good and if they fail they are pretty easy to replace.
    gk1 - I mainly used liqui molly 5w30 but the last oil change I used a high mileage mobil 1 because of the consumption of oil. It didnt help. Im not sure what OCI is. If its octane I always use 91 because im tuned and I pretty much always fill up at either the Shell station by my work or the UDF by my house. I heard UDF doesn't have ethanol in their fuels
    11A6 - I guess if the injector was leaking it could burn the exhaust valve when it opens.
    fastboatster - Dang #2 looks like it got a little warm. did you replace the rod?
    Dropped the block and heads off today to get hot tanked. Im going to pick them up tomorrow after work. Forgot to order new rod bolts so now im waiting on the hone paste, valve springs and rod bolts which should be here by the end of next week. I wanted to order ARP bolts but couldn't find any sets and had to get them ordered. I have a lot of cleaning, measuring and valve lapping to do so waiting on parts isn't too bad. Wish i had the funds to do a full build on the motor. forged rods and water injection but i might have enough for the larger crank pulley, larger inter cooler and dual pulley tune.
    Nov 27 2018
    Valparaiso, IN
    Are they going to check the block and heads for flatness when they hot tank? Hopefully they do, if not then I would recommend getting it checked. That should help with installing the head gaskets and not experiencing an early failure.
    Apr 23 2019
    CA
    @Junkers - no, I didn't replace that rod, I got another engine. This is just what I saw after I decided to tear down the old seized engine. I decided to get another engine right away after I found out the old one doesn't turn over and can't be turned by hand. It spun some main bearings and I'm not quite sure it's cost effective to rebuild.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Junkers View Post
    Thanks for the replies.
    OCI = Oil Change Interval
    Did you go by Audi's 10k mile recommendation or shorter/longer?
    Any particular reason you chose a 5w-30 vs 5w-40?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Jun 22 2018
    I changed the oil every 5-6k. Anything longer just doesnt seem right and no real reason using 5w30 instead of 5w40.
    Picked up the block and heads today. they look pretty clean. Also the honing paste came today. Its going to be a busy weekend. Ill get some before and after photos up
    Nov 27 2018
    Valparaiso, IN
    Mobil 1 synthetic will easily last 15,000 miles. My engine is at 205,000 miles on a 10k OCI. It got Castrol from the dealer for the first 145k then somewhere after that when I bought it went to Mobil 1
    Jun 22 2018
    Didn't get much done over the weekend. I did hone the block. It looks exactly the same as before so I didn't take any photos. You can feel the difference with your finger nail. I lapped the new valves, installed new valve stem seals. And checked the main bearing clearances. All with in spec of new bearings. I'm pretty much stuck waiting on parts now. Can't continue until the new valve springs, connecting rod bolts and main cap bolts come in. I also ordered a stage 2 crank pulley, new intercooler, replacement secondary cooler and the stage 2 double pulley tune.
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Subscribed to watch your progress.
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    Out of curiosity, how many hours did you have into removing the engine, and then breaking it down?
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Jun 22 2018
    About 8 beers. I didn't keep track of time. Spent alot of time figuring out how crap comes apart so I didn't break too much. I have to replace the hidden trans mounting bolt and the ac compressor pigtail. Also finding and ordering the correct tools took a while as I did not have any 12 point metric sockets. If I have to do it again and I hope not any time soon. I could probably pull the engine and get it apart in about 8 hours. Also I'm horribly bad at giving time estimates.
    Jun 22 2018
    Don't know how to edit on mobile but at a status update. I'm still waiting on the crank cradle bolts and valve springs to come in from ecs tuning. They still haven't shipped yet and the only reason I ordered from them is that they are located in the same state as me so I figured I would get them fast but I was wrong.
    Aug 11 2016
    CA
    Awesome great work. Good luck with reassembly!
    Jun 22 2018
    Just got done with ECS customer service. Says the parts are in stock and would ship soon. They were "in stock" when I ordered them. So I just canceled my orders and I'm going to do all my business with fcpeuro from now on. I refuse to do any business with people who do shady stuff like this.
    Mar 13 2018
    I can’t fault you there...
    Nov 27 2018
    Valparaiso, IN
    I would not say its shady business but rather Covid business at the moment. Because of the needed social distancing they are short staffed in the warehouse.
    Order Shipping Update:
    We are doing our best to ensure the fastest and safest shipping of your order. Due to delays caused by the COVID-19 pandemic, your order may take slightly longer to arrive.
    That is the language on their website at the moment.
    But even given that if you feel that FCP can give you better service then go for it. Over the summer they were great to deal with on my timing chain parts. I had good service dealings with Europaparts as well.
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    FCP offers lifetime replacement warranty as long as you ship the failed items back. Even on wear items. It's totally worth it for that reason alone.
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Jun 22 2018
    I don't think it's a staffing issue. The pcv valve I ordered a couple days after I ordered the valve springs is already delivered. Unless they have a warehouse in China, they are misrepresenting their "in stock" levels.
    Jan 14 2016
    Wilmington, NC
    Fcp is Def the way to go
    Sent from my Llama using Tapatalk
    Jun 22 2018
    FCP euro is out of stock of the valve springs and no ETA of the next shipment. Which is the correct way to list inventory on a website. So I had to order through genuineaudiparts.com. My order through ECS for the springs and bolts were $371.77 with standard shipping. My order through Genuineaudiparts.com for the exact same parts with next day shipping is only $327.90
    I might just use the old crank cradle bolts until the new ones come in so I can continue the build. I just hate doing work twice.
    Well Genuineaudiparts.com instantly cancelled my order. Just used my last option and called the dealer. He is able to get me all the parts by Wednesday of next week. And get this the total is $304 lol
    Established Member Two Rings Kael's Avatar
    Apr 25 2020
    1987 Corvette, "Lady"
    Urbandale, IA
    Always good to check around, odd surprises for sure. Dealer I'd have expected to be the highest!
    - 2016 Audi A6 3.0t Prestige "Sixius"
    - 1987 C4 Corvette "Lady"
    Jun 22 2018
    Picked up my parts from the dealer today. They got them in super fast. Worked a little on the heads but the propane heater ran out so work had to stop.
    New vs Old spring height. Notice the 3 tighter coils on the bottom? I didnt until i was half way done with one head
    easy way to tell the orientation. white marks up
    Right head done
    Super clean
    Bonus photo, aftermath of a minor derailment
    Sep 16 2020
    West Michigan
    Did you gasket match (port) the heads?
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jun 22 2018
    I thought about it. but i want to get my car on the road again ASAP
    I was just going over all the parts i have to rebuild the engine. The new head bolts are polydrive while the old ones were triple square. so theres another special tool i need to buy. Luckily amazon has them with prime shipping.
    Jun 22 2018
    Got the lower end somewhat assembled. It takes forever to check all the ring end gaps and connecting rod bearing clearances, but you have to do it. Almost made a huge mistake. Some how i mixed up the connecting rod caps for 2 and 5 before i marked them. The engine was really hard to turn until i swapped them around. All is good though everything checked out alright.
    Piston Oilers
    Main Cap Cradle all torqued to spec
    All connecting rods installed and torqued to spec
    Shiny Pistons
    Nov 27 2018
    Valparaiso, IN
    Check the welds on your cats while I the engine is out. Mine broke the flange at the manifold on the passenger side. And of course this happened 2,000 or so miles AFTER I put the engine back in the car.
    Mar 11 2007
    Colorado Springs
    Piston Oilers
    Shiny Pistons
    Looks beautiful.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Jun 22 2018
    Got a liitle more work done today. Spent most of my time cleaning up the upper oil pan. I forgot to take it when i got the block hot tanked. Also getting the old RTV off of the lower oil pan was a pain. Ran out of propane again. Ran through 6 tanks already. I also installed the crank locking pin. Notice cylinder 1 isn't at TDC, but cylinder 4 is. I wonder if the timing chain engineer got the firing order reversed. Also found 4 more bolts that i need to order. The Cam shaft sprocket bolts are one time use. They are torqued fairly high and don't want to risk one of them letting go. The only problem i have is that i cant find the part number for them. They arent even included in the "master" timing chain kits from FCPeuro or ECS tuning. Probably just going to call my audi dealer since he hooked me up last time.
    Lower oil pan on. With the tray and baffle its almost like a dry sump system
    Ready to start on the timing chain and front of the engine, but not with out any heat.
    Apr 23 2019
    CA
    bolt p/ns are N91042802 (long one) and n91050201 (short)
