Took my RS7 into Audi today to get the 40k maintenance--- I've got 46k miles on it. It was cheaper than they quoted, which was awesome!
What was not awesome was the tech showed me that the front brake rotors have hairline cracks in them, barely noticeable. In fact, it almost seems cosmetic?
The brake pads were also slightly worn, as expected with CCB. By contrast, the rear brake rotors and pads were acceptable.
He indicated that Audi recommends changing both front brakes out completely at a price of $15,793.00.
PANIC!!
A cursory Google of the Audi CCB problems shows that this is quite common with CCB...most hits were from R8's but also with Lamborghini as well.
Apparently the Carbon Ceramic can crack as it expands/contracts due to heat? I live in Denver, where the weather can fluctuate quite a bit.
Some Google hits say this isn't even a problem and that the brakes will continue to function as expected. Audi advertises that they should last "life of the car" or 150,000 miles.
The only real issues I found in my searches were the problem with performance in the wet roads.
SEMI RELIEF!
I mentioned to my Service Person that this shouldn't be possible and they should be covered under warranty (less than 50k miles) and they said something about "wear and tear"
Thinking about it on the drive home, while I know this car can be expensive to maintain, that is roughly 20% of the blue book value of the car, which I think is insane.
So what would you do?
Anyone with RS7 Carbon Ceramic brake issues and experience?
thanks!
--Shane
