Originally Posted by
4GoT10
Hi guys its me again :D
amm i have 2011 a6 c7 with keylles entry/go on my car.
it seems to me that keyless entry is not working on drivers side but i can lock it with the little tile on the handle.. passanger side keyless entry and lock works fine ..
is there any sensor or fuse that bight gone bad or ? i need to replace all handle ?
thanks in advance
Like a few others have said, scan for soft fault codes - you will likely have a ‘drivers door handle malfunction’ or something along those lines. Obviously check your battery too.
The typical root cause is a grounding issue and replacement is needed, or if you can find the ground fault.
This is actually a common problem with these handles on Audi models, that has been around for years. Do a google search to be enlightened.
