Results 1 to 10 of 10
    Junior Member Two Rings
    Mar 11 2020
    Southeast
    Audi recommended carbon cleaning
    Went to dealer for my 2014 with 54k miles.
    They recommended 2 services - "Fuel/Air Induction Cleaning Service" and "Fuel Injector Cleaning Service" , both for carbon buildup prevention. BTW I am not having any issues with the motor, I went in for an oil change and they just recommended this based on the miles and because they didn't have prior service records.
    They said this service involves "using a machine to run a solution through the engine for preventative maintenance" and said it is recommended every 30k miles.
    My question is - my car has 54k miles and I doubt the previous owner did this service. So at this point am I better off just doing a walnut blasting at an independent shop? It's pricey so I'd rather not for now if it is not needed yet, I don't mind doing the Audi recommended service but I just want to make sure it will actually do something for my engine.
    Can anyone give some advice? As always, much appreciated.
    Senior Member Two Rings 6SpeedS4's Avatar
    Dec 19 2018
    2016 Audi S4 w/ APR Stage 1 /IE Intake / IE non-res downpipes / AWE Touring / ECS SS Clutch line / M
    Pittsburgh, PA
    Quote Originally Posted by Spartan23 View Post
    Fwiw, I just did a carbon cleaning at 60k and it didn't really need it but was replacing waterpump, tstat and pvc so did it anyways.
    Sent from my SM-N975U using Tapatalk
    2016 Audi S4 PP / Sport Diff / 6 speed / APR Stage 1 93 Octane / IE Downpipes / IE Intake / AWE Touring / Canyon strut bar / 034 Rear Subframe Mount / ECS Tran Mount / ECS SS Clutch Line / Merc heat exchanger
    2014 Audi SQ5 Prestige / IE Stage 1 91 Octane
    Mar 11 2020
    Southeast
    Quote Originally Posted by 6SpeedS4 View Post
    Had you done any of these "preventative" services (the ones i mentioned above) prior to this or na?
    Dec 19 2018
    Pittsburgh, PA
    No, all done first time at 60K. Waterpump had very minor leak so went ahead and replaced before it got worse and replaced the tstat and pvc as well even though both showed no signs of failing.
    Mar 05 2016
    The dealer proposed me the exact same service, at 65k km for 189$cdn. I said cool, that’s not expensive for intake carbon cleaning + injectors cleaning. I asked the advisor, do you recommend changing parts while the SC is off. He said no, we don’t need to SC to perform these tasks. So basically, they are just spaying solution from open of the throttle body to clean the flap and connect cleaner to the fuel line to clean injectors. I said I passed.
    I bought a can of throttle body cleaner and I took off the throttle body myself to clean all body inside out. As for the injectors, I got a can of BK44 and dump it in the gas tank. I have twice the mileage now and the car is still running great.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Senior Member Three Rings usmcfieldmp's Avatar
    May 04 2020
    Fort Worth, TX
    This is a before and after on an 80k mile 2013 S5. I walnut blasted them myself while changing a stuck thermostat (plus water pump and PCV).
    I'd definitely go with an independent shop to blast them. But it's kind of a "while you're in there" job... you should change the thermostat and PCV while you've got it apart.
    2002 Audi TT Quattro || Entering Racecar Status | Needs a LOT of love || Project Thread
    2013 Audi S5 || TOTALED ||
    || 1986 Volkswagen GTI || 1997 Dodge Viper GTS || 2005 Chevrolet Cobalt SS ||
    Mar 05 2016
    That’s not the intake carbon clean the dealer is proposing.
    Sep 24 2019
    Indiana
    If they aren’t walnut blasting you’re wasting your money.
    Feb 12 2018
    Terrebonne
    cash grab
    brillant black 2015 ; 034 stage 1 | AWE touring 102mm black tips | Modded airbox | KW V1 | 034 rear sway | CF trunk spoiler | ECS rear diffuser | stance SF01 19x9.5 et38
    Senior Member Two Rings stoked_S4's Avatar
    Nov 10 2013
    2002 Skyline GT-R Mspec Nur
    I had this done 2 years ago around 45K. Some black smoke came out but was told that it was not so bad. Much economical than walnut blasting that costs $1K! This is better than DIY spray route. If you are in NJ it is a good option. I recommend this place.
    2022 X3M Competition
    2002 Skyline R34 GT-R Mspec Nur - 585hp Nismo Z-Tune
    2014 S4 Phantom Pearl Black | DSG | Sports Diff | Black Optic Pkg | MMI Nav | side assist | carbon inlays| Carbon Supercharged Badges | Michelin Pilot A/S 3+ | Eurocode Alu Kreuz | CR15 Bar | ECS SS lines SOLD
