What could it be? Is the clutch pack going bad? Should i run the clutch adaption cycle? Or is it just that the oil in the clutch is too thick and binds? Kinda embarrassing to stall an automatic
Oh, and its a 2.0TDI with 7-speed dsg.
2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
