Originally Posted by
my1stturbo
Did you ever get a chance to work on this? Curious what you found you had to remove to get access to it. From what I can see it looks to be that o-ring and hoping to get to it after work 1 night
I did it a couple weeks ago. The car has been parked in the garage since January when we got a new vehicle, so it hasn't been a priority.
I ended up replacing the hard pipe O-ring, which was an easier job as I was able to do it without removing the alternator.
- Removed the drivers headlight
- unscrewed and lifted the coolant reservoir out of the way
- removed the throttle body tube and throttle body
- removed the vertical steel bracket support
- unbolted the rear bolt holding the hard pipe
- unbolted the front most bolt holding the hard pipe to the thermostat
- was able to pry the hard pipe out of the thermostat
- watch a bunch of coolant drain out to the floor and catch pan
- replace the O-ring and reattach the hard pipe
- assemble it all back together
No leaks from what I can tell now, however it hasn't been driven much or put under pressure, as it's still parked.
I'm positive the O-ring was my issue, and everything should be good now.
