Results 1 to 26 of 26
    Aug 18 2020
    Sonoma, CA
    Chasing code P0171
    My kids 2008 A4 Quattro keeps setting the CEL about every 500-1000 miles with P0171, lean bank 1.
    I have checked PCV, hoses, breather pipe, N80, gas cap seal, fuel filter, dipstick seal and most every other obvious cause for this code. I even drained the intercooler pipes and very little oil came out.
    I have looked but not too extensively for vacuum leaks. I can find nothing obvious. I don't have a way to smoke test the intake and hoses so is the LP the best way to try to find a vacuum leak? I am getting irritated and since it only happens randomly it is hard to track down the cause. He can go from LA to San Francisco with no light which is about 400 miles but eventually it will set the CEL. What are the common failure items for this code that I am missing?
    He is back in LA now so will be awhile before I can give it another look.
    Maybe the MAF?
    I am at wits end.
    Feb 15 2016
    Cambridge,Ontario
    Have you actually replaced anything ?
    PCV is number one cause of this and is high fail on this platform
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 18 2020
    Sonoma, CA
    New Audi brand pcv and pcv hoses. All of the plastic latching ends of previous pcv hoses were a little suspect. When I replaced them, the hose connecting to the oil filter housing/block side under the intake just kind of pulled out.
    Jun 13 2017
    nowhere
    Try replacing the diverter valve or upgrading it to machined piston style its like $130 at ECS tuning. My car throws the same code rarely and it was only after I messed around with the DV valve and added a spacer for blow off, then removed the spacer again because the idle sucked and now I still have high idle issues and lean codes every now and then. smh
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    The metal breather tube on the turbo side of the head has a check valve in it that is part of the PCV system. On earlier years, that check valve is in the actual PCV. T hat check valve leaking can create that code.
    Aug 18 2020
    Sonoma, CA
    Quote Originally Posted by Older_not_Wiser View Post
    Just replaced along with PCV.
    Established Member Two Rings SlvrArrw's Avatar
    Nov 05 2016
    Richmond, Texas, USA
    Does the car idle normally?
    Sent from my Pixel XL using Tapatalk
    Aug 18 2020
    Sonoma, CA
    Quote Originally Posted by SlvrArrw View Post
    Yes, seems to. Cold start idles a little over 1000 rpm and then after a minute slows to about 850 or therabouts.
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    Chasing code P0171
    I know this sounds crazy but go back to basics once again and do these simple checks:
    while the car is idling, check if you can remove the Oil cap at all. If you cant, you most like have a bad pcv valve or a wrong version of PCV.
    you need to do a leak test on all the intake hoses after the MAF, if you dont have an air compressor. Find someone to do it.
    After that you need to look at the data of MAF and o2 sensor. Even a cheap scanner can do it. View some youtube videos on how to look at graphs those graphs should be easy to judge on any brand of car.
    Aug 18 2020
    Sonoma, CA
    Quote Originally Posted by Jeevan View Post
    I do have a compressor. How do I leak test intake hoses this way? PCV is new and oem.
    May 15 2019
    Bellevue, WA
    dude, you keep saying it new. There is always a possibility that it could be bad out of the box. It doesnt hurt to verify.
    Aug 18 2020
    Sonoma, CA
    Of course I will do the oil cap test. It seems difficult to remove all the time to me. I know it runs like crap when the cap is off.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Quote Originally Posted by tractoman View Post
    Yes, the cap will be somewhat difficult to remove when idling, and run rough when it is removed. This is one indication that the PCV valve is running properly. Since you're a 2008 there will be a check valve at the top of the front right breather tube going down to the pre-turbo port. If you want to check it, make sure absolutely no flow is possible towards the valve cover.
    Aug 18 2020
    Sonoma, CA
    Quote Originally Posted by Brillo View Post
    The breather pipe is new. I just installed it and check valve is correctly functioning.
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    If you've taken ALL of the necessary steps to confirm it isn't a PCV issue or a small boost leak from your charge pipes, next thing I would do is take off the intake/TB and reseal it with fresh gaskets. I know it's not a common issue on these cars but with it being a ~15 year old plastic intake I wouldn't be surprised if it's leaking slightly.
    Sent from my Pixel 3a using Audizine Forum mobile app
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
    Oct 03 2017
    Quote Originally Posted by blakefife View Post
    Sorry, but diverter valves don't cause lean codes often, if at all. If anything you'd be running rich.
    May 15 2019
    Bellevue, WA
    Quote Originally Posted by Cyrik View Post
    thats what I was about to say
    Account Terminated Four Rings
    Oct 15 2013
    My kids 2008 A4 Quattro keeps setting the CEL about every 500-100 miles with P0171, lean bank 1.
    Maybe the MAF?
    I am at wits end.
    Yes, clean out the MAF meter. Start with the easy stuff.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    This is backwards. Early cars have a blank breather tube. Later cars have the check valve in the tube.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    May 20 2017
    New Hampshire
    If you have VCDS you can find vacuum leaks pretty easy.
    Go to block 032 and look at fuel trim. Write down the values. Clear your codes. This resets fuel trim also. Start spraying carb cleaner around on hoses and parts of the intake with the car at idle. If fuel trim spikes when you spray a part, you’ll know the vacuum leak is in that area. Fix the leak, clear codes again and drive it for like 10-20 miles up and down the highway and check fuel trim again. If your trim is lower than what you wrote down before you cleared your codes and drove, you fixed a leak. If it’s about the same, now you check MAF.
    What is your MAF reading at idle? It should be about 2.5 GS at warm idle. If it’s higher or lower, clean it with carb cleaner, clear codes and do the same test drive. If your fuel trim is better, your MAF was dirty. If it stays the same, maybe replace the MAF.
    Another cause could be a front O2 sensor but those are harder to diagnose unless you have a O2 sensor fault.
    Another cause which is also overlooked a lot is the rear main seal. It can cause a lean code because believe it or not, it can allow unmetered air into the engine if it’s leaking.
    Also, the oil dipstick tube seals can also cause leak codes and is often overlooked.
    May 20 2017
    New Hampshire
    I’m not saying you did this but a lot of people put the wrong PCV valve in their cars. Did you buy yours from the dealer?
    A 2008 should have the part number ending with a P and have a breather tube with a valve in it.
    2005.5 and early 2006 has the R part number and a blank breather tube.
    Confirm what part number you PCV is.
    Aug 18 2020
    Sonoma, CA
    Quote Originally Posted by EvolutionArmory View Post
    It is the breather tube with check valve and pcv ends in p. Both are oem with 4 rings on them.
    Car is away at school with my kid but will pick up on this when he is home again.
    Thanks for the tips so far.
    May 20 2017
    New Hampshire
    Then you absolutely have the right combo.
    Mar 16 2012
    Lomita, California
    Pretty much what I said... 'On earlier years, that check valve is in the actual PCV.' Meaning it is not in the breather tube.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    May 20 2017
    New Hampshire
    Sorry dude. You’re absolutely right. I mixed up your post in my head real bad now that I went back and read it again.
    Oct 15 2013
    Could be an o2 sensor going bad too.
