Page 1 of 3 123 LastLast
Results 1 to 40 of 88
    Established Member Two Rings bootleg.rs5's Avatar
    Jan 06 2021
    2015 RS5, 2018 S5, 2018 A4
    Arizona
    Question Aftermarket Carplay
    Looking to get an aftermarket carplay to get a half functional Bluetooth system on my 2008. (Yes I have Tune2Air and it works maybe a third of the times I turn my car on).
    Is there any specific maker of a good carplay for this car that I should look for? Where can I buy one. Would likely install myself to save money
    Jan 24 2010
    Brno, Czech Republic
    Yes, I installed my Carplay/Android Auto box few weeks ago. I can say it is almost perfect. Cheap and highly functional. I haven't tried Carplay as I use Android, but according to reviews, it works well. Installation is 20mins max, it is plug and play system. Seller is highly cooperative and provides quick support. I had some issues with cropped clock etc. and he provided firmware update the next day that fixed that.
    I highly recommend this unit.
    Alixpress
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    woah that's neat, does that replace the MMI functionality or can you switch between the two? does it add any trouble codes to vagcom? also looks like this only works with MMI3G (facelift) c6 a6?
    thanks
    Marko
    2007 A6 Avant 3.2L Black/Black, 265k miles
    Jan 24 2010
    It doesn't replace it. You can quickly switch between standard MMI and this. To select this press and hold Nav or Media button for 2s. To switch back to MMI, press any button - Nav/Media/Tel...
    I haven't checked for trouble codes, but I haven't had any issues.
    There are number of versions of this box, suitable for most Audi models and MMIs. If you're unsure, just write to the seller, he will tell you which one.
    Advantage of this unit is that it uses car's canbus and optics and microphone, so the sound quality, call quality etc. is not touched. It also works with OEM reversing camera, it switches to it and back nicely.
    Also, you can connect 3rd party front and rear camera, there is also HDMI port
    Oct 25 2012
    Manchester, UK
    Really interested in this. Is yours the upgraded large screen MMI with the cursor on top of the knob? If so I'm yet to see this on the standard specification smaller (and lower resolution) screen MMI that I have though.
    Sent from my SM-G973F using Tapatalk
    Jan 24 2010
    Yes, MMI 3G High, with hard-drive etc. But they do versions for 3G Low and 2G
    Oct 25 2012
    Manchester, UK
    I want to see how it looks on a lower resolution screen and see if it's easy to read everything. Can't find a picture of anyone with my system who has done it. The alternative is to get the android one that replaces the screen altogether.
    Jan 06 2021
    Arizona
    Quote Originally Posted by -=zipp=- View Post
    Alixpress
    Does it have a good functional Bluetooth? Because my tune2air through the AMI is mediocre
    Jan 24 2010
    What BT do you have in mind? For handsfree? You can choose if you want to use car's BT or this box's BT. Box is OK, but voice quality is better over car's oem BT, so I use this.
    Note the Android Auto (and most probably Apple Carplay too) use Wi-Fi for communication
    Jan 06 2021
    Arizona
    My car's bluetooth doesnt work for music. Typically I connect to both the car "Audi UHV" and "Tune2Air" at the same time. The car takes calls, and the tune2air plays music through the AMI port.
    Im asking how this aftermarket system plays music? Is it an aux? My car doesn't have a built in aux port anywhere. Is it Bluetooth? If so, does it also require something plugged into the AMI?
    Senior Member Two Rings luketc1's Avatar
    Nov 13 2016
    Manhattan, NY
    the kit you buy should come with an AMI / 3.5mm adapter compatible with your model year. carplay/android box will output line-level audio via 3.5mm into the AMI adapter
    2014 B8.5 A4 6MT
    2012 958 Cayenne Turbo
    Oct 25 2012
    Manchester, UK
    What happens if you don't have an ami box? The description says you could enable aux instead but i don't have a physical aux input
    Jan 24 2010
    luketc1 - not true
    Wi-Fi is used for the connection, the music from Spotify etc. is transmitted via Wi-Fi. As for the handsfree, you can decide yourself if you want to use car BT or Carlink BT.
    As for the 3.5 jack:
    - if you don't have AMI, then simply activate Aux option in green menu and select Aux as the Source in the car. The sound is being transmitted over car original wires
    - if you have AMI, just use the provided ami to jack cable, and plug it into AMI. You don't plug anything else in that cable, it is there to create Aux in the car menu only
    Oct 25 2012
    Manchester, UK
    I see, so you only need to have aux enabled but doesn't need a physical aux jack input? That makes life much easier as I can enable green menu and then activate from there. I wasn't sure before whether it actually needed a aux input or whether just activating it alone was enough.
    Jan 24 2010
    Yes, exactly
    Nov 13 2016
    Manhattan, NY
    sorry bout that, I'm only familiar with the MMI 3g and newer generations. look forward to seeing pics/vids of some units installed on this thread. I'm debating whether to invest the $$ into a carplay box or speaker/subwoofer upgrades
    2014 B8.5 A4 6MT
    Jan 24 2010
    No worries, my car has MMI 3G High, with higher res display, joystick and HDD.
    Do you really feel the need to upgrade your speakers? I may have BOSE, but I'm familiar with my friend's A6 without BOSE and it sounds very very good, almost like BOSE. I'd go for the carplay box as it adds a lot of new features to the car
    Nov 13 2016
    Manhattan, NY
    I've been underwhelmed by the stereo since I bought it - 2011 MMI 3g high non-bose. My 2003 Acura MDX (also non-bose) sounded better and got louder stock. In the audi my biggest complaints are max volume and lack of bass. Best sound quality comes from Tune2Air or CD changer as sources. Potential remedies:
    - Focal/Hertz 3" components to replace mid/tweeter in front. Would probably leave front stock door "subs" as is. Any 6.5" components in rear doors... Probably ~$500-800 total
    - Simple LOC from one of the doors or glovebox for powered sub/amp in trunk... could get this done for $300-400 total
    - Both of the above+dedicated 5 channel amp and MOST output... $1500-$2000
    ...yikes... should probably just go with the carplay box for $200
    2014 B8.5 A4 6MT
    Junior Member One Ring
    Apr 12 2019
    Portland OR
    I just ordered this, should be arriving later this month and I will report back on how everything works once it is installed!
    Jan 16 2009
    what year car do you have ceedubbya?
    Oct 25 2012
    Manchester, UK
    Yes please report back. I'm debating whether to get a car play box or get the whole new replacement 10.25inch android screen instead. That is about double the price though
    Apr 12 2019
    Portland OR
    Quote Originally Posted by estomax View Post
    2010, with the 3g hd mmi
    Jan 24 2010
    aleung2 do you really consider the 10" screen? IDK how about you, but for me, it looks ugly, cheap and it doesn't fit the car, it covers part of the fuel meter, MMI functionality is questionable and the system as a whole is cheesy
    Oct 25 2012
    Manchester, UK
    Undecided yet but it is the one the doesn't cover the gauges. It does cover the buttons around it but they're moved underneath the screen instead.
    The only reason is because I have mmi 3g basic and the resolution is not as good and smaller than your 3g high screen. If I had 3g high I'd be happy to use the existing screen.
    Jan 24 2010
    OK, understood, the resolution is a valid argument.
    If you go for this Android HU, keep us informed how was the installation and how is the usability.
    Oct 25 2012
    Manchester, UK
    Yes will do. I've found a car audio place near me who can fit it for £100 though so I'll get them to do it but I'll ask them how it was compared to something like a carplay box.
    Apr 12 2019
    Portland OR
    My carplay kit came finally and I got it installed today. Its works flawlessly! Definently worth it. While the installation instructions were a little lacking, the install isn’t too bad and the system integrated well with the native mmi system. Here are the steps for the install in case anyone else wants to do it:
    1: remove the glovebox. Suprisingly easy, pop the side trim piece off, unscrew the five screws hold the glovebox in place. Three inside the glovebox and two on the bottom.
    2: plug all of the respective mmi interface plugs into the carplay box, the instructions are helpful for this. You don’t have to remove the mmi unit so no need for trim removal keys since you can get to the plugs from the backside of the glovebox.
    3: this is where it gets tricky, you need to plug the power cord into the climate control unit but to get the unit out on facelift cars you need to remove the airvents above it to get to the clips holding it in place. I was actually able to get the vents off using a small screw driver to pull the clip tabs inside the air vent and a credit card to wedge the vents out one side at a time.
    4: once all of the cords are installed make sure you test the sytem before reinstalling everything. Reinstall is much easier since everything just snaps back in place. I left the included usb input near the fuses in the side panel in case i ever need to update the carplay system.
    Pics of the install and results:IMG_7361.jpg
    Jan 16 2009
    that looks great, wish the non facelift route was that easy and OEM looking!
    Oct 25 2012
    Manchester, UK
    Looks great. I'm so jealous of the high res screen you have. I've ordered the complete new android screen which should arrive in about a week or so but I'm getting a car audio shop to install it.
    If it was just the carplay box I'd probably give it go myself to be fair.
    Sep 28 2017
    shenzhen/guangdong/china
    it is not hard to get a carplay on an old car now days ,new editons just need to retrofit a dongle,supports air play mirror link and voice command.www.gocarplay.com
    Sep 28 2017
    u got android screen for audi?did u ever try to use the miu drive AI box
    Oct 25 2012
    Manchester, UK
    No, never seen those before. Besides I wanted to upgrade my low res screen anyway
    Jan 24 2010
    ceedubbya: I'm glad you like it, I love mine as well :-) One of the best and easiest mods I did to my car! BTW: I think you don't need to remove the airvents, just pull the climatronic should be enough
    aleung2: I'm very interested how will you like the android tablet in the car, I hope you will post a review after you get it installed. How it interoperates with car MMI system, car buttons (steering wheel, central console) etc.
    Oct 25 2012
    Manchester, UK
    -=zipp=- I certainly will indeed!
    Apr 12 2019
    Portland OR
    I tried just pulling it, but it was way too wedged in there, had to get at the clips with a screwdriver after removing the vents. Was tuggin on it for a good long time before I just decided to remove the vents. I suppose its car to car on how tight your clips are.
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Does this one work with a 2G MMI ( i have a 2009)
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Established Member Two Rings alex--monteiro's Avatar
    Mar 27 2021
    trusty Honda Accord
    Dorchester, MA
    ^ did we get a reply on this?
    Oct 25 2012
    Manchester, UK
    There certainly is one that works with 2g yes
    Mar 27 2021
    trusty Honda Accord
    Dorchester, MA
    Quote Originally Posted by ceedubbya View Post
    This looks great! Could you post the link for the product itself?
    Jan 24 2010
    The link is here already, I posted it
