Results 1 to 13 of 13
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Question Battery Tender recommendation
    Been a while since I've posted. I still don't use my 2015 S4 that much (still has 19k miles), and even less and less these days (obviously). I did prep my car for winter but I don't think I'll use it afterall (beater does the job). Since I cannot store it inside at warm temp it'll be outside in the cold all winter (under a carport so no snow on it) and I was looking for a battery tender recommendation. I used to have a CTEK 93-56-864 MUS but I lost it so I'm looking for a replacement.
    Important note: last year I had to change the battery on the count of the car not being used enough so it died and I figured I would not install an AMG battery since I would have to change it every 2 years anyway so I have a standard battery.
    While price is not a problem, I'm looking for a tender that can be plugged in normal outdoor 120v outlets and can sustain -30c
    I still have CTEK's accessories that allow to charge via the cigarette lighter plug but I won't use it since the car needs to be turned ON for this accessory to work (go figure!).
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I've used a couple of versions of the actual "Battery Tender" brand with good luck in the past. Not sure about at a sustained -30C, so YMMV.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    Why not disconnect the battery if the car is sitting unused.
    Sent from my SM-G970U using Tapatalk
    Veteran Member Four Rings KMPRSSD's Avatar
    Dec 19 2010
    E10 2002tii, 2010 VW Touareg Lux Limited
    Connecticut
    I have use this on my garaged S4 (I'm in the same position as you under 20k miles and less and less use).
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I also use this at my job to keep our tow motor charged. It is in an unheated car port but in very cold northeast temps. I have had very good luck with it.
    ll B8.5 S4 l 6MT l IE STG ll SP l Daytona Grey w/ Magma l Sport Diff l Black Optics l B&O l AWE Touring w/ non res DP l 19" AG M590 l Luft-Technik Intake l P3 Gauges l EuroCode SS l RS4 Grille l Carbon Valance l DeAuto Fogs l RSnav ll
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    Quote Originally Posted by silverf0x View Post
    It's actually very simple to make the cigarette lighter socket permanent live by looping a live feed to it's fuse. I used this guide over four years ago and has worked perfectly for me since.
    Link......... https://www.audizine.com/forum/showt...it-s-always-on
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by DarrenOman View Post
    Because I would like to still be able to use the car quickly if I need it for an urgent matter. Plus wouldn't the battery suffer even more from being on a shelf?
    - - - Updated - - -
    Quote Originally Posted by KMPRSSD View Post
    Thanks I will purchase that unit, it seems to fit my needs!
    Murdered B8.5 S4
    Build Thread
    Dec 14 2015
    Montreal, QC
    Last question, is it better to install the tender directly on the battery in the trunk or in front is ok too?
    Murdered B8.5 S4
    Build Thread
    Dec 19 2010
    Connecticut
    This has been a topic for debate. I go right in the trunk cause I have nothing in there and it’s not that difficult to put back the tool kit. I put the car cover in there anyway, so I have to open it regardless. Some have said the posts in the engine bay aren’t ideal because they add more resistance to the loop. There hasn’t been much data I have seen to back that up. I may start doing the hood myself, just cause it is that much easier.
    Powered by iPhone using Tapatalk
    Established Member Two Rings 1bsingh's Avatar
    Jan 23 2017
    Audizine members are too clutch. In the same boat as OP. Thank you
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I have this one setup in my garage on my Camaro:
    Battery Tender
    Recommended for a few reasons:
    - Weatherproof - Doesn't mention actual temps - but I have NO insulation & only rough framed windows in my garage in New England and had ZERO Issues
    - It is designed to maintain the battery - so reduces charge level as battery is charged to avoid overheating and includes auto monitoring
    - Can be left plugged in constantly with no oversight - 120V standard electrical plug
    - Comes with a set of "Quick Disconnect" pigtails - one has "O" rings that can can be hard wired directly to the battery and the other is set of clamps used for easy charge connections as normally expected
    Sits connected 100% of the time (Quick connected with underhood direct mount to battery ) It's saved me form replacing battery what was every 2 years (up to 6 years now) - and I can disconnect it in under 30 seconds to drive the car with the quick connection.
    Well Worth it....
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    There is no difference connecting the battery tender in the engine compartment versus the trunk. The resistance of the wiring (from the battery to the front) makes no difference to the small output current of the tender. The wires from the battery to the front have a low enough resistance to carry the engine starting current (300 to 600 Amps), as compared to the tender charge current of 2 Amps or less.
    I recommend that any tender be plugged into a quality surge suppressor, like the Tripp Lite Isobar 2:
    https://www.amazon.com/Tripp-Lite-Pr...s%2C169&sr=8-4
    I like the Deltran "Battery Tender" brand of products. (Amazon, Costco, Walmart...)
    Concerning taking the battery out of the car, the battery does not suffer any more self-discharge if you take it out of the car, "putting on a shelf", versus just disconnecting one terminal.
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by S4'ed View Post
    Thanks for all the advice. As you seem to be very knowledgeable on this topic, may I ask which model of Batter Tender you would recommend? I'm looking for something that can sustain low external temperature, can be easily tucked under the hood and easy to remove
    I could also consider a permanantly installed module to use even in summer (since I dont use the car that much).
    Would something like this work? https://www.amazon.ca/Battery-Tender...731139&sr=8-21
    Of course I would combine it with this as per suggested: https://www.amazon.ca/gp/product/B00...K6Y9EEQB&psc=1
    Murdered B8.5 S4
    Build Thread
    Sep 24 2014
    Central NJ
    The one you picked is a 24V unit, can't use that for your 12V car.
    Get this one:
    https://www.walmart.com/ip/Battery-T...rger/420435088
    This would be fine. Unless it is directly exposed to rain/water, these cheaper models are good. No need for it to be rated for more than an amp or so of output current.
