Guys, just installed a walbro 525 and deleted the suction jet system as I should. I have IE rails and 1000cc injectors. I’m using my stock fpr (which I swapped with a known good working one too).
I have an inline fuel pressure gauge and it’s showing 75psi and not dropping. No restrictions in lines and I’ve made sure none of my injector seals are leaking.
At idle im getting multiple misfires on all cylinders, under load 0 misfires, only when I come to a stop. I’ve done a boost leak teast too and nothing. I’m thinking the high fuel pressure is causing the misfire but don’t know what else to look for.
Any help is appreciated, the b5 life is starting to get to me. Thanks
