Results 1 to 18 of 18
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    Question C7.5 MMI Clarifications (Hidden Menu/Green Menu/Developer Mode)
    Long-Time AZer, new to C7.5 platform.
    Looking for clarifications on MMI/MIB2? enabling the Green Menu that I'm used to on the MMI3G unit.
    Using VCDS v20.4 it looks like direct channel access is no longer supported?
    Entering Channel 6 directly and Setting to 1 is not possible.
    Instead I now see a drop-down with a ton of items, one of which is "Developer Mode"
    Entered the SA code S12345, and changed Developer mode from "not activated" to "activated.
    Rebooted the MMI.
    Now for my issue: The normal key press of "Car+Menu" for 3-5 seconds does not seem to bring up the Green Menu.
    Instead I was able to enter a Developer Menu by using a different key combination, but the menu list is very different and I don't see a way to access any of the traditional mod related menus.
    Does the C7.5 MIB2/MMI4G wtf it's called not support mods such as https://docs.google.com/document/d/1...h.dfepmswbuooe anymore?
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    S12345 doesn’t work for me as security access 🤷*♂️
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Established Member Two Rings Sima-Koya's Avatar
    Jun 15 2020
    Serbia,Belgrade
    MIB2 is coded via adaptations channels and security access.
    Green Engineering menu is pretty closed down on it.
    Contact:
    Whatsapp : wa.me/381653086899
    Telegram : https://t.me/simaservis1108
    Phone Number : +381653086899
    MHI2 / MIB2 / MMI 4G
    Maps update / firmware update / Android Auto / Carplay
    Aug 17 2015
    Thanks Sima, is Developer Menu that I have activated different from "Green Menu" which I don't seem to see as an available channel selection in my VCDS Adaptation drop down?
    C7.5 S6
    B8 A4
    Established Member Two Rings orphancrippler's Avatar
    Aug 01 2020
    2018 Nissan Rogue SL, 2016 Nissan Rogue SV
    Telford, Pennsylvania
    Quote Originally Posted by IHave2Turbos View Post
    They are one and the same. VAG gutted the green/dev menu on the MIB2. I went down this rabbit hole shortly after purchasing my '17 S6, and was able to do exactly what you've done, and that was the end of it. Conventional wisdom is, most things, if not everything, that was in the OG Green Menu, is now buried in various adaptations and coding bits, which nobody has completely decoded/deciphered yet.
    Sent from my Galaxy S20 Ultra 5G
    2017 S6 DS1/SRT Custom ECU+TCU "Deathstroke the Terminator"
    SRM +4mm, HPA Street DPs, APR Catback w/X-pipe & 4" Tips, APR HX, MercRacing IC Core, SRM Short Intakes, AWE S-Flo V2, SRM Dual LPFP, Autotech Plungers, SRM FF Sensor + Engine Lines, 4 Bar MAP + Boost Sensors, TiAl WG Actuators, EMP Pump, JHM Oil Screen Kit, 034 Rear Swaybar/Endlinks/Drivetrain Inserts, SRM Driveshaft Carrier, iO2 CatSims, CF Spoiler + Mirrors, RS-Quattro Grille, Black Badging, CeramicPro Gold, 20mm R/17.5mm F Spacers
    Jun 15 2020
    Serbia,Belgrade
    Its decoded and deciphered alright,just not in the VCDS.
    I can make coding inside the MMI without any diagnostic tools.
    Only usb to ethernet needed.
    Contact:
    Nov 13 2014
    Manchester, England
    Quote Originally Posted by Sima-Koya View Post
    Yep, I saw this live in action. Mans got talent
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    You can enable the green menu with OBD11, although its damn near useless on C7.5. How to do it is over in the VCDS thread with pics.
    18 S6
    Aug 17 2015
    As I said, I was able to enable the green "Development Menu" via VCDS but coming from a B8 I didn't recognize the menu and the feature list was not what the C7 VCDS mod articles mentioned.
    So it looks like the C7.5 MIB2 unit isn't as useful as you said for modding things on the fly. Thanks all.
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    I never found anything useful (to me anyway) in the green menu in any Audi I've ever owned. Not one single thing. B7 S4, B8 S5, B8.5 S4, now C7.5 S6. I'm not even going to bother checking anymore.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    Aug 17 2015
    It was super useful when i did some retrofits, made it really easy to enable various items in the mmi menu like turning on ADS, allowing features to be used while driving etc. granted some things still needed a coding component as well.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by VR2V8 View Post
    Is there any document that lists the functions and options on the green menu on the older C7 cars?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 17 2015
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    The links are broken. Audisthesia sent me a Word document (Audi C7 VCDS Tweaks) that's apparently a couple of years old with a variety of options changeable with VCDS, including turning on access to the green menu which I've done. However, I cannot find a similar list of what the various options on the green menu are and why I might want to change any. Anyone have such?
    Aug 17 2015
    Yeah if you look like 10 or so posts in that thread there is a google doc link that works: https://goo.gl/CXSUhY
    Nov 13 2014
    Manchester, England
    A lot of that stuff doesn’t work on the c7.5
    Junior Member One Ring whippa's Avatar
    Mar 06 2010
    Kansas City, MO
    On C7.5 with MIB2, if you've enable the green menu, the button combo to access it is, "Back" + Bottom Left soft key (silver buttons)
    Always own a car that makes you smile , when you look at it , and most of all, when you drive it .
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    That's the VCDS document, not a Green Engineering Menu document.
