Results 1 to 40 of 78
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    Northern Virginia
    Bucking/No Power at above 3,000 RPMs (No CEL)
    Stumped on this one.
    Just finished up a bunch of work, timing etc and now whenever I go above 3,000 RPMs in 2nd-4th gear, the car bucks back and forth and there's no power. It almost feels like it's in neutral.
    NO CEL, no codes in the system. I just replaced a bunch of vacuum hoses, and it idles at 18 inHG.
    The car is running an APR Stage 2 tune.
    Any ideas?
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Unplug the maf and see if it changes anything.
    Dec 10 2013
    Borden, Ontario, Canada
    My money on MAF as well.
    Sent from my SM-G9600 using Audizine Forum mobile app
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Mar 04 2014
    Northern Virginia
    Hmm, thanks guys. I'll try that next.
    I just thought it was so strange how I didn't have a CEL. It even passed emissions this morning.
    2003 Audi S6 Avant
    Feb 23 2010
    Emmaus Pa
    My bet is you have a leak and your maf is working correctly. That’s why you don’t have a code.
    May 10 2018
    MA
    unplugging the maf is an easy way to check things - it will reveal a bad leak, or a bad MAF
    you WILL get a check engine light once MAF is unplugged, and do not give it any boost
    Apr 07 2011
    Home of the mighty beaver
    concur
    Mar 04 2014
    Northern Virginia
    Well, I appreciate the advice from everyone.
    No vacuum, or boost leaks.
    The cats are bad. This is strange because I passed emissions two hours ago.
    2003 Audi S6 Avant
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    Also check your cps
    Sent from my SM-A205U using Tapatalk
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by R490 View Post
    describe "bad"
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Mar 04 2014
    Northern Virginia
    I'm about to go talk to who is looking over the car in person......
    They told me over the phone that they're evidently clogged.
    2003 Audi S6 Avant
    Apr 07 2011
    ah shit. that a recent development? check if actually melted, could be a result of other issues like running too rich etc.
    May 10 2018
    MA
    that seems odd
    anecdotal, but I recently upgraded the downpipes on mine...161k, and they were the original units. They worked perfectly fine, zero clogs. I was even able to upcycle them to someone and made my downpipe $ back and then some
    Mar 04 2014
    Northern Virginia
    Yeah, I'm not too sure what to think. They're XSPower "high flow" cats, with 50,000 miles on them.
    I guess I'll replace them with the same. I just think it's odd how I don't have a CEL, and that this was so sudden. I recently drove the car 300 miles and it was perfectly fine.
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    Quote Originally Posted by S4James View Post
    I guess so, I'll have to see.
    I thought it could be running rich, but it idles and performs exactly like my other S4. It did fry an 02 sensor in like 40,000 miles though, so I guess that could point in the cat direction.
    2003 Audi S6 Avant
    May 10 2018
    MA
    If they are clogged that means they dropped the downpipes to check. That's not the simplest, have this for you in an hour, type thing. Are there pictures?
    Feb 23 2010
    Emmaus Pa
    Shops can do a back pressure test on cats. Peasants like us would have to pull the exhaust apart and look.
    B9 S4- EPL/AWE
    Mar 04 2014
    Northern Virginia
    I dropped the car off at like 1:30.
    I brought it to a German car specialist that does a lot of VW/Porsche work, so hopefully, they'll have some evidence.
    2003 Audi S6 Avant
    May 10 2018
    MA
    Quote Originally Posted by CELison View Post
    still involves dropping the downpipes on these cars, since those testers use the 02 sensor bungs, and those face upwards IIC. Well, up on on, and vertical on the other.
    Dec 17 2016
    B5 S4 Avant
    Fl
    describe "bad"
    When it smells like cologne, leave it alone
    Mar 04 2014
    Northern Virginia
    They apparently tested the cats, by driving the car? Nothing else. Tech said there's a "whooshing" sound when the gas pedal is pressed and the RPMs drop off. He also said it smells like it's running rich.
    One of them told me to start, by flashing it back to a stock tune. I don't see how that would help, since it's been on Stage 2 software since 2011. If the cats are bad, they're bad. But why would I spend $1,000+ if they can't even tell me with certainty what's wrong?
    Here's the exact symptoms
    -Car falls flat on it's face at 3,000 RPMS, won't rev any higher, jerks and bucks when it does happen
    -Whooshing sound when this happens
    -Fuel/exhaust smell in cabin
    -Car is hard to start sometimes
    Pulled one of my spark plugs to gauge carbon deposits. It's clean.
    2003 Audi S6 Avant
    Junior Member Two Rings NachO_GMC's Avatar
    Sep 09 2017
    W205 C63 Coupe, Maserati Levante Q4, Chevy Silverado 1500, 2004 SRT-4 (Race Car)
    KS
    check the CPS on the bellhousing for any issues (sometimes the wires get melted from the exhaust heat - that could cause your issue)
    Grounds - check and clean them
    Are your Diverter valves in good working order?
    I'm working on a 4500 rpm engine cut that is almost exactly the same lead up symptoms as yours. I did the above things to rule out the obvious.
    GL
    Mar 04 2014
    Northern Virginia
    Quote Originally Posted by NachO_GMC View Post
    GL
    Appreciate the advice!
    Assuming CPS is crank pos sensor?
    It's just such a strange issue...
    2003 Audi S6 Avant
    Feb 23 2010
    Emmaus Pa
    Sounds like a boost leak.
    Jan 03 2009
    Iowa
    TBB okay? Have to remove to fully inspect.
    The woosh makes me think TBB.
    Mar 04 2014
    Northern Virginia
    The car has an APR bi-pipe, so the TBB is bypassed.
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    That would be one hell of a boost leak, no?
    The whooshing noise when the car is failing to hit boost is what's throwing me. Why would they say that's the cats?
    2003 Audi S6 Avant
    Feb 23 2010
    Emmaus Pa
    Doesn’t take much of a leak to cause major bucking. It sounds like it’s large enough to be audible. Also, this show sounds pretty incompetent.
    Mar 04 2014
    Northern Virginia
    Where would you suggest I look first? I've never dealt with a boost leak this large. I'm only in town for another few days....
    Yeah, I got that impression too. The tech also said it could be my fuel pump failing, as well as both of my cats failing simultaneously. I'm 0/2 on German car repair shops.
    2003 Audi S6 Avant
    Feb 23 2010
    Emmaus Pa
    Need to do a boost leak test by pressurizing from the Y pipe. No point in guessing. Where do you live?
    Mar 04 2014
    Northern Virginia
    I store the car in Virginia, but I (unfortunately) live close to Altoona PA.
    Apr 07 2011
    that does sound like you blew the TBB, one of the couplers.. something really big.. ive had both happen, similar effect to your issue. Disconnect the maf, and see if you can drive around ok (obviously not trying to make boost)...
    clogged cats dont go whoosh
    Mar 04 2014
    Northern Virginia
    Is it fine to drive with the MAF unplugged above 3k RPMS? That's the only range I have the issue.
    I don't have a TBB with my APR Bi-Pipe. What do you mean by the couplers?
    2003 Audi S6 Avant
    Feb 23 2010
    Emmaus Pa
    No issues driving with the maf unplugged. It will just be in open loop. They should do that ASAP. You’re 3 hours from me. I would tell you to just bring it by.
    Mar 04 2014
    Northern Virginia
    Come to think of it, I stripped a bolt that holds the TBB sensor to the top of the APR bi-pipe and it's not mounted securely up there. Could that cause this?
    EDIT: Def not, I can't move it by hand
    I'll try it tomorrow morning, thanks again for the advice. Wish there were more B5 people around here, indie shops just don't really seem to know.
    2003 Audi S6 Avant
    Feb 23 2010
    Emmaus Pa
    “Woosh” noise has boost leak written all over it. Pretty astonishing that a German Indy shop wouldn’t pressure test the car first.
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    What a ride. Even took it to emissions like that, that’s amazing.
    Definitely a boost leak for the sound of it.
    Get your soapy water and a spray bottle. You can make or buy a kit pretty cheap and quickly.
    You’ll have a lot more fun once you track it down!
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Any ideas?
    Vacuum/boost leak only showing its head under load/boost? Can you do a boost leak test or smoke it?
    For what it’s worth, my 2.7 usually idles around 20inHg and when my throttle body boot was torn this past summer I was only getting a soft code and no CEL.
    Mar 04 2014
    Northern Virginia
    Yup, only shows when I'm getting on the throttle. Also noticed it doesn't occur in first gear. Driving around and idling, it's fine. However, it sometimes has difficulty starting.
    Tomorrow I'll try to do a boost leak test. I just think it's so strange to have such a large issue, and no codes to show for it.
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    Yeah, I was kinda pissed off that they couldn't even give me a straight answer. Appreciate all of your help, I'll update tomorrow.
    - - - Updated - - -
    Quote Originally Posted by JustManson View Post
    I reeeeeeeeally hope it's a boost leak, and not cats like this "shop" said. It's been one thing after another since I did my timing job.
    2003 Audi S6 Avant
