Results 1 to 11 of 11
    Veteran Member Three Rings boooost3d's Avatar
    Mar 15 2018
    New Orleans, LA
    HELP me build this car S3 8V Prefacelift (Mod Heavy)
    Currently The car is APR Stage 3+ with most of what APR has to offer for the car thats bolt on. Included wheels and suspension as it was one of there promo cars. I blew the engine so I am going all out on the build but I do not want to change the turbo or go E85 as it is not readily available for where I currently love. Here is a list of what I am currently doing on the build as we speak. I am looking for some assistance in making sure this is a solid 10 sec car and any mods I am missing out on that can make a significant difference.
    Current Mod list
    APR Stage 3 Plus Turbo System
    APR Fueling System Upgrade
    APR Carbon Fiber Intake System
    APR Cat Back Exhaust with Valves
    APR Intercooler System
    APR Boost Hose Kit
    APR TCU Tune
    APR Spherical Pendulum Mount
    APR Dogbone/Subframe Mount Insert
    034 Upper Dogbone Mount Insert
    APR Brakes 350mm
    APR 19X8.5” (ET45) Flow-Formed Wheels
    APR Roll-Control Front and Rear Sway Bars
    Bilstein B14 PSS Coilovers
    ECS Tuning Adjustable Front and Rear End Link Kit
    034 Subframe Locking Collar Kit
    EMD PURE Carbon Fiber Rear Diffuser
    EMD PURE Carbon Fiber Front Splitter that needs to be replaced.
    EMD PURE Carbon Fiber Rear Spoiler
    Pinalloy Real Carbon Fiber Interior Trim Kit
    Carbon Fiber Mirror Covers (eBay)
    New Build Parts
    Racingline Oil Cooler Kit
    CTS Lightweight Crank Pulley
    Racingline DSG Oil Cooler Kit
    Hawk Rear Brake Pads(mine are low)
    Seasucker Bike Rack(MTB)
    Motul Oil Change Kit
    PODI Digital Multifunction V3 Gauge
    Snow Performance Water Meth Stage 2 kit
    APR Performance Ignition
    Kohlefaser Luft-Technik Intake full front
    ECS Secondary Air Filter Adapter Kit
    UB Under Body Brace
    CSF Racing Radiator
    CSF Racing Aux DSG Radiator
    LiquiMoly DSG Service Kit
    CYBF A2B Racing Long Block
    • A2B Motorsport Stage 3 Long Block
      -Custom A2B Motorsport JE Pistons 83mm
      -Proper Machine work to set piston and wall
      -Fit and File Rings
      -Bore, Deck Hone of engine Block
      -Boostline Connecting Rods
      -ARP Head Studs
      -Welded Tone wheel for High Revs
      -Supertech Valves Intake and Exhaust
      -Supertech Valve Springs
      -Decking of head and cleaning
      -Hand Porting of Cylinder head
      -ACL Main Bearings
      -ACL or King Rod Bearings
      -All new OEM of the Following:
      Hardware and One time use bolts
      Head Gasket
      All other Engine Gaskets OEM Only
      New Timing Components
      New Lifters
      New Valve Seals
      New Oil Pump
      New Cam Bridge
      New Balance Shafts.
    VW / Audi 2.0T FSI TSI Direct Port Injection
    RSR Studio 4 Point Roll Cage
    EMD Carbon Fiber Front Lip
    Unibody Tunnel Brace
    Unibody Rear Brace
    034 Rear Trailing Arm Kit
    I am unsure if it has the following
    Updated APR tuning for TCU and ECU
    Upgraded LPFP
    I am sure I am missing a bunch of thinks but please give me some ideas of what else I would address. I have a lot of cars I need to beat and a lot of cars of track days id like to attend. I also have an R8 (along with all the other Audi's except an rs7, rs6, rs5) so my sense of speed is slightly skewed because it is starting to feel slow. I would also like to keep in mind lightening the vehicle up. I do plan on running the high octane file from APR.
    Give me some ideas guys.
    Visiting New Orleans?
    @nola_gruppe
    @boooost3d
    NOLAGruppe.com
    Mar 15 2018
    New Orleans, LA
    Oh and before someone says something like,"you should have gotten an RS3 and modded that" I already have a TTRS and I have a think for making the middle middle faster. Everyone already expect the RS3/TTRS to be fast.
    @nola_gruppe
    @boooost3d
    NOLAGruppe.com
    Mar 15 2018
    New Orleans, LA
    @nola_gruppe
    @boooost3d
    NOLAGruppe.com
    Oct 02 2020
    It looks like you already know what to do and what direction you want to take. The only things I can think of are not using the bike rack and the CTS Lightweight Crank Pulley. Maybe also some CF panels and removing the back seat. And maybe sone little suspension bits and pieces. Other than that you have it covered, especially with that built motor, car is going to be a monster!
    Sent from my LG-H871S using Tapatalk
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I’m curious to see what the car weighs fully gutted before you put the cage in. Are you talking no rear seat type “gutted” or full gut removing ~500 pounds?
    2016 S3
    Instagram- @Thisisastickup
    Mar 15 2018
    New Orleans, LA
    Quote Originally Posted by brian23A3 View Post
    Why not the bike rack? It would be more of a novelty but I was contemplating a roof rack instead. What are your thoughts on the LWCP from CTS? I will be removing the back seats obviously and finding light weight panels is not as easy as you would think. I would love some fenders, hood and trunk. What suspension parts do you think I am missing. Motor should be done in 2 weeks
    Quote Originally Posted by b6Hate4 View Post
    I think I would be happy with shaving 200lbs. I wish I knew how much the cage will add. 200 is already a stretch because I am adding probably at lease 50lbs and rigidity parts
    @nola_gruppe
    @boooost3d
    NOLAGruppe.com
    Oct 02 2020
    Maybe others can chime in but for our cars fluid damper pulleys seem to be pretty good.
    On some cars the lightweight pulley affects the motor because they make the pulley smaller (that's why they include a new belt, smaller than OEM) and it a spins the alternator, AC differently to free up 5-10 HP (supposedly). Some people mention that they prevent the battery from properly charging. There's a lot of debate but these are expensive cars and I would not risk it. IMHO of course.
    Oct 02 2020
    IMHO, roof racks should be if you really are using them for their intended purpose. And on a performance car being as built as you are doing is just unnecessary weight.
    But again if you ride bikes, snowboard, etc. It's cool.
    Oct 02 2020
    Suspension
    Front and rear endlinks
    Control arms
    Change every bushing you can!
    Front and rear sway bars (not sure if this is in the mod list)
    Front upper strut brace
    Also the engine and transmission mounts. Most people like the BFI mounts.
    I think a company called Darwin Pro makes a CF hood for the car.
    And I'm not sure if one of the braces you mentioned goes in the trunk of the car.
    That's all I can think of lol. Sorry for the multiple posts.
    Mar 15 2018
    New Orleans, LA
    Suspension
    Control arms
    NO Worries on the multiple.
    The controls arms, endlinks, Sways, mounts are done. I am going to do the Ultra racing tower braces for the front and rear. I actually do a good bit of mountain biking so I do want to use them. The Car will also match my bike so its technically part of the show part of the car. And Thanks for the input on Darwin Pro
    @nola_gruppe
    @boooost3d
    NOLAGruppe.com
    Oct 02 2020
    Very cool. Eurocode also makes a nice rear brace.
