Originally Posted by
S6Man4.0tt
Seems like smelling gas in the oil under the oil cap is very common. It's right next to the high pressure fuel pump which are known to have leaking seals and dilute your oil. Also injectors can go bad. I'm wondering how common this is. The 2 4.0's I've personally owned and checked both had the smell. I know alot of people have had real problems and fuel smells where a bad sign.
I'm not sure that a smell of gas means it has an issue either though given how the PCV system is it may be somewhat normal to a degree. In my case I had no issues with driving or starting ect. and logs look fine.
Be aware the oil cap itself and the plastic right under the cap can really reek from buildup on it but the air coming out isn't as bad. I've noticed I can clean this and the smell can goes away from the cap itself and not come back. I'm not sure how much that should count in this case. I can tell the air still has fuel smells in it to some degree a little bit which may be normal.
This may just be me, but thinking a gas smell mixed in with your oil is “normal”, goes against every engineering principle that every combustion engine has been built around.
It does seem like the more people tune their 4.0t cars and go bigger turbos, or other forms of fuel, the HPFP has been failing for a growing number of people. Not sure it’s all that common just yet, but seems to be a growing issue and likely weak point.
This is something you should get checked out. If you have DS1, you can log your runs/driving to determine if you have a potential HPFP leak - fueling would drop at certain points. I believe they also have new “health check monitors” to help determine early on if you have a failing injector. It sounds like you have logs, didn’t know what has been logged.
You can also check out the HPFP itself - take it a part and check for leaks.
If you don’t have the typical PCV failure symptoms - hard to pull oil cap, whistling and oil consumption - I personally don’t think it’s a PCV issue causing that smell in the oil.
