Results 1 to 27 of 27
    Oct 23 2015
    Australia
    Preferred spark plugs for 2.0 with stage 1 ?
    I pulled out my tri electrode Bosch plugs they'd done 60 K miles ( yeah I know Bosch are generally not liked ) and put in an another used set of Bosch side electrode platinum I had and car runs so much better,smoother and no detectable miss at high revs which I was getting
    Which NGK's are the go-to now ?
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Jun 27 2011
    For stage 1 I'd stick with stock heat range NGK BKR7EIX.
    I'm current;y running Bosch Platinums (though I'm stock) and have no issues with them.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 23 2015
    Australia
    Ah,that model rings a bell from when I was last looking for plugs on here probably 5 years ago.They get a good rap but exxy over here- about $A75 a set.I remember why I went with Bosch,I had a big order from FCP and the extra postage didn't matter....
    I'll go with them anyway,60k is probably time for replacement with any iridium plug.
    Incidentally,many many of your mommy missiles over here,very popular..when I was looking at upgrading Wolfie last year,the common thread from the owners selling B8's and 9's was " kids arriving, #1 needs a Q5 "
    Jun 27 2011
    Yea that’s what we did for sure, haha. First kid on the way, the Avant became mine, the sedan was sold and the q5 was bought. Then when number 2 came we had to upsize to the Q7. They were both great cars but q5s are really not that big at all, two kids and two dogs and it was way overloaded.
    -CP
    2017 Q7 3.0t
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Stock plugs PFR7S8EG gapped to .028.
    Gap is more important than what model of NGK plug you run but the stock plugs are fine for stage 1 and last long.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    I prefer the FR5DTC to be honest.
    https://jhmotorsports.com/spark-plug...-and-4-2t.html
    Jun 27 2011
    Quote Originally Posted by EvolutionArmory View Post
    Stock plugs PFR7S8EG gapped to .032.
    FTFY. 0.8mm is the standard gap specified by audi, which translates to .032".
    Also I'm using the bosch FR6KPP332S plugs just to add to my sorta vague post above.
    -CP
    2017 Q7 3.0t
    Oct 23 2015
    Australia
    Just had a look at your plugs-DOUBLE platinum ! amazing no ones brought out triple platinum haha marketing....
    The advantage I see with the plugs Jake likes above ( which are the same that I just pulled ) are that there is no gap to contend with,also they are crazy cheap,even over here ie $A26 for 4....
    Oct 23 2015
    Australia
    And no wonder my Bosch were misfiring,I just discovered from spark plugs.com (fake news aside ) that they are only rated for 30k miles,I had done 60k
    May 20 2017
    New Hampshire
    Yes. .032 for stock boost levels is fine.
    Stage 1 at 20 PSI should be gapped to .028. But the stock heat range stock plugs are fine all the way up to K04. Just gotta gap them down
    Mar 24 2013
    Oakdale, CT
    I’m running BKR7EIX gapped at 0.026”. I tried BKR8EIX but the car felt “off” with them so I switched back.
    -Adam
    Account Terminated Four Rings
    Oct 15 2013
    What are you looking for? Performance or longevity? Or both?
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    Quote Originally Posted by Jake@JHM View Post
    Would this be a good alternative to the Bosch F5DP0R? I have been looking for those again to replace what I have but can't find them at a reasonable price, and don't know if they were discontinued or changed the name or what so just moving on. thanks
    Oct 15 2013
    No better plug than ngk ruthenium for performance and durability.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by esandes View Post
    Lol, what do ya have to back this up?? Cuz theyre newer??
    Sent from my LM-G710VM using Audizine Forum mobile app
    May 20 2017
    New Hampshire
    Quote Originally Posted by Jayz691 View Post
    He never has anything to back up what he says.
    I mean the truth is, there aren’t a lot of cars here making enough power where going above the factory PFR7S8EG plugs gapped at .028 will make a difference. And those cars seem to do fine with BKR8EIX plugs.
    People make way to much noise about plugs. Run the right heat range and gap, and replace them when you need to. That’s it. 🤣
    Established Member Two Rings Liberty0rDe4th's Avatar
    Mar 28 2022
    usa
    Most of the canned tuned manufacturers create their tunes using OEM style plugs. So the tune is based on that performance level. I went with this kit. if I'm spending the time pulling the plugs out I might as well replace the coils at the same time. I'm skeptical that hotter or colder plugs would make any significant difference under low level tunes.
    https://www.moddedeuros.com/products...gk-spark-plugs
    Sent from my Pixel 6 Pro using Audizine Forum mobile app
    Mar 28 2022
    usa
    And don't forget the dielectric grease. But, don't use too much. It can cause the coil pack to slip, potentially causing misfires.
    Oct 15 2013
    Quote Originally Posted by Liberty0rDe4th View Post
    I run 2+ and a colder plug didn't work well (cold engine misfires under load) plus there seems to be more carbon fouling of the colder plug.
    Jan 21 2018
    frackville, pa US
    Yup. I ran 7 heat range from stock to stage 2. When I went k04, I ran 7's for a littlr, but then switched to 8's(bkr8eix). Seems to run a little smoother under lower RPM, higher boost. It was partially cuz I was trying to see what was causing a little timing pull(2°-3°) up top. Plugs didn't really help, little e85 does. Motoza does recommend bkr8eix with their tunes, so I left them in.
    Mar 28 2022
    usa
    Indeed.
    Feb 15 2016
    Cambridge,Ontario
    agreed , i accidentally in a tune up kit i bought from jake, installed one heat range lower and fuel efficiency fell off a cliff, i went back to stock plugs and all has been good, last replaced plugs about 4 years ago .. poor plugs get blamed for everything,
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    May 20 2017
    New Hampshire
    And they’re usually blamed by the guys like Esandes who don’t know anything and are barely modded.
    Feb 15 2016
    Cambridge,Ontario
    hey give him a break, not always, .. the other 50% of the time he blames the PCV !!!
    1976 Yamaha XS 360
    Mar 28 2022
    usa
    Jan 21 2018
    frackville, pa US
    me too
    Feb 15 2016
    Cambridge,Ontario
    Hey that's a good looking taco.
    Sent from my Pixel 6 using Audizine Forum mobile app
    1976 Yamaha XS 360
