Results 1 to 12 of 12
    Nov 20 2015
    West Palm Beach FL
    TPMS fault, Intermittent AC
    So I went to drive my car on lunch today and I got a TPMS fault. There was also a code for the ambient temp sensor. When driving the outside temp goes blank from time to time. The AC will also intermittently work. I scanned the car and have codes for a few different control modules. I’m thinking maybe I need a new battery to start with, but I would appreciate any insight someone might have about the codes that were present. Don’t mind the headlight codes, I unplugged that and started the car and forgot to plug it back in.
    Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
    Component: 3.0T SIMOS84 H08 0003
    Revision: --H08---
    Coding: 0104000A240F0128
    Shop #: WSC 06324 000 00000
    ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
    ROD: EV_ECM30TFS0218K0907551D.rod
    VCID: 3260DB2765957DDA10-8066
    1 Fault Found:
    6492 - Sensor for Ambient Air Temperature (G17)
    P0073 00 [037] - Signal too High
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 157219 km
    Date: 2021.01.07
    Time: 15:12:56
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 92 °C
    Intake air temperature: 72 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.679 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 0 /min
    MAF_ENVD: 0.00000 mg/stroke
    Coolant temperature (unfiltered): 92.3 °C
    Engine: operating status: ES
    Engine load: 0.000000 %
    Vehicle speed: actual: 0 km/h
    Readiness: 1110 1101
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 290D1A
    VCID: 02004BE79DB50D5AC0-8056
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 157219 km
    Time Indication: 0
    Date: 2021.01.07
    Time: 15:13:40
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x00A2
    Hex Value: 0x0038
    Hex Value: 0x3394
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 0D0100
    Shop #: WSC 06325 000 00000
    VCID: 77F62A33C67758F2E7-8022
    Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Serial number: 2311000148338008
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 34
    Reset counter: 211
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.02
    Time: 20:43:48
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
    Component: KLIMA 3 ZONEN H04 0121
    Revision: C1000000 Serial number: 01131120130810
    Coding: 6600228000
    VCID: 3972EC0BB0E38E82D1-806C
    3 Faults Found:
    01020 - Water Pump (V36)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 157219 km
    Time Indication: 0
    Date: 2021.01.07
    Time: 15:14:50
    Freeze Frame:
    Voltage: 11.60 V
    Temperature: 91.0°C
    Current: 0.000 A
    Voltage: 11.60 V
    not available
    Bin. Bits: 10000001
    RPM: 0 /min
    Load: 0.0 %
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 157219 km
    Time Indication: 0
    Date: 2021.01.07
    Time: 15:14:50
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 157219 km
    Time Indication: 0
    Date: 2021.01.07
    Time: 15:14:50
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000001138175
    Coding: 26001091063CAF212700080300003D0D4F9CD2480201016100 0000
    VCID: 3C7CF51FBFD1BBAACA-8068
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 160711 H07 0070
    Serial number: SWF11070165354
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 11552526
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000000807110912
    Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
    Component: HOMELINK H01 0010
    6 Faults Found:
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.04
    Time: 17:34:00
    00979 - Lamp for Low Beam; Right (M31)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.04
    Time: 17:34:00
    03189 - Bulb for Side Marker Light; Front Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.04
    Time: 17:34:00
    01496 - Bulb for Fog-Lamps; Left (L22)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.04
    Time: 13:49:00
    01500 - Bulb for Fog-Lamps; Right (L23)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.04
    Time: 13:49:00
    00779 - Outside Air Temp Sensor (G17)
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 32
    Reset counter: 211
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.02
    Time: 20:43:00
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q
    Component: KOMBIINSTR. H11 0258
    Revision: 00000000 Serial number: EJG60DG7C
    Coding: 8F1F09008B00D705020000
    VCID: 418284EBD833D64299-8014
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 34
    Reset counter: 211
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.02
    Time: 20:43:23
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0154176413
    Coding: 0106023A00FA440580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0070
    Serial number: 00000000000000414974
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
    Component: J245 PS045 H07 0041
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 34
    Reset counter: 211
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.02
    Time: 20:43:48
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1501
    Coding: 011C13204E00410001
    VCID: 52A0BBA70D555DDA30-8006
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 156386 km
    Time Indication: 0
    Date: 2020.12.21
    Time: 08:02:25
    Address 55: Headlight Range Labels: 8T0-907-357.clb
    Part No SW: 8H0 907 357 C HW: 8H0 907 357 C
    Component: AFS 1 H01 0040
    Revision: 00H01001 Serial number:
    Coding: 0000019
    VCID: 3260DB27AD957DDA10-8066
    Subsystem 1 - Part No: 8K0 941 329
    Component: AFS-Modul links H02 S001
    Subsystem 2 - Part No: 8K0 941 329
    Component: AFS-Modul rechtsH02 S001
    1 Fault Found:
    02234 - Right Headlight Power Output Stage (J668)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 156946 km
    Time Indication: 0
    Date: 2021.01.04
    Time: 17:34:01
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 8R1 035 746 K HW: 8R1 035 746 B
    Component: H-BNT-NA H44 1040
    Revision: -------- Serial number: 204KW0C7541307
    Coding: 110200000206E1EF41028B4E00000403140000000000000000
    VCID: 3F868213AEC7A0B2EF-806A
    Subsystem 1 - Part No: 8R0 060 884 BA
    Component: NAR 2013 0703
    Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
    Component: DU7 High H43 0084
    Serial number: 9466FA0B0596979
    Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
    Component: E0380 Bedient H02 0030
    Serial number: 00000001315908
    Subsystem 4 - Part No: 8R0 060 961 E
    Component: CD-Database 4949
    3 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 152
    Mileage: 155964 km
    Time Indication: 0
    Date: 2020.11.25
    Time: 12:11:15
    Freeze Frame:
    Text: DU9466,Front,M,0,0,5
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 18
    Reset counter: 211
    Mileage: 157219 km
    Time Indication: 0
    Date: 2021.01.07
    Time: 15:10:01
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00010000
    01524 - Antenna for Telephone
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 152
    Mileage: 155964 km
    Time Indication: 0
    Date: 2020.11.25
    Time: 12:11:25
    Freeze Frame:
    Voltage: 11.60 V
    Jul 31 2016
    PA
    I would suggest new battery as well, but first thing I would do would be to clear them all and see what comes back over a week or so. Could be climate module for AC, not sure if that is where the ambient temp sensor feeds into as well, but possible.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Nov 20 2015
    West Palm Beach FL
    So I replaced my battery this evening and cleared all the codes and I’m still having issues. I ran the 3 measuring blocks to check battery health and here is what I got. battery.JPG
    My question is since I just put this in should I assume it will need to charge while driving a bit to give me an adequate assessment of what my issues are? For group 19 does 99% aging mean it’s only lost 1% or the car thinks it’s shot? I got the battery from the dealer and programmed in the new BEM code.
    Jul 16 2018
    Atlanta
    Clear the codes and see what comes back. No point posting known noise.
    If the outside temp is going in and out, could be the sensor. Or could be the circuit. The G17 outside temp sensor has two wires back to the J519 central electrics control module (address 09). One is the power supply to the sensor, the other is the ground line to the sensor. But a number of sensors share that same ground: brake fluid level sensor, windshield washer fluid level sensor, and engine coolant level sensor. So if you're not having errors from those, it's likely the G17 or the plug to the G17 (maybe it's not fully clipped into place?). There's nothing to tie the G17 to all the other electrical issues in the scan as posted.
    As for the TPMS, did you get a fault? Or did you get a warning? Because there's no DTC there.
    Nov 20 2015
    West Palm Beach FL
    Quote Originally Posted by Smac770 View Post
    The outside temp is going in and out and now it’s reading way off when it does read. I’m leaning towards a bad sensor as I just double checked the connection and I don’t have errors in the other systems you mentioned.
    For the TPMS I get an actual fault. I didn’t see any codes either but it’s there. It’s a bit odd because when I start the car every once in a while the fault will go away. This is why I originally thought battery as it was 8 years old and I know the car can do strange things with a bad battery. I’m wondering if there is a loose wire/ground somewhere that could cause this.
    I actually stumbled on another thread where someone had similar faults that you responded to. You mentioned the home link module potentially causing an issue if there was a loose/broken wire. I did recently have the bumper off to do the water pump/pcv/tstat/ and carbon clean. These issues didn’t start happening till about 3-4 days after I completed the service though.
    Jul 16 2018
    Atlanta
    You don't say what MY you have, but unless it's MY09, you don't have actual TPMS sensors. TPMS in the MY10+ is indirect TPMS, meaning it just uses the ABS/ESP module and it's various wheel speed and vehicle acceleration sensors, as well as steering angle, to surmise if a tire is flat. That's why a problem with confidence in operation of the ABS/ESP control module (address 03) might yield a TPMS fault. But the ABS DTC you have says "J285 instrument cluster is unhappy, I'm sad", and the J285 just says "J519 central electrics is unhappy, I'm sad", and the J519 just says "right headlamp not connected and this G17 is flaky as hell", neither of which should the ABS system care anything about.
    But you do seem to have a steady low voltage, one freeze frame from Nov at 11.6 and two freeze frames from Jan 7 at 11.6. Lot of short drives? My AGM was still good after 10 years, but my drives are all 5+ miles. Not sure why your voltage is only 12.0v. Blocks 18/19/20 are about the battery, 21/22/23 are about energy management, and 14/15/26 are about the alternator. And 1 is the term 30 and term 15 values. When the engine starts, you'll normally see the voltage go into the 14s, and then get down into the mid 13s as the battery state of charge approaches 85%, where the car doesn't try to charge it further. Are you seeing that during a drive? Or is the drive so short, the battery SoC never returns to 85%?
    The percentages are 100% (new/full) down to 0% (old/empty).
    On the HomeLink transmitter J540, that subject probably came up because the person was having issues with the air quality sensor G238 or refrigerant pressure sensor G395. They are all on a LIN bus, so problems with one device could interfere with the communications with the other devices. The outdoor air temp sensor G17 is not a comms device, just a simple signal device, though it does share a ground line with other sensors.
    Nov 20 2015
    West Palm Beach FL
    The car is a MY12. It’s funny you mention short drives as my commute to work is only 5 miles round trip. The screenshot of blocks 18/19/20 is right after I replaced and recoded the battery last night with ignition off. I was surprised to only see 44AH as the rating is 110AH and it was a new battery from the dealer. I couldn’t find a date code so I’m curious how “new” it actually was
    This morning when I started the car I had no errors and the ambient temp was reading correctly. I’m going to rescan this evening and see what is still there for codes after clearing last night.
    Jul 16 2018
    Atlanta
    The Ah on mine has never been close to the quoted value, even right after replacing the battery, it was only 2/3s the quote value. So not sure how it computes that, but it seems irrelevant. That said, 110Ah is not an AGM, the AGM would be 105Ah. And 44Ah does seem way down more so than I would expect. But is the 110Ah non-AGM the part number encoded into the battery adaptation? My J533 always seems to read .1V or .2V low for term 30 compared to other modules. Does a multimeter support the same voltage value when you read say across the two jump start posts under the hood?
    As you have VCDS, you can pull the history data from address 19 (CAN Gateway) and see if anything looks particularly interesting in it.
    Nov 20 2015
    West Palm Beach FL
    Yeah the battery is non-AGM and I coded the battery to the car immediately after install. I’ll have to test with a meter later today.
    I left work just now to grab lunch and when I started the car all the errors with the TPMS fault and blank ambient/no AC were back. It’s strange that they will randomly come and go.
    Nov 20 2015
    West Palm Beach FL
    So after clearing and re-scanning here is the general idea of the issues.
    Address 01: Engine
    Sees issue with G17 Ambient air sensor
    Address 03: ABS J104
    Sees issue with J285
    This ABS code does not return immediately after clearing
    Address 5 Acc/Start Auth-J393
    J393 sees issue with itself
    J255 sees issue with J519
    J255 sees issue with J285
    J519 sees issue with G17 (outside air temp sensor-electrical fault in circuit)
    J285 sees an issue with J519
    J393 sees issue with J285
    I’m not sure if these are related to my issue. I upgraded to 3g+ MMI and they might be related to a coding issue. The antenna code is because I never hooked up the antenna when I swapped everything.
    2 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 157467 km
    Time Indication: 0
    Date: 2021.01.20
    Time: 13:27:11
    Freeze Frame:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 157467 km
    Time Indication: 0
    Date: 2021.01.20
    Time: 13:27:19
    Freeze Frame:
    Voltage: 12.10 V
    Jul 16 2018
    Atlanta
    I'd replace the G17 sensor and see where it goes from there. There's clearly a problem with it or the wiring between it and the J519.
    For builds after May '11 (such as MY12), it should be https://parts.audiusa.com/p/Audi__/A...Z0820535B.html
    Nov 20 2015
    West Palm Beach FL
    Replaced the G17 today and everything seems to be back to normal. Cleared the codes and will monitor over the next few day
